Wheel Backspacing and Offset Info
Discussion in 'Wheels & Tires' started by tcBob, Jul 17, 2010.
  1. Jun 27, 2017 at 12:38 PM
    #861
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    What are you scrubbing right now?
  2. Jun 27, 2017 at 1:38 PM
    #862
    bennett
    bennett Well-Known Member
    Bennett
    Georgia
    08 SR5 4X4
    5100s on all 4 corners(Fronts at .85); Eibach Coils; Toytec Diff Drop; Toytec Top Plate Spacers; Toytec AAL; 285/75R16 MTZs
    Just a little bit on the fender now in reverse
  3. Jun 27, 2017 at 2:53 PM
    #863
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Scrub, scrubbing, scrub radius...is something totally different than rubbing when talking tires. You had me a little confused.
    Assuming you're rubbing in the cab mount area...
    The outside of the tire will sit 1/2 further out; it will rub more.
    The inside of the tire will sit 1/2" further in; you might have clearance issues with the UCA.
    Going to a 8" wide rim is allowing the full section width of a 285, whereas your stock 7" isn't.
  4. Jun 28, 2017 at 11:41 AM
    #864
    bennett
    Bennett
    Georgia
    08 SR5 4X4
    So would it be better if I could find an 8" wide rim with 4" or 4.25" backspacing. What do people running 285s normally go with?
  5. Jun 28, 2017 at 1:58 PM
    #865
    splitbolt
    NW Arkansas
    Most get an 8" wide, 0 to -12 offset, 4.5"-4" backspace.
    4" would give you the same backspace you currently have; should clear the UCAs fine.
    But now the outside will sit 1" further out...it will rub worse.
    No free lunch with 285s.
    lynyrd3 likes this.
  6. Jun 28, 2017 at 4:15 PM
    #866
    Boomkanani
    Goldsboro, NC
    Some stuffz
    If the spacers were eliminated and ran the 8" wide rim...they would not stick out further
  7. Jun 28, 2017 at 4:58 PM
    #867
    splitbolt
    NW Arkansas
    1/2" tire protrusion; 1" wheel protrusion.
    Right now he has a 16x7 et 30 with 1.25" spacers; basically a 16x7 et 0.
    I thought it was accurate, if he goes to a 16x8 et -12, to match his current 4" of backspace. :notsure:
  8. Jun 28, 2017 at 6:32 PM
    #868
    Boomkanani
    Goldsboro, NC
    Some stuffz
    True it would stick out more, by a little more than .6". Offset on stock 7" should be 30...equals 5.18 - 1.25" spacers = 3.93" backspace....which sticks out about 4.07". According to your link total tire is 10 mm wider...I would think 5 mm each side.
    (4.5 - 4.07) + .2 = .63
  9. Jul 4, 2017 at 9:44 AM
    #869
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
  10. Jul 4, 2017 at 1:20 PM
    #870
    splitbolt
    NW Arkansas
    Work...?
    Fitment? Rubbing? Not adding a ton of positive scrub?
    The tire will protrude about an 1" with those wheels; rubbing shouldn't be a problem.
    Maybe some plastic or mudflaps...depending on use and caster.
  11. Jul 4, 2017 at 2:17 PM
    #871
    M1Awolf
    Rob
    Montana
    Thanks for the info, I was pretty sure I had bolt pattern,offset and backspacing right. I just wanted to confirm that rubbing shouldn't be a problem and that a CMC shouldn't be a factor. I am also planning on putting about 2.5"-3" of lift on it and installing an SSO slimline and a Smittybuilt X20 10k, I will do UCA's if needed.
    @splitbolt This is the other wheel I am looking at any input on this one.
    TIA
    https://www.extremecustoms.com/product.php?item_id=127552
  12. Jul 5, 2017 at 8:28 AM
    #872
    MUDDSHARK
    MUDDSHARK might not do u right but will never do u wrong
    2016 Quicksand Tacoma Trd access cab
    Locking gas cap so far.
    Man I wish I found this info before I searched all over line lol
  13. Jul 5, 2017 at 4:20 PM
    #873
    splitbolt
    NW Arkansas
    The lift changes things.
    You'll more than likely need UCAs with that much lift. This will move the wheel rearward; but with that much lift, it still shouldn't be a problem.
  14. Jul 5, 2017 at 4:55 PM
    #874
    M1Awolf
    Rob
    Montana
  15. Jul 5, 2017 at 5:11 PM
    #875
    splitbolt
    NW Arkansas
    Yes. They're essentially the same as your first choice.
    Just make sure they clear the calipers; some 16"s run into spoke interference.
    You'll probably have to call the manufacturer or a wheel shop that knows their shit.
    M1Awolf[QUOTED] likes this.
  16. Jul 5, 2017 at 5:22 PM
    #876
    M1Awolf
    Rob
    Montana
    Thanks @splitbolt
  17. Jul 5, 2017 at 5:25 PM
    #877
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    If I may interject your first choice has a center bore of 106.1 which is good and the size of your hub, your second choice has center bore of 108mm not a deal breaker, but our trucks are hub centric.. If you go with the second choice I'd look into some hub rings to keep the wheels centered on the hubs. Just something I thought I'd point out:D
    splitbolt likes this.
  18. Jul 5, 2017 at 5:28 PM
    #878
    splitbolt
    NW Arkansas
    Good catch.:D
    303tacoma[QUOTED] likes this.
  19. Jul 5, 2017 at 5:47 PM
    #879
    M1Awolf
    Rob
    Montana
    Thanks guys, you are going to find this kind of ironic. I am the alignment tech with 20+years experience for a 6 bay tire shop. I have never dealt with sizing and fitment of wheels so I came here looking for Tacoma specific info....lol
    303tacoma likes this.
  20. Jul 16, 2017 at 5:15 PM
    #880
    HighFlyingHawaiian
    HighFlyingHawaiian New Member
    2007 Tacoma Sport
    Hey guys, so I've read all 44 pages and haven't really found if this set up would work. I've got 17x9 +18mm offset. I plan on running 265/65/17 tires. Stock 2007 TRD Tacoma. Will this work or do I need spacers or a lift? Or should I just return them and get 17x9 -12mm offset. Looks like most guys run the -12mm set up. Thanks!
