Wheel Backspacing and Offset Info
Discussion in 'Wheels & Tires' started by tcBob, Jul 17, 2010.
  1. Dec 10, 2011 at 7:33 PM
    #141
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    0 offset/4.5" BS would be ideal.
  2. Dec 11, 2011 at 9:47 PM
    #142
    Tacogray
    Tacogray Member
    Fernando
    Northern California
    thanks for your help
  3. Dec 26, 2011 at 8:42 AM
    #143
    docjake
    docjake Well-Known Member
    Fredericksburg VA
    There are some very patient people in this thread.
    lynyrd3 likes this.
  4. Dec 29, 2011 at 12:19 PM
    #144
    nobody4343
    nobody4343 Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
  5. Dec 29, 2011 at 12:20 PM
    #145
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    hey man try posting that link again. it didn't show up.
  6. Dec 29, 2011 at 12:22 PM
    #146
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
  7. Jan 25, 2012 at 3:43 PM
    #147
    draddots
    draddots Well-Known Member
    Dan
    City of Champions
    03 DC TRD
    Grey wire mod
    I've decided on Mickey Thompson Classic IIs. Will tire size greatly affect whether these wheels will fit? Do they not fit period? I will not be running a tire bigger than than a 33(or metric equivalent) on a 16x8 wheel. Thanks for any and all assistance.
  8. Jan 25, 2012 at 8:34 PM
    #148
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    ^^^^ what offset
  9. Jan 26, 2012 at 4:16 AM
    #149
    draddots
    Dan
    City of Champions
    03 DC TRD
    Grey wire mod
    Backspacing is 3 5/8", Offset is -22mm
  10. Jan 26, 2012 at 5:40 AM
    #150
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You could fit the 33's with that wheel and a 3" lift, with minor trimming.
    As for wheel fitment, I would check around to see who has those on a first gen. I don't think you'll run into any issues, but some of the 2nd gen guys do with Mickey Thompsons, so better safe than sorry.
  11. Jan 26, 2012 at 8:18 PM
    #151
    draddots
    Dan
    City of Champions
    03 DC TRD
    Grey wire mod
    ^ Thank you!
  12. Jan 28, 2012 at 3:26 PM
    #152
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    im going through same thing.......07 dbl c sb stage 2 fabtech calls for 4.5 b/s on 17 hardest part is matchig tires to rims with the right bs......i must b over thinking this too
  13. Jan 28, 2012 at 4:04 PM
    #153
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    So 16x8 0 offset will work with a 3 inch pro comp lift right
  14. Jan 28, 2012 at 4:17 PM
    #154
    pa blaster
    Scott
    central pa
    right now i have 3" tuff country W/16x8 stock rims 285-75-16 pc mud terrains front wheelss needed a 1/4inch spacer to eleminate tire rub on A-arm
  15. Jan 28, 2012 at 4:32 PM
    #155
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    Ok I don't plan on upgrading to 285s yet still got good 265s
  16. Jan 28, 2012 at 5:29 PM
    #156
    TexasTacoma37
    Stock rims are 16x7 and also sit in 1" closer to the uca than the 16x8 zero offset.
  17. Jan 29, 2012 at 3:32 PM
    #157
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    so no problems with the 16x8 0 offest then no spacers needed or anything
  18. Jan 29, 2012 at 3:33 PM
    #158
    TexasTacoma37
  19. Jan 29, 2012 at 3:36 PM
    #159
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    thanks im ordering these soon then[​IMG]
  20. Jan 29, 2012 at 3:37 PM
    #160
    TexasTacoma37
    Have you confirmed that they clear the front calipers? Many brands of 16s do not.
