Wheel Backspacing and Offset Info
Discussion in 'Wheels & Tires' started by tcBob, Jul 17, 2010.
  1. Mar 22, 2011 at 9:06 AM
    #41
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    does anyone know if a set of 15x10 wheels will fit a 1st gen prerunner. kinda curious cause i found a good deal on tires but im afraid they wont fit over the brakes
  2. Mar 22, 2011 at 11:33 AM
    #42
    Lovelyn1
    Lovelyn1 Well-Known Member
    Danalyn
    Big Island, Hawaii
    05 Tacoma SR5 4x4 SuperWhite
    2 inch leveling kit......and that's all for now!!
    Ok....reading all this technical info and trying not to get too confused cuz I'm a girl(hahaha)..... but my simple question: if im puttin on a 6" lift w/ 20x10 rims n 33" tires.....do I still need to worry about this bacspacing thing???......if so, Wat r some suggestions for it?
  3. Apr 21, 2011 at 7:53 AM
    #43
    JC47
    JC47 Well-Known Member
    British Columbia
    08 TRD Sport DCLB 4X4
    OME 885, 5100's, 1.5 AAL, DC2's, 265/75/16 Duratracs. Leer Cap, Debadged.
    16x8, 0 offset and 4.5 bs
    17x9, -12 offset and 4.5 bs
    Will these "stick out" roughly the same?
  4. May 27, 2011 at 2:27 PM
    #44
    elk340
    elk340 Well-Known Member
    Justin
    Ouray, CO
    '11 Tacoma TRD Off-Road AC
    Toytec ULK; OME Dakar leaf packs; Light Racing UCAs; OME carrier bearing drop; Toytec 3 degree axle shims; sway bar delete; Toytec extended rear brake lines; ARE CX topper; BAMF rear differential skid; BAMF LCA skids; BAMF sliders; Budbuilt IFS, mid, transmission, and gas tank skids; HomerTaco mesh; River Rat 69 satoshi grille; Toyota Land Cruiser radiator grille emblem; tinted windows; Toyota all-weather floor mats; Toyota bedmat; I-Pod interface; block heater; ATO hi-lift bed rail mounts; HL-605 Hi-Lift; RotoPax 4-gallon gas can and bed rail mounts; mattgecko sliding window security bar; Sockmonkey decals.
    6x139 I believe
  5. May 27, 2011 at 2:39 PM
    #45
    98tacoma27
    Ben
    Not Beech Creek
    :thumbsup:
  6. Jun 1, 2011 at 2:30 PM
    #46
    BlueYota
    BlueYota Well-Known Member
    Arron
    South Texas, WAY south!!!
    Blue 06 4x4 TRD
    3" lift
    I have an 06 TRD 4X4 Tacoma with 16" alloy TRD wheels. I have the All-Pro UCA's with the 5100's in the front with 285/75/16 Dueler Revos. Currently when I make sharp turns the tire will rub on the UCA's. I am looking to get new wheels and tires and would like to keep the same size tire but but not sure on the wheel size/offset/backspacing i need to get some extra room between the tire and UCA.
    If any one here can help out that would be great.
    FYI: I am looking at putting Destination MT's with the Ultra Wheel Maverick. I am more open to changing wheel size than tire size. I would like to keep the wheel well looking full.
    Thanks and sorry about the novice question!
  7. Jul 4, 2011 at 2:54 PM
    #47
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    anyone running 18x9 with 5.5" backspacing and offset +12? i have a 06 dc with 3" lift. would like to see some pics of those that have a truck with wheels these specs running 285/65/18. thanks!
  8. Jul 4, 2011 at 3:06 PM
    #48
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Those tires are too big to run on wheels with 5.5" backspacing. You will need 4.5".
    I have rims with nearly those same specs you noted, with a 1.75" lift and 265's. If you want to see some pics, check out my build in my sig.
  9. Jul 4, 2011 at 6:45 PM
    #49
    pngo121
    Phi
    Pittsburg, CA
    would this be a rubbing issue or what? the wheels i have right now are 17x9 4.5" bs n -12mm offset. just looking for slightly bigger wheels.
  10. Jul 4, 2011 at 8:15 PM
    #50
    TexasTacoma37
    Yes, it will be rubbing on the UCA.
  11. Jul 4, 2011 at 9:24 PM
    #51
    pngo121
    Phi
    Pittsburg, CA
    thanks for the info!
  12. Jul 6, 2011 at 9:00 AM
    #52
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    What offset/backspacing range should I look at for just wanting to be stock.
    I have the 265/70/16 tires and will be replacing them, but also getting some winter wheels/tires. I don't want my wheels/tires being too much closer to cause rubbing, or sticking way far out.
    Thanks.
  13. Jul 6, 2011 at 9:19 AM
    #53
    TexasTacoma37
    Stock is a 5.5" backspaced, 7" wide rim. Only way to stay stock would be to get a rim with those same specs.
    As an exmaple, if you got a 8" wide rim, with 5.5" backspacing, it will stick out 1" more than stock. An 8" wide rim with 4.5" BS would stick out 2" more, and so on.
    Surf808Dad and Lmw93 like this.
  14. Jul 11, 2011 at 5:28 PM
    #54
    rcfreak201
    rcfreak201 Well-Known Member
  15. Jul 23, 2011 at 8:09 PM
    #55
    NoLimits
    NoLimits Member
    Barry
    Tulsa
    Black Longbed 4x4
    I'm thinking about getting a set of 15x8 with probably some 265/70 on them but my question is would the 2.5 backspacing stick the wheel out too far? Or would the 3.75 do the job?
    I'm just basing the question on how it would look. Thanks
  16. Jul 23, 2011 at 8:12 PM
    #56
    TexasTacoma37
    265/70/15 on a 5 lug? How much lift do you have?
    IIRC the best you can do on stock suspension is 235/75/15
  17. Jul 25, 2011 at 9:02 AM
    #57
    TacomaHog
    TacomaHog Well-Known Member
    Tom
    New York
    2009 TRD OFF ROAD
    After market stereo with GPS and 10in subs and amp
    i just got a 3 in procomp on my 09 trd off road and am very satisfied with the clearence that alone gave me. i am planning on upgrading my tires from the stock 265/70r/16 to 285s but the guy at the shop said i needed skinnier tires to keep from rubbing the control arms. im really wanting that aggrsive look and dont want to go skinnier but dont want to rub. i also asked him about spacers but he said he didnt recomend because of unwanted stress on the lugs and what not. all im asking if that is true or not and if so is there another alternative i could use to keep from getting skinnier tires. i am going to be using the stock 16s.
  18. Jul 25, 2011 at 9:13 AM
    #58
    98tacoma27
    Ben
    Not Beech Creek
    It's either spacers or aftermarket wheels with a backspacing of 4.5" or less. FWIW, a lot of members have or do run spacers without issue.
  19. Jul 25, 2011 at 9:19 AM
    #59
    TacomaHog
    Tom
    New York
    2009 TRD OFF ROAD
    @ 98tacoma27, so i either get aftermarket rims. which isnt an issue cuz i was planning on just buying a set of used toco rims and powder coating them. or spacers. probly just go with aftermarket rims. thanks for your input
  20. Jul 25, 2011 at 9:21 AM
    #60
    98tacoma27
    Ben
    Not Beech Creek
    :thumbsup:
    That's what most members do; aftermarket rims.
