Wheel bearing & Control Arm Cost?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Turk409, Feb 17, 2017.
  1. Feb 17, 2017 at 3:30 PM
    Turk409
    Turk409 [OP] Active Member
    Daniel
    2006 Tacoma TRD
    Hi everyone, I just ordered my wheel bearings and lower control arms for both sides in the front of my 2006 Tacoma. My mechanic told me my control arms bushings were bad but he said most likely my ball joints were too, due to my lift, so I bought the entire control arm. I am just wondering how much should I expect to pay in labor for my wheel bearings and control arms replacement? I am doing both all at once so it should be cheaper since he just have to take everything apart once right?
    Thanks in advance
  2. Feb 17, 2017 at 7:24 PM
    TacoLV
    TacoLV Active Member
    Nick
    Vegas
    2008 PreRunner
    Maxtrac 4' , AAL
    Since everything is already apart I would have to say you're probably looking around $400 for everything. That's a ballpark figure but you can also call and ask for estimates from other shops too. You may have to factor in an alignment once the UCA are installed also .
  3. Feb 17, 2017 at 7:27 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    You can do it your self very easily
  4. Feb 17, 2017 at 7:30 PM
    Bishop84
    Bishop84 Well-Known Member
    If they are seized they can be right awful to remove, saws-all and many beers, I wouldn't want to cut one out at home.
  5. Feb 17, 2017 at 7:30 PM
    TacoLV
    Nick
    Vegas
    2008 PreRunner
    Maxtrac 4' , AAL
    I would agree that most people who have semi mechanical knowledge could but the issue would be wether the member has the proper tools
  6. Feb 18, 2017 at 4:32 AM
    badger
    badger Well-Known Member
    07 SR5
    There is a guy on the marketplace called Bamatoys who sells bearing / hub assemblies. He does things like popping the seals and adding extra grease. I really like his product, and it makes bearing replacement a snap. Even if you prefer that a mechanic do the work, having those hubs will make the mechanic bill far smaller (or should), and you will get a better bearing replacement job.
  7. Feb 18, 2017 at 7:59 AM
    dirtgypsy
    dirtgypsy Well-Known Member
    2005 Super White DCLB
    none
    Just got mine back from dealer from having both jobs done on passenger side only. Lower control arm/ ball joint went first and it was $370 in labor and then the wheel bearing failed and it was $360 in labor. Good luck with the repairs!
    Clint
  8. Feb 18, 2017 at 10:47 AM
    Turk409
    Daniel
    2006 Tacoma TRD
    Thanks for all the great responses. I just got quoted by a shop $350 to do both sides (control arms and bearings). I am going to keep calling around and see if I can find any better deals. I been seeing that these bearings and control arms have to be pressed. I have some concern that the shop I am going to take it don't have a presser; Would the work they give me be less of quality and that's why they're charging me less?
  9. Feb 18, 2017 at 3:20 PM
    TacoLV
    Nick
    Vegas
    2008 PreRunner
    Maxtrac 4' , AAL
    I don't know if it would be less quality unless you maybe taking it to some pop shop or something but maybe they don't know the full scoop on it. I think with labor rates though 350 could be your average price
  10. Feb 18, 2017 at 3:22 PM
    anthony250f
    Anthony
    San Diego, CA
    Buy the wheel bearings already pressed in.
