Wheel Backspacing and Offset Info
Discussion in 'Wheels & Tires' started by tcBob, Jul 17, 2010.
  1. Apr 10, 2015 at 11:20 AM
    #641
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    Magical looking :headbang:
  2. Apr 10, 2015 at 12:18 PM
    #642
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I know there's at least one set of older Tacoma 16" rims that won't fit the 2005+ Tacomas.
  3. Apr 10, 2015 at 1:29 PM
    #643
    teamcurtis
    teamcurtis Well-Known Member
    Curtis
    San Diego
    2015 DC 4x4 Super white
    285/75/16, snugtop xtravision, pop-lock
    because they have the wrong offset
  4. Apr 27, 2015 at 9:26 PM
    #644
    Italia234
    Italia234 Well-Known Member
    Nick
    Tucson
    TRD offroad
    I have searched and read 33 pages of this thread and I don't have a clue at this point . I found the largest tire I can run is a 265 70 17. But what can I run in wheels size. Method 105 17x8.5 BS 4.75? will the 8.5 fit on a 2015 TRD offroad with no lift? With the 265 70 17 or is it too wide?
  5. May 2, 2015 at 8:34 PM
    #645
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    My brain hurts right now... 17x8.5, 4.75 back spacing, 0 offset. Will that fit on a stock 2014 DCSB without rubbing or major problems?
  6. May 4, 2015 at 9:46 AM
    #646
    8th sin
    8th sin Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    It depends on the tire you're running, and a number of other factors. The only truth is that if you want to maintain 100% of your factory suspension travel on a wheel/tire set up that deviates from stock specs, you're going to have to trim something.
    On my 2010 I ran 275/65/17's on 17x8 @ 4.5" backspacing on stock suspension, and only lightly rubbed at full stuff and full lock. I never trimmed anything and never took the time to see what was rubbing.
    Now I run 275/75/17's on 17x8.5 @ 4.75" backspacing on a 3" lift and had to do some light plastic trimming of the fender flare wheel well liner. I'm also running aftermarket UCA's with caster at 2.4 (this does make a difference regarding rubbing). Haven't run it offroad, so not sure how it will do at full stuff but it's completely rub free on the street.
    Based on my experience, this is what would need to be trimmed in order of "distance" from the hub (if you're running less tire OD than 32.7", or more backspacing you may only have to do the first few). Most of these items are in the rear of the front wheel wells and will be contacted by the tire on the side you are turning towards:
    Mudflaps (remove them, they'll break anyway)
    Front "MPG tabs" (remove them, they're fugly)
    Bottom rear inside lip of the fender flare
    Lower part of the plastic wheel well liner
    Pinch weld (behind the wheel well liner)
    Cab mount
  7. May 11, 2015 at 11:21 AM
    #647
    TSmalls89
    TSmalls89 Technologically Advanced Redneck
    Tyler
    Merrimack NH
    2022 Tacoma TRD Offroad
    So if I am looking to run 286/75/R16 on a 2013 with a level kit (3 inch front, AAL rear), been told to look at a 16x8 6x5.5 with 5" back space and -12mm offset.... that sounds about right? Already tried 4.25" backspace and -6 offset and it wasn't enough......
  8. May 11, 2015 at 11:36 AM
    #648
    replica9000
    2019 T4R ORP
    Doesn't sound right. The offset does, but not the backspacing. With a -12mm offset, you should have closer to 4" backspacing, which is what you want. With a 5" backspacing, your wheels would be closer to the suspension.
  9. May 11, 2015 at 11:37 AM
    #649
    TSmalls89
    Tyler
    Merrimack NH
    Yeah I am currently running the stock TRD offroad rims with a 1.25inch spacer. What should I look at then for a backspace and off set?
  10. May 11, 2015 at 11:45 AM
    #650
    replica9000
    2019 T4R ORP
    Typically, your 8" rims are actually closer to 9" wide. You're basically adding 1/2" for each lip. So a 8" rim with a 0 offset will have a 4.5" BS (9 / 2 = 4.5).
    You should be safe with any rims with a 0 offset, or a negative offset. The more negative your offset, the less BS you'll have, which means the more your wheel will stick out.
    I've run 305's on a 18x9 with a 0 offset (5" BS) wheel, and still cleared the suspension.
  11. May 11, 2015 at 12:01 PM
    #651
    TSmalls89
    Tyler
    Merrimack NH
    OK, Definitely weird seeing how I tried the 16x8 with 4.25inch back space and it still grabbed the control arm. I was pissed
  12. May 11, 2015 at 12:13 PM
    #652
    replica9000
    2019 T4R ORP
    Do you have a link to the wheel you bought?
  13. May 11, 2015 at 12:18 PM
    #653
    TSmalls89
    Tyler
    Merrimack NH
    do not, but here are specs (looks like discount tire direct took down the rim)
    4 MB Wheels Razor
    16 X8 6-139.70 -6 BKMTXX
  14. May 11, 2015 at 12:35 PM
    #654
    replica9000
    2019 T4R ORP
  15. May 11, 2015 at 12:40 PM
    #655
    TSmalls89
    Tyler
    Merrimack NH
    Thats the exact same rim, but in chrome. Didn't fit. Tire grabbed the UCA and barely cleared the caliper.
  16. May 11, 2015 at 12:44 PM
    #656
    replica9000
    2019 T4R ORP
    You could measure the BS to see if you were sent the correct rims. Other than that, I'm not sure why they wouldn't fit.
  17. May 11, 2015 at 12:46 PM
    #657
    TSmalls89
    Tyler
    Merrimack NH
    Already sent the rims back, was too pissed to even think of it to be honest. Going to look at a shop that does custom rims to get the right set up. Do not need anything special, just black rims that'll get rid of the damn spacers.
  18. May 25, 2015 at 5:38 AM
    #658
    Joni
    Joni New Member
    JB
    2001 tacoma
    I have looked through some of the threads here, but can't find a listing of oem toyo rims that would have the same offset/sizing
    Like first generation tundra rims interchangeable with tacoma first generation? Maybe others that may be interchangeable highlander, fj, etc. looking to change a 2x4 older 2001 taco to a 16" rim and larger tires
  19. Jun 2, 2015 at 12:32 PM
    #659
    TacomaRaider
    TacomaRaider Well-Known Member
    TumbleWeed
    Northern California Shasta county
    2002 3.4l 4x4 Tacoma SR5 TRD
    Bilstein 5100 front and rear OME 882, OME Dakar, American Racing baja AR172 15x8, BFG KM2 32X11.50
    Anyone running American racing Baja on a first gen? I'm looking in to getting a pair. 15x8 -19mm offset and 3.75" backspacing. I just want to know how much they stick out
  20. Jun 3, 2015 at 11:57 AM
    #660
    TacomaRaider
    TumbleWeed
