Wheel Backspacing and Offset Info
Discussion in 'Wheels & Tires' started by tcBob, Jul 17, 2010.
  1. Jul 25, 2015 at 1:28 PM
    #681
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Again, I'm not knowledgeable enough to say yes or no, but it sounds to me like you'll be rubbing.
    Most who mount 285/70r16, I believe have some issues and have to do some cutting/heating.
    Ima thinkin' the 18's will, more so. Maybe that extra 1/2" lift over mine, is enough, but IDK
    Before you pull the trigger, I'd search out someone running those, to confirm.
    Even check with some that have the 16's.
    As stated above, I'm runnin' LT275/70R17 on a 17x8 wheel w/ 2.5" lift, and I'm real close.
    I'm sure I'd rub if I stuffed 'em while articulating the suspension @ full lock.
    I'd search 285/70r16 +/or 285/70r18 and see if you can confirm.
    Seems to me there are threads asking the same question.
    Good Luck
    CC
  2. Jul 25, 2015 at 3:43 PM
    #682
    crunchy11
    crunchy11 Well-Known Member
    North CA
    stock(too stock) 13 trd
    seat stains
    So icon recommends 285/70r16 for their stage 4 lift. I think I can get away with an 18" of at least I hope. Back to the search button
  3. Jul 25, 2015 at 4:38 PM
    #683
    Cape Codder
    Jack
    285 is tire width in mm, 70 is your sidewall and is 70% of your 285mm tread width 285x.70=199.5mm of Sidewall / 199.5mm=7.854307"
    7.85" + 16" + 7.85" = 31.7" Tire/16"Wheel Diameter (.5" smaller diam than mine)
    7.85" + 18" + 7.85" = 33.7" Tire/18"Wheel Diameter (1.5" larger diam than mine)
    BIG DIFFERENCE
    My Tire/Wheel Diameters are 32.2" for the A/T and 32.1" for The Blizzaks, and once again, I'm close
    Also of Note: I had them set my alignment caster (picture front wheel of a shopping cart) @ 2.5°, instead of the 3°, everyone here, recommends.
    Meaning my front wheel is more forward @ 2.5° than @ 3°.
    0° is straight up and down or perfectly plumb. Picture the front wheel of the shopping cart again.
    Each degree angles the wheel backward (shopping cart again). @ 3° I'd rub my mud Flap.
    When you start going below 2.5° Caster (toward 0°), it will effect your steering.
    Wandering on the highway, or having to pull you wheel back from lock instead of it straightening itself.
    You will NEED to understand all these figures, to understand why a tire will rub.
    Do your homework, or do it twice
    My Tires Pictured Below........
    And again, good luck
  4. Jul 29, 2015 at 8:24 PM
    #684
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Hello all, looking for some 16" D wheel steelies for my 2001. Have been looking at some Vision Wheel 84 Series D windows with 4" backspacing but it has -12mm offset, wondering if it will hit my calipers. I'm also looking at some Allied Wheels 51 series with 0mm offset. What is the preferred sizing to not only not interfere with not only the OE brakes, but in case I want to go with Tundra's in the future? I'm also looking to have a wide stance vs. having to get spacers. If this is in some other sticky I must have missed it.
  5. Jul 30, 2015 at 8:21 PM
    #685
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Thank you cape codder for the info. :thumbsup:
  6. Jul 30, 2015 at 8:41 PM
    #686
    Cape Codder
    Jack
    You're Welcome
    Always willing to share what little I know.
    Hope you're making progress
    Remember: Educate yourself
    CC
  7. Jul 30, 2015 at 9:07 PM
    #687
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Chose to get a bumper before wheels and tires... though the search for the right wheels will never be over.
  8. Aug 7, 2015 at 3:40 PM
    #688
    TSmalls89
    TSmalls89 Technologically Advanced Redneck
    Tyler
    Merrimack NH
    2022 Tacoma TRD Offroad
    So if I ran 16 X8.5 6-139.70 -25off set, would that clear the UCAs with 285/75/r16s? Or would going with a -12 offset be ok? -6 wasn't enough and I still grabbed the UCA with the tires.
