Wheel Backspacing and Offset Info
Discussion in 'Wheels & Tires' started by tcBob, Jul 17, 2010.
  1. Nov 30, 2014 at 2:40 PM
    #621
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Adding wheel spacers would increase the likelyhood of a rub with the stock wheels and 255's
  2. Nov 30, 2014 at 3:02 PM
    #622
    Nostunknivek
    Nostunknivek Well-Known Member
    Kevin
    Victoria, BC
    '09 TRD OR partially debadged
    Seat belt chime mod, weathertech floor liners, secondary air filter removal,
    Is a wheel spacer basically just adding more backspacing to the rim while also increasing the scrub radius that your wheel turns by whatever thickness the spacer is? is that why i would have more fender rubbing with wheel spacers?
    Is the issue with the rim backspacing and camburg UCA's that the rim hits the uca? or why do they call for that backspacing?
  3. Dec 12, 2014 at 6:49 AM
    #623
    Uranium235
    Uranium235 Well-Known Member
    Illinois
    2015 TRD Sport
    Synthetic blinker fluid, upgraded floor mats, custom passenger.
    OK. I need help. I am shopping for wheels for a truck I haven't even taken delivery of yet. But here's my question:
    The factory TRD Sport wheels have an offset of +30mm (or about 1.2"), meaning that the mounting hub is 1.2" closer to the face of the wheel than centerline. Further, the wheel is 7.5" wide. Even further, the backspacing is 5.5". Sooooooooo, by my math, using an offset of 1.2", the mounting hub is 3.75"+1.2" from the rear of the wheel, or around 5". Backspacing is defined as the distance between the rear of the wheel and the mounting hub. So if it's 5.5", where did I go wrong?
    I am asking because I am looking at new wheels. I will be going with 265/70-17s on 17x8.5" wheels, and the wheels I am considering have offsets of either +10 or -6. Don't know which I should go with. I don't want UCA issues, but I also don't want my wheels sticking out too far.
  4. Dec 13, 2014 at 4:36 AM
    #624
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
    Plus the thickness of the wheel lip. Most of the formulas says plus .25 inches, which never adds up. It seems more like plus .5 inches always is closer.
  5. Dec 14, 2014 at 9:05 PM
    #625
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Ok, someone help me figure out if these wheels will keep my tires out of the frame.
    Tires:
    315/70/17
    Current wheels:
    17" TRD Sport wheels
    1.25" spacers
    So that's a 7.5" wide wheel with 5.5" of backspacing, correct? With the 1.25" spacer my backspacing is at 4.75".
    My thinking is that I need to push the tire further out to keep it from coming in contact with the frame. The back of the tire hits the frame behind the LCA mount.
    Wheels I'm considering
    17x9, -38mm offset, 3.5" backspacing
    So that's going to push the tire away from the frame another 1.25".
    So, what am I not seeing here? Any other issues that might come up?
  6. Dec 15, 2014 at 6:12 AM
    #626
    adamh1977
    adamh1977 Well-Known Member
    arkansas
    trd sport 4x4
    any time fog,tinted windows to 5% ,plasti dipped gun metal gray,toytec 5100's eibach coils ,led map and dome lights
    I'm running 265 70 17 on stock sport wheels and don't have a problem with stock supension or lift that I have now no rubbing or anything
  7. Dec 15, 2014 at 9:22 AM
    #627
    teamcurtis
    teamcurtis Well-Known Member
    Curtis
    San Diego
    2015 DC 4x4 Super white
    285/75/16, snugtop xtravision, pop-lock
    well youll clear the UCA, then prob rub the fender...
    315 is a lot of meat to fit under there
  8. Dec 28, 2014 at 9:01 PM
    #628
    Griff 99 TRD
    Griff 99 TRD Well-Known Member
    '99 Tacoma TRD Extended Cab 4x4
    K&N FIPK OME w/883s Air Raid TBS Trailgear Bumper Smoked Lights Mean Green Alternator JL Audio Sub/Amp HAT Speakers Pioneer Head Unit ARB bumper XD 128 16x8 wheels Odyssey battery BAMF Sliders Camburg UCAs
    I'd like to run 33x12.50 on an (appx) 2" OME suspension lift. What size wheel do you guys recommend? I originally got some eagle alloys 15x10 with 3.75" backspacing and -46mm offset to hold my 32x10.50 tires, buy they are rubbing. Any input would be awesome!!
  9. Jan 9, 2015 at 11:12 AM
    #629
    GreatCanadian
    GreatCanadian Well-Known Member
    Newfoundland
    SR5 4X4 V6
    Hi folks. One of the posts above states that "hopefully this will cut down on the number of will it fit questions". Well, sorry, here's a "will it fit" question. Been looking around but can't determine. I know the bold pattern is fine so I'll add the other specs and see what you folks have to say.
    My truck is a 2014 4 door Tacoma SR5. My tires are 245-75-16. I am looking at a used set of 16 inch rims off a 2002 Pathfinder. According to the web, the Center bore for my truck is 106.1, and the pathfinder is 110. Is that a concern?
    His rims are 7X16 ET10 or ET0 (is that the offset?). Will that work? All that I'm sure of is that the bolt pattern is correct. Thanks for any help you folks can offer.
