Wheel bearing/ Hub help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Geneiuus, Mar 13, 2019.
  1. Mar 13, 2019 at 1:51 PM
    Geneiuus
    Geneiuus [OP] Well-Known Member
    Banning
    1st gen tacoma
    Hit by a deisel truck
    2004 Double Cab Prerunner
    Who was the member that makes complete guns on here? I found the thread the other day then lost it. Just quoted everything from the dealer and almost had an aneurysm. I need to get a set, stat.
    Thanks
  2. Mar 13, 2019 at 1:53 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    guns?
    If you mean complete hub/bearing, no pressing needed, it's only for 2nd, 3rd Gen trucks. 2005 and up.
    I hope you don't really have an aneurysm. That won't help.
  3. Mar 13, 2019 at 2:25 PM
    Geneiuus
    Banning
    1st gen tacoma
    I meant hubs.
    Only for 2nd and 3rd gen?
    FML
    Looks like I'm gonna need those guns after all. Lol.
    The dealership quoted over 1k for just parts.
  4. Mar 13, 2019 at 2:58 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Why are you at a dealership unless you enjoy that sort of thing?
    Kind of like the old joke about the hunter who kept getting raped by the deer.
    The deer figured out pretty quick he wasn't there to hunt.
    koditten and SaulG like this.
  5. Mar 13, 2019 at 3:04 PM
    Geneiuus
    Banning
    1st gen tacoma
    Just getting a starting point for pricing. Sometimes it's hard to figure out what's good product in the aftermarket world when I find the same thing for $100 or $1. Then at least I can aim for the upper middle if I can't find any solid info
    cruiserguy likes this.
  6. Mar 13, 2019 at 4:24 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Order Koyo's. Take off your own spindles/ bring to machine shop
    Toyota seals if you want they are good. I thnk most seals are good myself but good ones all cost about the same.
    BTW: 100 each is not out of line for a good bearing.
    edit: with machine pressing you should be able to get by under 500/both sides. If the machine shop (or 4WD shop) says "Ahh man, these are sooooo hard I have to charge a lot" or " I've never done this before" go somewhere else.
  7. Mar 13, 2019 at 10:19 PM
    Geneiuus
    Banning
    1st gen tacoma
    Can I get away with just buying the 6 ton bench top press from Harbor Freight and doing it myself? Or I can take it to my old Harley shop and use the big press there. Or do you need some super special arbor and press kit?
    Thanks
  8. Mar 13, 2019 at 10:25 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Find a machine shop attached to an auto parts store. Have them press out and press in your new bearings. I just had it done.
    The labor was $85/ side. Parts were around $210. I forget exactly because I bought brake parts as well.
    Having them do the labor gets you a somewhat of a warranty.
  9. Mar 14, 2019 at 3:08 AM
    nczo6
    nczo6 Well-Known Member
    robert
    Triad NC
    2002 2.7 4x4 xtracab silver
    $85 per side!!! holy moly, I'm glad I just picked up a press for 100 bucks since I need to do this.
  10. Mar 14, 2019 at 3:15 AM
    koditten
    Kirk
    Central Michigan
    I did the math. I don't get a garentee if I do it myself. I don't want to keep a tool I don't use and taking up space.
    cruxofthebisquit likes this.
  11. Mar 14, 2019 at 4:53 AM
    nczo6
    robert
    Triad NC
    I'm one who does as much work as I can, I cant stand someone else working on my stuff just due to the fact people are lazy and don't care these days.
    Geneiuus[OP] likes this.
  12. Mar 14, 2019 at 5:04 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You'll need a bunch of spacers and cups to support the bearing and hub correctly while pressing, to avoid damaging the parts.
    There are also tool kits e.g. OTC Hub Tamer or Hub Grappler that let you do this in situ without a press if you have an impact wrench. Basically a big jackscrew with spacers and cups.
    koditten and cruxofthebisquit like this.
  13. Mar 29, 2019 at 9:42 PM
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    Any idea if these can be rented from an auto parts store?
  14. Mar 30, 2019 at 12:36 AM
    Geneiuus
    Banning
    1st gen tacoma
    I think Autozone had something like the OTC Hub Grappler for rent but it was somewhere around $450 deposit.
  15. Mar 30, 2019 at 2:54 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    See I quoted so it does not overwork your brain!!
    I have to agree with Kirk It all depends at my $120.00 /hour labor rate I can bill a few hours labor while having a bearing pressed in and out rather then taking 3 times as long to do the job myself .
    Either bending a spindle or getting a bearing crooked with my luck seems to be the case costing far more in the end. since it is not something I do every week.
    It comes down to what works for you
    koditten[QUOTED] likes this.
