wheel bearing going out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07TaCo07, Aug 12, 2011.
  1. Aug 12, 2011 at 7:40 AM
    07TaCo07
    07TaCo07 [OP] Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    So les schwabs told me my driver side wheel bearing is going out and I was wondering how long I can drive on it for and what happens when it does fail. Any signs that's its getting really bad?
  2. Aug 12, 2011 at 7:46 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You probably dont want to drive too long. I think some people went 20-30K from first grinds on turns to grind/vibe always.
  3. Aug 12, 2011 at 7:58 AM
    pootermobile
    pootermobile Well-Known Member
    Florida
    06 DBL cab 4WD V6 6-speed Debadged
    De-Flapped, All-Weather Floor Mats, Blue LED dome light, De-badged, BMW shift knob, 8K HIDs in headlights and fogs, Fog light relay MOD, 3" Coil-spring spacers, 1.5" rear blocks, 17" ProComp 7033s, 285/70R17 Nitto Terra Grapplers, Ebay 7" touch screen head unit, TEKstyle snap button tonneau cover
    mine started about 3 weeks ago with a vibe(that you can definitely feel). I'm trying to drive it the least amount possible(ride my motorcycle) but it keeps raining. I drive about 55 mph max and probably have about 300 miles on it and i can tell its getting worse. Planing on fixing it tomorrow because it's better to just fix the wheel bearing than anything else it may take with it.
