Wheel Bearing Going Bad: Sounds?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MolonLabeTaco, Oct 6, 2018.
  1. Oct 7, 2018 at 8:53 AM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    Still possible it's a tire with the tread starting to separate. Swap tires left to right and repeat the sweeping curve test to see if the sound switches.
  2. Oct 7, 2018 at 9:33 AM
    Noreast
    Noreast Well-Known Member
    Dylon
    2012 silver 4dr tacoma TRD
    I got one that's pretty bad around 2,000 RPMs but over 65mph it's gone
  3. Oct 7, 2018 at 11:23 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Lift the front of the truck off the ground. Grab the spindle with one hand and spin the tire with the other. It should be whisper quiet and smooth. Any roughness felt through the hand that is holding the spindle is a bad bearing.
    Don't need to remove the caliper or wheel. I do this on every car that is up in the air getting an oil change or something. You'd be surprised how effective it is
  4. Oct 7, 2018 at 11:46 AM
    MolonLabeTaco
    MolonLabeTaco [OP] Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I hear a slight grinding sound from both wheels, when lifted & spinning by hand, but assumed it was brake pads.
  5. Oct 7, 2018 at 11:52 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Your not looking for noise necessarily, but do you feel any roughness through your hand?
  6. Oct 7, 2018 at 5:20 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    If it ever quits raining I'll try this. I went ahead & bought 2 wheel bearing/hub assemblies built by BamaToy1997.
    If I end up replacing them, do I have to use a new axle nut or can I re-use the ones on my truck already?
    I have no rust & 91K miles.
    TreeFortRichard likes this.
  7. Oct 7, 2018 at 5:30 PM
    Lthompson
    Lthompson Well-Known Member
    Not necessarily.. Mine went away when turning right, noticeable at any speed above 60 mph... but it was the drivers side bearing bad. Changed the passenger side, didn't fix it. changed the drivers side, it went away
  8. Oct 7, 2018 at 5:45 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I bought 2 just in case!
  9. Oct 7, 2018 at 6:25 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You can reuse the axle nut as long as its torqued properly, maybe put a couple drops of loctite on the threads
    MolonLabeTaco[OP] likes this.
  10. Oct 7, 2018 at 8:19 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    I just did this myself. You Texas people don't deal with the rust we have here in Massholia...axle nut is 100% reusable.
    When you get the hub off the knuckle you will be staring at the end of the axle and inside you'll see the speed sensor. Don't touch it. Wipe around the edge uf the knuckle and lube the oring on the new wheel bearing before sliding it in.
    Check out my posts in this thread
    https://www.tacomaworld.com/threads/hub-assembly-additional-parts.570697/#post-18825027
  11. Oct 7, 2018 at 8:51 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I've actually done it before on a buddies Taco about 3-4 months ago. His came w/new nuts but the ones I just bought don't so I was wondering. Thanks for the link!
  12. Oct 7, 2018 at 8:53 PM
    Boatbldr
    Boatbldr Well-Known Member
    Florida
    2002 prerunner
    None
    Try turning your hearing aid down while your driving or just shut them off Ole' man
  13. Oct 7, 2018 at 8:59 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I'm not THAT damn old!!! :brianr:
    Boatbldr[QUOTED] likes this.
  14. Oct 8, 2018 at 1:17 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I did this and didn’t feel anything on the PS and maaaaaaybe a very subtle vibration on DS. Nothing really noticeable, though.
  15. Oct 8, 2018 at 4:20 PM
    #35
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It's hard to describe what you're feeling for if you've never felt good ones and bad ones.. it was taught to me by an old tech I work with
    Think of it this way.. if you hold a skateboard (with bad wheel bearings) in your hand and spin the wheels you can feel the roughness. If you replace the bearings and re-spin the wheels the difference is night and day.
    Do you have a stethoscope? Put the metal tip right at the back of the knuckle and have a helper spin the wheel around. You should hear absolutely nothing
  16. Oct 8, 2018 at 4:31 PM
    #36
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    I know this all too well! I used to skate 1/2 pipe comp's in the late 80's-early90's. I didn't feel what you're describing.
    b_r_o[QUOTED] likes this.
  17. Oct 8, 2018 at 4:33 PM
    #37
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Bust out the stethoscope!
  18. Oct 10, 2018 at 5:53 PM
    #38
    kimo
    kimo Well-Known Member
    Knuckle Head
    Kauai
    09 Super White TRD Sport DCLB 4X4! 2017 Silver 4Runner!
    I'm at 94k miles and started getting same noise last week. I'm pretty sure its the bearings. Ordered new hubs/bearings today. It looks pretty straightforward and was planning on a brake job soon anyhow.
    Any update on your situation?
  19. Oct 10, 2018 at 8:52 PM
    #39
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    Waiting for the parts to arrive. Whatever my sound is, assuming it’s bearings, is getting louder every day it seems.
    It’s an easy job to do and doesn’t really take any special tools, except for a 35mm socket and torque wrench. I’ll post back after I swap them out on my findings!
    b_r_o likes this.
  20. Oct 11, 2018 at 5:00 AM
    #40
    kimo
    Knuckle Head
    Kauai
    Okay, yeah I need to get a 35mm socket and my old torque wrench only goes up to 150 ft lb.
    Funny thing I found an old 36mm in my tool box from 30 years ago when I owned a VW.
    Good luck with your repair!
