Wheel Backspacing and Offset Info
Discussion in 'Wheels & Tires' started by tcBob, Jul 17, 2010.
  1. Aug 29, 2014 at 11:03 AM
    #601
    darkfader
    darkfader Will this fit without rubbing?
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    bump
    maybe someone can tell me the difference in poke between these two rims and stock:
    17x8 0 offset
    and
    18x9 -6 offset
    thanks for any help guys, i just don't want to make the wrong decision on such a pricey purchase. thanks again!
  2. Sep 18, 2014 at 9:34 AM
    #602
    teamcurtis
    teamcurtis Well-Known Member
    Curtis
    San Diego
    2015 DC 4x4 Super white
    285/75/16, snugtop xtravision, pop-lock
    took me forever and a million button strikes on the calculator to realize that wheel size isn't the same as rim width. A wheel that is labeled 16x8 is really 9" wide (usually)
    Meaning a 8" rim with 0 offset isn't 4" backspacing.
    examples
    <li id="frontOffset137" style="display: block;">Offset: 1mm<li id="frontBackSpacing137" style="display: block;">Backspacing: 5.039"Bolt Pattern: 6-139
    Rec. Tire Size: 265/50-20
    Weight: 34.65lbs.
    Finish: Black w/Spot Milling
    <li id="frontConstruction137" style="display: block;">Construction: 1pc. Gravity Cast<li id="frontFinishWar137" style="display: block;">Finish Warranty: 1 Year<li id="frontManufactured137" style="display: block;">Manufactured in China
    and
    Front and Rear
  3. Sep 18, 2014 at 9:38 AM
    #603
    teamcurtis
    Curtis
    San Diego
    usually (there are exceptions which is why you cant just do the math yourself)
    17x8 is 9" wide.
    Divide 9" in half. This is dead center of the wheel. 4.5.
    Add the offset +(0)
    Back spacing = 4.5
    18x9 is 10" wide
    divide 10 in half =5
    add the offset -10mm (.39")
    back spacing = 4.61
  4. Sep 25, 2014 at 6:55 PM
    #604
    BeBeep
    BeBeep Still Plays With Cars, Trucks, Bikes & Guns
    Bob
    NRH, TX
    15 DCSB TRD Sport PreRunner
    TRD Exhaust, Gentex Mirror w/ Homelink, Autodim, Temp & Compass, Pop & Lock Tailgate Lock, Toyota Bedmat, Underhood LED Lighting Toytec Ultimate 3" lift w/3 Leaf Progressive Rear Springs (overload spring removed), Hypertech Speedo Calibrator
    I have looked at so many threads over the last few days my eyes hurt but I believe I finally got the info straight. I plan to install the Complete Old Man Emu Suspension System with NitroCharger Sport Shocks which I believe will give me about 3" of lift.
    If I go with a 17X9 wheel -12 offset (stick out 1/2" ish) and 4.5 BS I can mount 285/70-17 tires. Is that correct?
    That said, what will I need to do/trim/remove to not have rubbing issues?
    I would appreciate any info anyone could provide related to my questions.
    Thank You,
    Bob
  5. Sep 26, 2014 at 7:40 AM
    #605
    darkfader
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    thank you teamcurtis! i believe that cleared up some of my confusion.
    i'm pretty sure i have also decided on a 17x9 -12offset wheel. although i think i will have less than 3" of lift so i'm also curious to the answer to this. but from the research, it sounds like you might need to chop the cab mounts for the 285, or you might not have to. lol it seems like some people need to, and some don't. i may play it safe and just go with a smaller tire than the 285. i'd rather not chop cab mounts, but i don't have a problem removing mudflaps or a little minor trimming of fender flares. information overload!
  6. Sep 26, 2014 at 1:56 PM
    #606
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    Have the same wheel numbers with 285's...minor trimming. no CMC...
  7. Sep 26, 2014 at 5:26 PM
    #607
    darkfader
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    awesome thank you!
  8. Oct 13, 2014 at 8:46 AM
    #608
    AllTerrainMonster
    AllTerrainMonster Well-Known Member
    South Korea
    2006 2.7L Base 2WD
    so does a negative or a positive offset make the wheel stick out of the fender? i'm looking at 15 inch wheels with a +38mm offset, and am wondering if i will need wheel spacers to get the aggressive 4x4 stance...
  9. Oct 13, 2014 at 9:11 AM
    #609
    teamcurtis
    Curtis
    San Diego
    Negative moves the tire outboard
  10. Oct 13, 2014 at 9:12 AM
    #610
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    +38 will move your wheel in 1.5", which may cause contact with the suspension. Also, 15" wheels won't fit on a 2nd gen Tacoma, most 16" wheels do.
