Wheel Backspacing and Offset Info
Discussion in 'Wheels & Tires' started by tcBob, Jul 17, 2010.
  1. Apr 29, 2014 at 8:18 PM
    #581
    ChuckLee
    ChuckLee Well-Known Member
    Richmond, VA
    06 SR5 4x4 DC
    04 single cab 4x4
    (3-4" skyjacker lift, stock uca)
    17x8.5 mb tko's with -6 offset.
    285/70/17's
    I JUST ORDERED THESE TODAY, thought I read all there was to read on sizing (basically 4.5" backspace and you r safe), then found a thread that said this setup won't work because I need 4.25" or even 4" back spacing.
    If anyone knows for sure please chime in so I can cancel order before delivery.
  2. May 13, 2014 at 11:05 AM
    #582
    rtgreene10
    rtgreene10 Well-Known Member
    Fl cracker
    4x4 turd
    hope this helps some
  3. May 19, 2014 at 2:39 PM
    #583
    Jon147
    Jon147 Well-Known Member
    Jon
    Orange County
    '13 TRD Sport-Vader
    Bilstein 5100 RHA/OME 887s/LR UCA's, 5100's in rear w/ Wheelers 3 leaf progressives, wrinkle black/silver TRD front skid plate, emblem removal, LED third brake light, remove/replace TRD Sport stickers with custom black TRD stickers, tail gate lock mod, BLHM & BLTM, VLED 430lm DTRLs, VLED LED rear turn signals, LED headlights from BadAssLED's, black mesh grill, AVEC LED light bar behind grill, AVEC LED light bar lower valance, 91' Cadillac Deville Horns, Hood Scoop LED from C4 Fabrication, Procomp 5001's Satin Black, FlowMaster Dual Exhaust American Thunder, Blue Sea Aux Fuse panel, AVEC 12" ultra slim light bar in bed, Undercover Flex bed cover
    Procomp 5001
    Wheel Size: 17x9
    6 on 5.5 Bolt Pattern
    Offset: 6.6
    Backspace: 4.75
    Max Load: 3420
    I have 265/70/17's and 5100's up front set at .85
    Any issues with getting these wheels?
  4. May 26, 2014 at 8:14 PM
    #584
    Willcory
    Willcory Well-Known Member
    San Antonio TX
    2013 Black Tacoma 4x4
    My question is I found a set of these wheels for a decent price and I want that look with the tire sticking out a lil bit without using spacers. Can I use a 285 with the 10" wheel??? I see guys running the 20x12 version with the -44mm offset and they dont seem to have any problems.
    wheel: 18x10 moto metal 962
    Offset -24mm
    backspacing - 4.56
    tire 285/65/18 open county or trail grappler
  5. Jun 20, 2014 at 1:59 PM
    #585
    Z E R 0
    Z E R 0 Well-Known Member
    California
    02 Tacoma 4x4
    Hello,
    I am lifting NY tacoma with the Maxtrac, 4" kit.. I want to run 285/75/16 BFg ta ko, but I am not sure which wheel to get, like what kind of backspacing, offset do you guys recommend. Wheels that will not rub anything.. Please help to
  6. Jun 27, 2014 at 6:47 PM
    #586
    bryanbyers28
    bryanbyers28 Well-Known Member
    Bryan
    Woodstock, GA
    2013 Black Tacoma 4x4 TRD Off-Road
    WeatherTech floor liners LED Map, dome, and license plate lighting Home made console organizer 30" LED Light Bar in lower grill Toyota Bed Mat
    Im trying to decide on wheels for my 2013 Tacoma TRD Off-road. Im going with a 4" lift running on 285/70/17s tires.
    My question what size wheels should I get?
    I know that I am getting a 17" diameter wheel what width should I get 8.5" or 9".
    I know what the offset and backspacing are but i do not know how to figure out which wheel size i should get according to the width of the wheel.
    SOOOOOO which ones
    17x8.5 with 6 on 5.5 Bolt Pattern with 0 offset
    OR
    17x9 with 6 on 5.5 Bolt Pattern with -12 offset and 4.5 backspacing
  7. Jun 28, 2014 at 6:46 AM
    #587
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    8.5" wide wheel is ideal for a 285/70r17, and with the 0 offset, the wheels will only stick out maybe 1/2". A 9" wide with a -12 offset will stick out 1/2~3/4" more than that.
  8. Jun 28, 2014 at 12:56 PM
    #588
    bryanbyers28
    Bryan
    Woodstock, GA
    thanks for the help!!! now I can buy wheels!!!:dancingbacon:
  9. Jul 2, 2014 at 8:09 AM
    #589
    lucky53s
    lucky53s New Member
    '12 Prerunner
    Well, I read the first 20 pages of this before posting but it seems that a lot is dependent on the actual wheels and tires chosen so I'm going to ask and pray for someone nice to respond.
    I'm doing a favor for my brother in law to help him figure out what he can put on his stock '12 Prerunner. I have a Tundra so I have never researched Tacoma stuff before today but he doesn't understand and asked me for help.
    He wants the biggest tires he can put on stock. I'm recommending 265/70/17 or 265/65/18. I told him the Toyo Open Country AT/2s were good. From my research, I would probably go with those. I have Cooper AT3s on my truck because I got a better price though.
    Next come wheels. He loves my Fuel Hostages and lives far enough away that I don't care if he copies me.
    The Hostage comes in 17x8.5, 17x9 and 18x9. The AT/2 is good up to 9" or 9.5" width depending on which he chooses. Now comes the question that I can't figure out. How much backspace does he need? Ideally, he wants no rubbing.
