Wheel Backspacing and Offset Info
Discussion in 'Wheels & Tires' started by tcBob, Jul 17, 2010.
  1. Mar 19, 2017 at 7:40 PM
    #801
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    The truck in your avatar is a 16x7 ET30; 5.18" backspacing
    SoCOTaco[QUOTED] likes this.
  2. Mar 19, 2017 at 7:42 PM
    #802
    SoCOTaco
    SoCOTaco Well-Known Moron
    Mitchell
    Lakewood, CO
    2012 Tacoma TRD Off Road 4X4
    GFC, Fox 2.0's w/ Dakars, SCS BR6's, Fridge w/ Beer
    Awesome, thanks! They're just stock wheels with a powder coat.
  3. Mar 21, 2017 at 9:05 AM
    #803
    RedTRDBaja
    RedTRDBaja Member
    2013 Red Tacoma TRD Baja
    I have the Alloy TRD wheels right now that come stock on my Baja that have offset of 10, wanted to get different TRD wheels that have an offset of 15. Is there a fitment problem with this or would it work just fine without having to buy anything?
  4. Mar 21, 2017 at 11:11 AM
    #804
    splitbolt
    NW Arkansas
    As long as the rims are the same width, you will only lose 5mm of backspace. This will move your wheel/tire 5mm to the inside.
  5. Mar 21, 2017 at 11:32 AM
    #805
    RedTRDBaja
    RedTRDBaja Member
    Do you think that i would have rubbing problems if i moved to a negative offset wheel? Thats with the stock suspension that comes with the baja, the bilstein suspension
  6. Mar 21, 2017 at 12:21 PM
    #806
    splitbolt
    NW Arkansas
    What size tire are you going with?
  7. Mar 21, 2017 at 12:36 PM
    #807
    RedTRDBaja
    RedTRDBaja Member
    Was looking at going with a 0 off set or a -12, thats really all i can find. That from my 10mm offsets
  8. Mar 21, 2017 at 2:05 PM
    #808
    splitbolt
    NW Arkansas
    What rim width?
    What tire size?
  9. Mar 21, 2017 at 2:12 PM
    #809
    RedTRDBaja
    RedTRDBaja Member
    Looking at something like a 18x10 or 18x9 with 275/65r18
  10. Mar 21, 2017 at 3:13 PM
    #810
    2BeersPlease
    2BeersPlease Well-Known Member
  11. Mar 21, 2017 at 3:58 PM
    #811
    splitbolt
    NW Arkansas
    A 9" with -12 offset will have 4.5" of backspace; a 10" with -12 offset will have 5" of backspace. Your current rims have 4.5" of backspace. If you go with a 10", you would need -36 offset to get 4.5" of backspace.
    So, if you go with a 9" wide/-12 offset and 275/65/18s, the rim will sit 41mm/1.61" further out the tire will sit 27mm/1.06" further out. Tire diameter increases 2", increasing tire radius 1". Between the tire sticking out and clearance radius increase, you might run into interference on the cabmount.
    Scrub will increase by 16mm/0.63".
    For that tire size, I'd recommend a 8" wide/0 offset/4.5" backspace. Compared to stock, it would only sit about a 5/8"" further out. It may or may not make a difference on the cabmount. The increase in positive scrub would be significantly reduced to only 4mm/0.16".
    I'd recommend the 9" wide/-12 offset/4.5" backspace if you went to a 275/70/18.
    Compared to stock; your scrub radius would be unchanged, tire radius goes up another 1/2" and only protrudes about 5/8" outward.
    Couple more calculators you can play with.
    303tacoma likes this.
  12. Mar 21, 2017 at 4:38 PM
    #812
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    @splitbolt whats your breakdown on these?
    I'm running 17x8 4.5 B/S 265/70/17
    Going to a 17x8.5 -10 offset
    Thinking of either 255/80/17 or
    265/70/17 tire size
  13. Mar 21, 2017 at 7:35 PM
    #813
    splitbolt
    NW Arkansas
    Are you lifted?
