Wheel Balance Weights
Discussion in 'Wheels & Tires' started by Drogers, Jul 11, 2010.
  1. Jul 11, 2010 at 6:49 PM
    Drogers
    Drogers [OP] Well-Known Member
    Derek
    Sayville, NY
    2010 Reg Cab 4X4 5sp manual
    Leer 100XR Topper, Re-wired interior dome light, Shaved front mud flaps, Rebadged flat black, Avid offroad light/bull bar, Yellow OEM Fog Light Mod, 265/75R16 Nitto Terra Grapplers, stock 16 steelies painted flat black, K&N air filter
    Does anyone know how to move your wheel balance weights to the inside of the wheel? I've never removed these things before and don't want to screw anything up.
    Thanks in advance.
  2. Jul 11, 2010 at 6:54 PM
    Brunes
    Brunes abides.
    Rotorhead
    You can't just move them. You need to get the wheels rebalanced with the static setting in order to get the right weights in the right place on the inner lip of the wheel.
  3. Jul 11, 2010 at 6:55 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    ^ what he said plus the weights that go inside or on the lip are different kinds
  4. Jul 11, 2010 at 6:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    x2....best to get a tire shop to do it....that way they are in the right spot on the wheel. you cant guess where they need to be balanced at.
  5. Jul 11, 2010 at 7:04 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    08 Tacoma Black,Sport package,
    Sport pedals, Extang full-tilt cover, Magnaflow exhaust system, XPEL invisible paint protection, TRD short Shifter, Hood struts, Homelink mirror, Dbl power outlets,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Muth heated signal mirrors TSB. Lo-Tek Pilllar pod with Glow-Shift gauges, 4x4 illuminated switch, Pioneer Z110BT (upgraded to Z130BT) w/2011 toyota tailgate backup camera,traffic tuner, parking brake bypass. Leather interior w/heated seats. LED's installed in glove box, center console, front and rear cupholders, rear console vent, AFE CAI, LED taillights, under hood lights, LED bed lights, oil catch can, extra D-rings installed in bed, frame replaced, Bilstein 5100, fronts set at.85, FOCAL Auditor 6.5" componet speakers. Replaced lower center dash panel with 2011 dash panel, installed USB charger and relocated seat heater switches to lower panel, FLYZEYE lights, APEX stealth LED light bar brackets and Cali Raised LED light bar, Illuminated Ignition Ring,Diff. Breather mod, AC mod.
    Have your tires re-balanced and the weights put on the inside. You just can't move them. I have all my wheels balanced with the weights on the inside
  6. Jul 11, 2010 at 7:08 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    I've Had Wheels That Wouldn't Balance Without Some Weights on The OutSide of Rim.
    Don't Know Why. Same Wheels / Same Results / Multiple Shops
    Even Though I Requested Them on the Inside
  7. Jul 11, 2010 at 7:08 PM
    08pretaco
    Oliver
    az
    ^ your lucky. my tires have to be run probably 5 to 6 times with weights inside and lip in order to get them balanced properly
  8. Jul 11, 2010 at 7:19 PM
    Drogers
    Derek
    Sayville, NY
    Thanks for the help!
  9. Jul 13, 2010 at 6:17 PM
    dgr540
    dgr540 I've got the FUNK
    Friendswood, TX
    2013 Wrangler Unlimited
    XDs Trail grappler 35x12.5x18 Winch 8K lbs Front bumper 4in Lift
    I bought a pack a Harbor Freight.