    GC
  10. Jan 9, 2015 at 11:20 AM
    #630
    Ravic
    Ravic Artisan in DIY mods
    TP
    North Augusta, SC
    2013 DCSBMGM OR 4x4
    DIY Mods-BHLM, Plastidip Rims (now spares), color matched Grille, Plate Bumper, bilstein set @2.5 (self installed no spring compressor), 2" Rough Country AAL, LR UCAs. Non DIY- 285/75r16 duratracts, procomp 7031.
    Your going to need to do some research and see if those pathfinder wheels can be used as lug centric, if so they should fit... granted the backspacing is 5-4.5 BS..
  11. Jan 9, 2015 at 12:08 PM
    #631
    GreatCanadian
    Newfoundland
    SR5 4X4 V6
    Thanks Ravic, I've moved the question to the 2nd generation forum where hopefully it will get more traffic. Again, thanks.
  12. Jan 23, 2015 at 12:31 PM
    #632
    Tcollins83
    Tcollins83 Well-Known Member
    Trevor
    Ocala,fl
    '13 TRD Off-road dbl cab
    Window tint, k&n filter, painted grill.
    So confused on backspacing... I'm thinking of getting an rcd lift. I'd like to run 33x12.50's on a 17x9 procomp 7032 rim. It claims it has 4.75 bs. I don't know if this will fit or not. Please help. I've scrolled thru this thread and still disn't get an answer.
  13. Jan 23, 2015 at 9:07 PM
    #633
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Depending on how aggresive the tires are, that's cutting it kind of close.
  14. Feb 4, 2015 at 8:47 AM
    #634
    Dirty G
    Dirty G Active Member
    Colorado Springs
    DC TRD Off Road
    TOYTEC coils, Rear TSB
    Does anyone know if 16x7 wheels with 4 5/8 back spacing on a 2nd Gen fit a 285x75 with out spacers?
    I want to run 4Runner 3rd Gen six spoke wheels on my 2011 DCSB.
  15. Feb 5, 2015 at 7:49 PM
    #635
    NosiBaLasi
    NosiBaLasi RESULTS, not excuses
    Jones
    Home of 1st Marine Expeditionary Force
    IG: overlandhd & tacoma_2gen_hq
    All in "My Build" page
    The wheels i like are the Eagle 023, 17x9, 4.75 BS and -5 offset. But tire shop says it will rub on stock UCA's coz of the -5 offset. Is this true? I have a 3" lift. Thanks for the help
  16. Feb 8, 2015 at 5:56 PM
    #636
    littlecee1
    littlecee1 Member
    tacoma 06
    2" front spacers,1" add a leaf and 1 1/4 rear blocks.
    Just checking on some specs on some wheels. I want to install 20"x10" rims with 33" tires on my 2014 tss . Want to make sure the fit. Don't know what off set the factory wheels are , I think they are 7.5 inch wide. I believe it is 4.75 back space but not sure. If I understand right anything with 4.75 bs or smaller should clear the uca.
  17. Feb 10, 2015 at 8:18 AM
    #637
    littlecee1
    littlecee1 Member
    tacoma 06
    K,talked to the dealer and they said 20x10 with -19 won't fit. Still unsure if I want 18" rims or 20" rims. I just want them to stick out maybe 1" to 2" from the fender. I am planning on getting bush wacker fender flares installed later. Also on getting 33'' tires installed. Plan on spending some money and want to make sure I get what I want and not something I was just sold. Thanks
  18. Mar 3, 2015 at 7:21 AM
    #638
    8th sin
    8th sin Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    Looking to fit 285/70/17's on 17x8.5 wheels with 4.75 backspacing until my lift parts (icon stage 3) arrive later this month, highway driving only until then. 2015 DCLB Sport 4x4.
    Will i rub on stock suspension or should I wait until I'm lifted? I know I'll likely have to do some cutting at some point to clear 285's when fully stuffed, but I'm getting impatient staring at these wheels and tires unmounted in my garage. I'm ok with some rubbing in the meantime so long as it's not on anything that's going to instantly shred the tire.
  19. Apr 9, 2015 at 7:29 PM
    #639
    smallstaco
    smallstaco Member
    fallbrook, ca
    2007 tacoma prerunner
    Pro comp 3" lift, Pro comp 33" mt 2's
    Hey everyone, I have a 2007 regular cab with a 3" lift, 1 1/2" spacers on the front, 16x8 wheels, and 33x12.5 tires. Ive had the truck for about a year and a half and have replaced the wheel bearings multiple times (approximately 5xpassenger and 2xdriver side) so now im trying to get rid of the spacers which I was under the impression that new 16" wheels with a different offset would solve the problem of the wheel hitting the caliper without the spacers. It recently came to my attention that that wont work and I either need to go to 17s or that stock 16" toyota wheels clear the caliper for some odd reason. Does anyone have any advice on things that work, my main thing is getting rid of the spacers before I end up buying a stock in wheel bearings and not having to buy 17" wheels and all new tires.
  20. Apr 10, 2015 at 7:51 AM
    #640
    teamcurtis
    Curtis
    San Diego
    Its the offset. . measurements are measurements
    there is nothing magical about the stock wheels