  9. Aug 7, 2015 at 9:13 PM
    #689
    Toy.Yoda
    Toy.Yoda Member
    YEG, Alberta
    '15 DCLB MGM
    Revtek Lift and Level
    Ok my turn to be the rookie. Im looking to run 17x8.5 with 4.5 BS and -05 offset. If i put 285/70 on there what will rub?
  10. Aug 10, 2015 at 2:38 PM
    #690
    sbtacoma
    sbtacoma Active Member
    Santa Barbara
    06 Prerunner TRD
    K&N intake Flowmaster exhaust Bilstein 5100 front shocks - 2.5" Bilstein 5160 Rear Tacoma shocks Leaf added giving 1" Toyo Open Country AT II 265 70 R16 XD Addicts 17x9 Selling
    Im looking at XD Addicts 798 wheels. They have two different sizes, both in 17X9 rim.
    Does anyone have pics of the blacked out Addicts in the typical 4.5 BS and 12 mm offset VS the 5.71 BS and 18mm offset? One distributer stated that the 5.7 would rub the brake calipers, another disagreed?
    Looking at the 265 70 17 Toyo open country to wrap them in.
  11. Aug 28, 2015 at 7:14 PM
    #691
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Is there a thread that talks about wheel spacers? I'm trying to pick a 1.25" spacer but I'm not sure what lug centric and hub centric means and what lugs are compatible with which spacer.
    TIA
  12. Nov 17, 2015 at 7:24 AM
    #692
    MainerDave19995VZ
    MainerDave19995VZ Well-Known Member
    David
    Maine
    1999 Tacoma Extra Cab SR5 TRD 5 Speed 5VZFE
    2nd generation 16" wheels with 1.25" BORA spacers
    I'm running second gen stock wheels on my 1st gen and with 265/70/16 I rub the frame when turned all the way. Both sides but it looks like a bit more rubbing on the passenger side. I didn't realize what wheels I had when they came with the truck brand new in boxes. I took off the 15 inch 31's because they wouldn't pass inspection in Maine. After reading and posting for a few days I'm thinking of these spacers: https://www.uswheeladapters.com/shop/1-25-6x5-50-6x5-50-wheel-spacer/
    Primarily it seems like I'll be getting the wheels back to where they belong and so I am not concerned with "stress" on the wheel bearings. I understand that ideally I'd have the correct wheels or smaller tires but it's what I have and I can't undo it now. I really do like the look of the newer "stock" wheels on the first gen. Anyone familiar with these spacers and is 1.25 inches enough? It seems like it will be plenty after looking at some other first gens with same size tires on stock first gen wheels. Thanks!
  13. Nov 17, 2015 at 5:36 PM
    #693
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    I wouldnt touch those personally. Always stick with adapters/spacetrs that are both wheel and hub centric.
    MainerDave19995VZ likes this.
  14. Nov 18, 2015 at 10:15 AM
    #694
    MainerDave19995VZ
    David
    Maine
    Thanks Steveo! I thought the ones I posted on were hub centric. So I'm thinking that you found that they are not also wheel centric. Which honestly I know need to read up on! Spidertrax are wheel and hub centric then? As if I know what I'm saying!
  15. Nov 19, 2015 at 5:45 AM
    #695
    CVOTRDSPORT
    CVOTRDSPORT Well-Known Member
    2016 White Tacoma TRD Sport 4X4 Longbed
    Hey all Im new here and have read a gazillion threads on wheel size and fitment and have not found the answer Im looking for yet. Hoping someone here can give an answer so I can order a set of TRD SEMA wheels.
    To begin, I have a stock height 2016 TRD Sport DCLB, I want to simply put black TRD SEMA wheels on my stock size 265/65-17 tires. My owners manual says my 16 taco either has 7" or 8" wide rims. According to tire distributors website, my tire will fit rim sizes 7.5-9".