    Here are my options:
    265/70/17 are rated up to 9", 265/65/17 are rated up to 9.5"
    17x8.5 with 5.25 BS (+14 offset) or 5.75 BS (+25 offset)
    17x9 with 4.5 BS (-12 offset) or 5 BS (+1 offset)
    265/65/18 are rated up to 9.5"
    18x9 with 4.5 BS (-12 offset), 5 BS (+1 offset) or 5.75 BS (+20 offset)
    The ideal goal is no rubbing on 2012 stock height Prerunner without the tires sticking out very far past the fender. I do have a heat gun and will be happy to massage his fender liners if necessary. I had to do that on my Tundra. I don't want to trim body mounts or and other metal though.
    EDIT: I found time to do some more research and I think going with any of these combinations that have a 4.5" BS should be okay. I will leave it up to him if he wants the 17 or 18. I'd go 17 because I like more rubber and less wheel. I have 18s on my Tundra and love it but won't post it here in respect to the forum. Still very open to suggestions but everything I've read says 265/70/17 or 265/65/18 will fit with 4.5" BS.
  10. Jul 7, 2014 at 9:21 AM
    #590
    gpblitz
    gpblitz Member
    Howie
    Minnesota
    07 Tacoma
    I lifted my Taco 1 1/2" . I plan on using ATX wheels 17 x 8 with 0 off set and 4.45 back space with a 265 65 17 tire . Will I have any rubbing problems or my tires sticking out my fender wells ? Any viberation problems due to the lift?
  11. Jul 7, 2014 at 9:46 AM
    #591
    replica9000
    2019 T4R ORP
    That tire size comes stock on 4x4 models with 17" rims. With the 0 offset, the edge of the tire should be roughly flush with the edge of the fender flare.
    As far as the vibrations, each truck is different. You could put the same lift on 2 of the same truck. One might have vibrations, while the other doesn't, or might have them at different speeds.
  12. Jul 7, 2014 at 10:35 AM
    #592
    gpblitz
    gpblitz Member
    Howie
    Minnesota
    07 Tacoma
    What would be better ? I'm wanting to keep the tires inside the wheel wells yet no rubbing on a tight turn.
  13. Jul 9, 2014 at 10:32 AM
    #593
    lucky53s
    lucky53s New Member
    '12 Prerunner
    Didn't get any help on this but thought I would try again and add on what I heard from Rimzoneonline.
    I was told 265/70/17 would fit. The Toyo AT2 fits up to 9 in wheel. He said to go with 17x9 with +18 offset and I would have no issues. He said anything from about +10 to +20 would be good.
    Opinions? Personal experience?
  14. Jul 13, 2014 at 10:01 PM
    #594
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    I just ordered my wheels! 17x8.5" with a +14 offset 5.25" backspace
    This will move my stock wheel location just a hair over 1 full inch outward
    Im gonna run stock tire size 265/65/17
    If I were you get the black hostage 17x8.5 +14 offset 5.25" backspace
    The hostage wheels look sweet on the Tacoma
    Trust me they wont stick out,but gives you just a slightly wider stance
    If you want you can also run 265/70/17 with NO issues
    Also great thing about that wheel....its hub centric to your Tacoma
  15. Aug 1, 2014 at 7:04 PM
    #595
    GATORTACO92
    GATORTACO92 Well-Known Member
    Alex
    Hoover, Al
    2004 F-350 6.0 King Ranch
    2004 F-350...uh lots of motor work to go fast...er. Way to much to list. 2001: 3" leveling kit, ARB bumper, lightforce 240 blitz, 35" KM2s. SOLD 2008: OME 886s 90000 with dakars, LR UCAs, 5% tint, Satashi. SOLD 2015: Flooded and Gone
  16. Aug 5, 2014 at 11:02 PM
    #596
    ProPhaze777
    ProPhaze777 Well-Known Member
    Yakima,wa
    '14 trd offroad black
    Would this wheel work with 285/75r16 with a 3" lift?
    Style: Worx
    Bolt Pattern: 6x5.5
    Offset: 10
    Finish: Black
    Backspacing: 4.89
    Vehicle: Lifted Toyota Tacoma
    Hub bore: 106.1
  17. Aug 6, 2014 at 5:46 AM
    #597
    ProPhaze777
    Yakima,wa
    Bump for confirmation from a yota master
  18. Aug 6, 2014 at 6:02 PM
    #598
    ProPhaze777
    Yakima,wa
    Srs guys, just need confirmation as I believe they will but don't want to be fuked
  19. Aug 24, 2014 at 7:58 PM
    #599
    darkfader
    darkfader Will this fit without rubbing?
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    i hate to ask, but i need confirmation before i drop a ton of cash on wheels and tires. i've read this thread a half dozen times and i just don't know what to do.
    i want to get this:
    18x9 wheel
    -6 offset
    4.76 BS
    6 x 5.5 bolt pattern
    106.1 bore
    and i can install 265/60-18 tires to keep the diameter the same as stock. will this rub fenders or suspension on my stock '13 DCSB Sport? can i even mount a 265/60 on a 9 inch rim? i'm so confused.
    link to comparison: thanks in advance for your help!
  20. Aug 25, 2014 at 7:39 AM
    #600
    darkfader
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    and just to add to my confusion, willtheyfit.com says the 18x9 -6 wheel will stick out 55.1mm more than what i have now, and rimsntires.com says they will stick out 36mm more. i think 55 is too much for the look i want but 36 would be just right. please help me, thanks!
    will they fit: rimsntires:
    http://www.rimsntires.com/specspro.jsp
