Wheel bearing? High pitch noises
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chrissteffen599, Oct 1, 2014.
  1. Oct 1, 2014 at 10:45 PM
    Chrissteffen599
    Chrissteffen599 [OP] Well-Known Member
    Texas
    02 tacoma
    Bilstein 5100 all around Allpro front and rear bumpers Trailgear turn signals Hella 700ff HID conversion
    For the past couple weeks, I have been getting a high pitch ticking or clicking noise coming from on of my wheels as it rotates. Does anybody have any opinions on what it could be and how it can be fixed? I have heard the possibility of it being the wheel bearing.
  2. Oct 1, 2014 at 11:44 PM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    Do you have spacers installed?
  3. Oct 2, 2014 at 5:23 AM
    Chrissteffen599
    Texas
    02 tacoma
    Sure do /: but that's changing in about 3 weeks. Full OME setup on the way! Would the spacer kit be the culprit?
  4. Oct 2, 2014 at 7:28 AM
    Darryle
    Darryle
    Weatherford, Texas
    Others have reported that they get a clicking noise when they install their spacers
  5. Oct 2, 2014 at 7:33 AM
    BamaToy1997
    Bill
    Navarre, FL
    Check to be sure that the rotor is not contacting the backing shield. Also check that the caliper bolts and bracket bolts are tight.
  6. Oct 2, 2014 at 12:15 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I believe he meant wheel spacers, not a spacer lift. Unless I misunderstood you.
  7. Oct 9, 2014 at 9:59 AM
    270wsm
    270wsm Well-Known Member
    AZ
    Will wheel spacers frm 3/4"-+1.5" cause problems if so what kind?and how soon anyone :)
  8. Oct 9, 2014 at 10:05 AM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I also have wheel spacers that are pretty thin up front and have recently been hearing a high pitch squealing sound sound from my front drivers side wheel. It goes away when I touch the breaks but then comes right back when I let off the pedal. I'm trying to figure out if I need a brake job(new pads & resurface the rotors) or if I need to replace the wheel bearing. Hopefully it's not a combo of both.
  9. Oct 9, 2014 at 12:44 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    me too^^ subbed for outcome
