Wheel Bearing Damage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kieth, Jul 31, 2012.
  1. Jul 31, 2012 at 7:26 PM
    kieth
    kieth [OP] Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    Hey guys I changed my front drivers side wheel bearing last week. Check out these pics of the damage on the outer race, pretty weird, only 90,000kms.
  2. Jul 31, 2012 at 7:40 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    That's weird , was it making a ton of noise ?
  3. Jul 31, 2012 at 7:41 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Pretty ugly, how'd the cages look? Wonder if they damaged that race when they pressed it all together, 55k miles isn't very good so it wouldn't surprise me if that's what happened.
  4. Jul 31, 2012 at 7:52 PM
    Wayner275
    Wayner275 Member Me
    Regina, Saskatchewan
    09 Tacoma
    Step bars, Weathertech mats, Sirius sat., Fold-a-Cover G4 Elite, Pop-n-Lock (ditched the PopnLock and went with the Dyno Lock, RedLine hood struts, Cloud-rider Grill insert,
    Same thing happened to me at 88,000 kms on my 2009dc. Only on the driver's side.... no problems with the passenger side (yet).
  5. Jul 31, 2012 at 8:26 PM
    kieth
    06 trd
    the cages looked fine, It wasnt very noisy and there was no play in it at all, just a vibration in my floor and gas pedal.
  6. Jul 31, 2012 at 8:57 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    A lot of 4 wheeling in water tends to wash the grease out.
  7. Aug 1, 2012 at 12:46 AM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    How was the truck driven? A lot of offroading?
  8. Aug 1, 2012 at 6:10 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Looks overheated.
    Those bearings start to get loose at about 30K if nobody tightens them then grease leaks out and they just fall appart. I replaced mines at almost 45K and now tighten them every 3000K to keep them solid.
    As long as they stay together seals will keep grease inside.
    I highly recommend filling new bearings with tons of Mobil 1 grease and then re tighten them to spec every 3000 miles especially in cases where there are over sized tires.
  9. Aug 1, 2012 at 7:17 AM
    Hard
    Hard Well-Known Member
    H
    4X4X4
    Filling a sealed bearing? Do tell...
  10. Aug 1, 2012 at 7:39 AM
    BlueT
    NorthEast
    When you buy new bearing you can separate it and fill with grease. They are sold with no grease and needs to be packed.
  11. Aug 1, 2012 at 7:46 AM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    What are you re torqueing? When mine went out I replaced the whole hub assembly, well had the dealer do it because they gave me a hell of deal since they didnt have to press out the old bearing.
  12. Aug 1, 2012 at 8:13 AM
    BlueT
    NorthEast
    you need to retorque CV nut if you have 4wd, Bearing adjust nut if you have prerunner. the only thing I would worry about dealer doing work is if they filled new bearing with grease.
  13. Aug 1, 2012 at 4:40 PM
    kieth
    06 trd
    i just drive into fishing lakes and campin spots every other weekend, lots of mud\water holes\light offroading. I replaced the bearing assembly and did not pack with grease, its a complete unit, how could it not be greased from factory?
  14. Aug 1, 2012 at 6:05 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    It is but not very well. Best to pull out the bearings and then pack em full of high quality hi-temp disc wheel bearing grease. I used valvoline full synthetic. I like valvoline personally and it comes highly recommended, even over mobil 1, in multiple threads over on BITOG
  15. Aug 1, 2012 at 11:39 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    They aren't sealed bearings.
    They are bearings inside the hub which has seals to protect the bearings inside by retaining the grease.
  16. Aug 1, 2012 at 11:43 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    As I stated and by others here the grease washed out. Lots of water will wash out the grease regardless of the seal on the hub. 4 X 4 = More maintenance.