    What Ive found on flea bay is either 7 or 8" wheels, but what I cant determine is what offset to go with. They list 4mm, 12mm, or 15mm. I dont want to lift the truck nor add any spacers. I want to keep it as close to the stock width or stance as I can.
    Can anyone say with certainty which offset will work for what I am looking for? Thanks in advance for any help. Next item to identify is correct exterior led conversion.
  16. Nov 19, 2015 at 9:54 AM
    #696
    Turttle98
    Turttle98 Active Member
    Abel
    California
    06 trd sport dbl cab 8.5 inch lift diamond whit
    8.5" lift kit with fox coilovers and double rear 2.5 fox shocks with bypass reservoirs on each side Kenwood ktv-516 indash kit Kenwood door speaker Kenwood tweeters 10" kenwood sub
    I have a question I'm currently running fuel deep hostages 20x12 with a -44 offset on 35s and I wanted to drop down to 17s or 18s methods but was wondering if the difference in offset would cause a problem with rubbing and if it does what size wheel spacers would I have to run for it not to rub. Really appreciate it.
  17. Dec 10, 2015 at 11:17 AM
    #697
    Taco_Kid
    Taco_Kid Well-Known Member
    if they are the mag style lugs then usually are hub centric. acorn style are usually rim centric.
    right now i am trying to determine if moving off of my 16x8's (i forget back spacing) to level-8's striker-6 16x8.5's with 4.25" backspace with my 285/75 tires if i'll have rub issue. right now with lift, uca's, and bushwacker flares i dont really rub that much, have not done the frame alteration yet either.
  18. Jan 1, 2016 at 7:21 PM
    #698
    2016TacomaDCLB
    2016TacomaDCLB Active Member
    2016 DCSB TRD Off-Road
    I have read so many posts in this thread and my brain hurts. So much good information here, but I'm not positive I am comprehending it.
    Let me explain my situation and hopefully someone can help me understand what to expect.
    Tires are 285/70/17's
    I own a set of TRD Pro wheels that are 7" wide with a positive 11mm offset. I am interested in a set of Method wheels that are 8.5" wide 0 offset.
    What will change with the new wheels? With a 0 offset, would the tread be 11mm closer to the inner wheel well? Could I go from not rubbing with the 11mm positive offset to rubbing with the 0 offset?
    Any input would be appreciated.
  19. Jan 2, 2016 at 6:20 AM
    #699
    twogiraffe
    twogiraffe Well-Known Member
    Las Vegas, NV
    2016 Double Cab Longbed Offroad Inferno
    * AllPro LOLA 2.0 with expedition rear leaf springs * Stealth Custom Series F5. 17x8.5 Gunmetal * BFGoodrich TA KO2 285/70/17 * SnugTop XtraVision
    According to this illustration, having a negative offset should put your tires farther out away from the wheel well. You will have less backspace with negative offset - making the wheel stick out more.
    http://cdn1.bigcommerce.com/server4000/366a8/product_images/uploaded_images/rimoffset.jpg
    Your new wheels are 1.5" wider with 0mm offset. So it is 0.75" (19mm) wider on the inside and outside of the center line.
    The added width to the insde is more than difference in offset. So inside rim of the new wheel will be 8mm closer to the wheel well than the old wheel.
    At least that's how I understand it based on the graph.
  20. Jan 4, 2016 at 4:34 PM
    #700
    EvilElf
    EvilElf Patiently waiting, plotting my build
    Ohio
    2009 Toyota Tacoma 4DR LB
    Stock
    Will these fit?...
    I have a 2009 Tacoma 4 door long bed...
    Wheels... bolt pattern 6x139.7 [6x5.5"] -44mm offset. 108.1Center Bore. 3.75 backspace
    I know the bolt pattern is going to.
    The center bore shouldn't be a big deal because I can just buy a hub ring kit.
    But the offset and backspace worrie me. I don't plan on doing my lift for a few months and I don't want to buy them and waste the money if they won't work.
