Wheel Backspacing
Discussion in 'Wheels & Tires' started by mx355, Jun 16, 2011.
  1. Jun 16, 2011 at 10:25 AM
    mx355
    mx355 [OP] Well-Known Member
    Trent
    TX
    2014 TRD SPORT 4x4
    Icon Ext Travel, Dakar EL095R, RRW RR5-V, 285/70 BFG AT KO2, Katzin Leather, Husky X-Act Contour, Truxedo Lo Pro, Baja Design Squadron Sport Amber Combo with FPK, Fog Light Anytime.
    Looking at a set of wheels that I can get a really good deal on. The backspacing is = 5.25 in. How will they fit or will it work?
  2. Jun 16, 2011 at 10:28 AM
    bschmitt09
    bschmitt09 Welcome to the abusement park.
    Bryan
    Western WA
    Barcelona Red 2011 TRD Off-Road
    Debadged, Wheels & Tires, Delta Toolbox, LEDs interior & exterior, Spyder tail lights, Color matched grille, door handles, and rear bumper, MBRP dual exhaust.
    5.25" in backspacing is what the OEM 16" TRD wheels are, so they should fit fine. What's your tire size?
  3. Jun 16, 2011 at 10:39 AM
    mx355
    Trent
    TX
    2014 TRD SPORT 4x4
    Going to get a lot of hate but its a 20" wheel so would run a 275/55-20
  4. Jun 16, 2011 at 10:39 AM
    mx355
    Trent
    TX
    2014 TRD SPORT 4x4
    Wheel is a 20x9.5
  5. Jun 16, 2011 at 11:15 AM
    bschmitt09
    Bryan
    Western WA
    I believe you may have some rubbing issues with that combo.
  6. Jun 16, 2011 at 11:29 AM
    mx355
    Trent
    TX
    2014 TRD SPORT 4x4
  7. Jun 16, 2011 at 11:34 AM
    mx355
    Trent
    TX
    2014 TRD SPORT 4x4
    If same backspacing same as stock 16s and 20s tires are only .4" wider where do you think it would rub?
  8. Jun 16, 2011 at 12:51 PM
    bschmitt09
    Bryan
    Western WA
    The stock tires are 265/70-R16. Even though you're only .4" wider than stock, you're about 1.5" bigger in diameter over stock. Could have some rubbing on the front flaps and/or inner fender.
    Some people report minor rubbing with 265/70-R17 (31.6") and some don't. Try browsing some other threads in the Wheel and Tire section and see what other people have found.
  9. Jun 16, 2011 at 12:58 PM
    mx355
    Trent
    TX
    2014 TRD SPORT 4x4
    I have a 1.75 Bilestins on my truck so height im not really worried. No mud flaps on so basically just worried on rubbing frame or fenders.
  10. Jun 16, 2011 at 1:16 PM
    Mescalero
    Mescalero Beretta Taco
    Clemson, SC
    '10 PreRunner DCLB BSP
    5100's x 4, radar detector, dual usb plug, mag-light, satellite radio hard wire
    what kind of deal you getting if you dont mind me asking? brand/model/price? just curious
  11. Jun 16, 2011 at 1:43 PM
    mx355
    Trent
    TX
    2014 TRD SPORT 4x4
    BUMP
    Does anyone know if this is Too much backspacing for a 275/55-20 with a 1.75" billy lift?
  12. Jun 16, 2011 at 1:51 PM
    mx355
    Trent
    TX
    2014 TRD SPORT 4x4
    And do Tacoma wheels have to be hub centric?
  13. Jun 17, 2011 at 4:39 AM
    bschmitt09
    Bryan
    Western WA
    They don't HAVE to be. Factory Toyota wheels are designed to be hub centric though. If you're worried about it you could get a set of hub centering rings.
  14. Jun 17, 2011 at 7:35 AM
    mx355
    Trent
    TX
    2014 TRD SPORT 4x4
    I just mostly worried about that backspacing of 5.25 and 0 offset, if it would rub on upper contol
  15. Jun 17, 2011 at 5:19 PM
    mx355
    Trent
    TX
    2014 TRD SPORT 4x4
    BUMP!
    Found this online, is this correct?
    Stock wheel closer to 5.5" than 5.25". The 2005-'08 17x7.5 TRD wheels have a +30mm offset. If they had 0mm offset, the backspacing would be 4.25". So, technically, the backspacing is 5.43 inches.
    Here is a guy with 20x8.5 with 275/55-20 with no rubbing issuses, but not sure on backspacing or offest.
    http://img.photobucket.com/albums/v514/deff808/IMG_0599.jpg