    Do you need more backspace clearance.
    A 17x8.5 -10 is 4.25" backspace.
    My approach is from the stock suspension and wheel/tire dimensions; paying attention to large changes in scrub radius.
    Both tire choices, with that wheel width, will add about 1-3/8"" of positive scrub over stock.
    But...you can afford to add .25" of positive scrub for every 1" of suspension and/or tire lift.
    Now, if you had a 3" lift and 255/80s that would allow you to run with 1" of added positive scrub over stock. Then being 1-3/8"" over stock is no big deal. You're actually only have 3/8" of added positive scrub.
    A 17x8.5 0 offset would be ideal then...but then that's 4.75" BS...
  14. Mar 22, 2017 at 3:14 AM
    #814
    303tacoma
    Rebecca
    Yes I'm lifted close to 3"
    Light racing UCAs
    Found a great deal on the SCS SR8 17x8.5 -10 offset 4.3 back space
    Was just debating tire size between the 255/80or265/70
    Thanks
  15. Mar 22, 2017 at 4:37 AM
    #815
    splitbolt
    NW Arkansas
    The 265/70 scrub is 1.5" over stock suspension or about 3/4" more than your lifted suspension.
    Of the two, based on scrub alone, I'd lean towards the 255/80. Being 33s, high protrusion, and having used ucas to regain castor, it will probably put you into cabmount territory.
    303tacoma[QUOTED] likes this.
  16. Mar 22, 2017 at 12:35 PM
    #816
    __Moo
    __Moo Member
    Moses
    2016 Tacoma TRD 4x4 off-road
    Icon stage 4 Scs ray 10
    Will 17x9 -38 3.5 back space offset fit the third gen Tacoma's? Planning on running 295/70/17
  17. Mar 22, 2017 at 12:45 PM
    #817
    2BeersPlease
    Throw your specs or here and see what you get. Very helpful tools.
  18. Mar 23, 2017 at 4:15 PM
    #818
    beachingtaco
    beachingtaco "We have assumed control"
    Long Island, new york
    2012 DCLB trd sport
    westin nerf bars, ARE in-channel visors, Wet Okole's, mobtown tailgate skin, Tail Gate theft mod
    I'm not sure what the stock sport rim size is but want to go with 17x9's with -12mm offset and 4.527" back spacing....Tires will be 265/70's and will have a 1.75" or 2.75" lift....Will these fit without wheel spacers?
  19. Mar 24, 2017 at 10:35 AM
    #819
    tacoRenner
    tacoRenner Well-Known Member
    Sacramento, CA
    '11 Tacoma CrewCab TRD off-road
    Need some help with these rims guys. Never been good at math lol.
    https://www.tirerack.com/wheels/Whe...coma+Double+Cab&autoYear=2011&autoModClar=4wd
    01mm offset?? no backspace information. Anyone know how these would work/look on a 2nd gen with a 2.5" lift on 285/70/17's. Eventually wanna go over to a full icon kit, they recommend a rim with 5" backspacing. I can't even find a rim with a 5" backspace, even the icon rims only have 4.5". I'm scratching my head, don't wanna buy rims flat as pancakes lol. Any help would be appreciated. thanks
  20. Mar 24, 2017 at 4:49 PM
    #820
    splitbolt
    NW Arkansas
    Those are 8.5" wide/+01mm offset.
    To find backspace, add 1" to the rim width. This accounts for flange thickness and gets you the outside wheel width, which backspace is determined.
    So, 9.5"...
    Offset is the measurement from center of the wheel to hub flange.
    Positive offset is outward of center.
    Negative offset is inward of center.
    Moving inward yields less backspace.
    Moving it outward yields more backspace.
    So...
    Center of (8.5+1)/2=4.75
    4.75"+1mm=4.79" backspace.
    When a suspension requires a certain backspace, it's the maximum.
    You should be good to go if they're calling for 5".
    tacoRenner[QUOTED] and oilslick like this.