  11. Oct 13, 2014 at 9:12 AM
    #611
    teamcurtis
    Curtis
    San Diego
    what is the width?
  12. Oct 14, 2014 at 4:58 AM
    #612
    AllTerrainMonster
    South Korea
    2006 2.7L Base 2WD
    Well i have the base model, 5-lug tacoma and was wondering because i like the look of the tires when they are slightly out of the wheel wells
  13. Nov 13, 2014 at 8:35 AM
    #613
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
    This chart above and this formula:
    backspacing=(wheel width)/2 + offset+(about 0.25 inches)
    do not agree.
    For example: 10" wheel/2 + zero offset + .25" =5.25". The chart shows 5.5".
    Another example: 8" wheel with a 19mm offsit: first 19mm offsit/25.4 =.748 inches. 8" wheel/2 + offsit of .75 + .25 = 5". The chart shows 5.25".
    I made an Excel table to run all the calculations. All the measurement are .25 inches off.
    In the formula should the "about .25 inches" be changed to "about .5 inches" or is the chart off by one column?
  14. Nov 13, 2014 at 4:54 PM
    #614
    AllTerrainMonster
    South Korea
    2006 2.7L Base 2WD
    Pro Comp 7031's, will the 15x8's fit on the 5-lug tacoma? 3.75 backspacing and -19mm offset
  15. Nov 14, 2014 at 12:19 PM
    #615
    teamcurtis
    Curtis
    San Diego
    Did you account for the rim width vs the actual wheel width?
    a 17x8.5 wheel is really 9.5 wide. (inner rim lip for tire vs outer most part of the wheel for clearance)
  16. Nov 14, 2014 at 2:10 PM
    #616
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Yeah, This ^^^^^
    Drew up some diagrams for guys like me and you. Posted 'em earlier in this thread. Link Below
    Visual Backspace Explaination - Simple Drawings of 3 wheels w/ different backspacing
    Now has 5 different wheels
    Needed to grasp the concept myself and this was the best way for me.
    Wheel width is measured INSIDE the rim's bead flanges.
    Lay wheel flat on back and it measures 1" more to the top than rated width.
    8" Wheel is measurement inside flanges, but it 9" from outside to outside of flanges.
    Confused yet? Look at the Pics, should clear it up for ya
    EDIT: Offset measured from center of width to mounting surface
    Backspacing measured from mounting surface to outer edge of back (vehicle side) flange
    Though they are related, they are two different measurements,
    with the mounting surface, being the only common denominator.
    FWIW
    EDIT EDIT: When you get the spreadsheet straightened out, maybe you could post it for the rest of us.
    Or for just me :D. I for one would be interested is seeing it.
    Good Luck
    CC
  17. Nov 14, 2014 at 2:59 PM
    #617
    Cape Codder
    Jack
    :rofl: Nevermind :rofl:
    Just went to the thread I linked for you and noticed you were the 6th post in it. (2012/04/21)
    Guess you've seen it.
    CC
  18. Nov 24, 2014 at 4:44 PM
    #618
    adamh1977
    adamh1977 Well-Known Member
    arkansas
    trd sport 4x4
    any time fog,tinted windows to 5% ,plasti dipped gun metal gray,toytec 5100's eibach coils ,led map and dome lights
    how do you find out what your back spacing is on some stock 17'' sport wheels cause im wanting to put some 285 70 17 on them but not sure if i need wheel spacers or just get new wheels and tires.
    cause i really like my stock sport wheels but not sure about wheel spacers
  19. Nov 25, 2014 at 5:41 AM
    #619
    replica9000
    2019 T4R ORP
    http://www.tacomaworld.com/forum/wheels-tires/30754-wheel-specs.html
  20. Nov 30, 2014 at 2:37 PM
    #620
    Nostunknivek
    Nostunknivek Well-Known Member
    Kevin
    Victoria, BC
    '09 TRD OR partially debadged
    Seat belt chime mod, weathertech floor liners, secondary air filter removal,
    I have a 09 TRD offroad accesscab with stock TRD OR wheels which have a 5.25" backspacing if I'm not mistaken. I am putting on 255/85/r16 toyo open country MT/s which is a 33.5" tall and 10.2" wide tire. I will be installing my full OME lift with 886 (planning on bumpers and armor down the road) struts up front and dakars in the rear. I will be doing Camburg Uniball UCA's at the same time which require a maximum wheel backspacing of 4.75".
    So I imagine I'm going to have an issue somewhere due to the wheel backspacing of the stock TRD OR wheel. Where am I going to rub? Would spidertrax wheel spacers alleviate this problem? Is my wheel going to rub on the camburg UCA's? I'm just hoping it will go together fine as I don't have much more money at this time to spend on aftermarket wheels/wheel spacers.
