Wheel bearing noise or tire noise?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kingston73, Aug 10, 2016.
  1. May 11, 2019 at 5:38 PM
    #61
    Bill Anderson
    Bill Anderson Member
    05 SR5 4wd LB
    Never had a bad rear bearing. But the front ones will throw noise/sounds from, it seems, all directions lol. That's why I don't try to guess which one is bad/ failing, since I can rarely pinpoint the 'correct' bad bearing. Even with all the tips and tricks to diagnose, I still can't diagnose correctly lol.
    And like you I could've sworn it was my tires. First I had them balanced, didn't make a difference. And since i was absolutely convinced certain (Yeah right lol) it was my tires, I replaced those. Nope! It was the wheel bearings. Replaced both, and is still smooth as silk 40,000 miles later.
    You won't believe how smooth your truck will be after replacing those bearings. You don't realize the bearings are as bad as they are, until you drive down the highway after having them replaced.
    henryp and TRON[QUOTED] like this.
  2. May 11, 2019 at 5:48 PM
    #62
    smitty997
    smitty997 Well-Known Member
    Dan
    Your moms trailer
    2011 TURD OR
    WHEEEEEEE
    Never a more true statement
  3. May 11, 2019 at 8:52 PM
    #63
    08RC
    08RC Well-Known Member
    I just did the fronts for the same sounds . I had the noise when I bought it . I lifted it put on new tires and wheels and had the same sound afterwards. The one thing that was a dead give away was it had the sound of bad tire balance but not the feel. It was smooth with both sets of tires . Any tire that loud you would also feel some vibes too, I didn't. Problem is it still there just not as loud, maybe rears need to be replaced too.
  4. May 13, 2019 at 3:23 PM
    #64
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Damn the dealership wanting 700.00 for each hub assembly excluding labor. That’s just crazy! So is everyone doing the Dorman option with skf bearing?
  5. May 13, 2019 at 3:30 PM
    #65
    smitty997
    Dan
    Your moms trailer
    2011 TURD OR
    WHEEEEEEE
    Hubs are not hard to do yourself as long as you have a socket for the axle nut. Save yourself the money. I think I got mine for my drives side for around $150
  6. May 13, 2019 at 3:37 PM
    #66
    08RC
    At about 10-15 miles a day I bought a less than 100 bucks each assembled for mine . Can't remember the brand but they will most likely last longer than I need to and they are not Moog so I am fine with it
    smitty997 likes this.
  7. May 24, 2019 at 9:44 PM
    #67
    TRON
    Finally swapped out my front bearings today with new ones. Made a world of difference. These wheel bearings that were oem and had about 100k on them were nsk bearings. Which I thought was strange cause my truck is 2008 and I’m the single owner. Thought they would have been koyo.
  8. Oct 28, 2019 at 11:32 AM
    #68
    HillCountryTaco
    HillCountryTaco Member
    I’ve had a noise/grinding that I thought was in the front end. I had recently had tired rotated and balanced (stock size tires) but noise persisted. Tires are fairly new with less than 18,000 miles.
    Next, I had both front wheel bearings replaced and noise is still there but seems to be coming from the rear now.
    The noise is loudest when turning left, noticeable when straight, and almost disappears when turning right. Would that indicated the rear left wheel bearing as the problem?
    Thanks in advance for any feedback.
  9. Oct 28, 2019 at 5:39 PM
    #69
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Background information is helpful. How many miles? What have you checked/ruled out? When did it start? Any changes to the truck? Any parts replaced?
    Have you checked the u-joints? Carrier bearing?
  10. Oct 28, 2019 at 6:28 PM
    #70
    Bill Anderson
    05 SR5 4wd LB
    It's also possible, when one of the new bearings was being pressed in the hub, the new bearing could've been damaged.
  11. Oct 28, 2019 at 7:57 PM
    #71
    TRON
    Rear bearings being bad is very rare
    SR-71A likes this.
  12. Oct 29, 2019 at 7:47 AM
    #72
    HillCountryTaco
    66,000 miles. The noise started about a month ago. The mechanic who changed the front wheel bearings checked the u-joints and they were ok. I’m not sure about carrier bearing.
    ACEkraut[QUOTED] likes this.
  13. Oct 29, 2019 at 9:51 AM
    #73
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Replaced both my fronts at 149k and the truck is 10x quieter now. I thought it was tire noise the whole time, lol. Used Koyo bearings from the TW member who does the press service.
  14. Nov 18, 2019 at 2:41 PM
    #74
    HillCountryTaco
    I’ve been traveling a lot and haven’t had time to work on the above problem until today. The sound seemed to be coming from the rear right and thought I might have a bad tire, so I took off tire and put on the spare and the noise is still present. Any ideas of places to narrow down based on background?
    Carrier bearing? Back wheel bearings, etc?
  15. Jul 5, 2020 at 9:18 PM
    #75
    HillCountryTaco
    New update - I had my mechanic replace the needle bearing with the ECGS bearing. Unfortunately, I still have the rotating sound described in prior posts. To summarize, both front wheel bearings replaced, u-joints checked, and new ECGS bearing. I do not think it's tire noise as it is more of a metallic sound when turning left and disappears when I turn to the right. I'm at a loss...
  16. Jul 6, 2020 at 1:14 PM
    #76
    ACEkraut
    Aaron
    Durham, Maine
    There are still two back wheels that might have a bad bearing. Jack them up and wiggle them side to side to see if there is any play. From past experience I chased a front end bearing problem....until I found out it was the rear bearing. It could also be the drive shaft carrier bearing.
  17. Oct 30, 2020 at 5:16 PM
    #77
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    I’m hearing and feeling this in the steering wheel at 134k miles.
  18. Oct 30, 2020 at 5:48 PM
    #78
    1E7taco
    1E7taco Googled It
    Michigan
    2006 Silver Toyota Tacoma Base
    240k+ miles
  19. Feb 28, 2021 at 8:33 AM
    #79
    hoveringuy
    hoveringuy Active Member
    Another datapoint here. I had a loud "hum" that sounded like I had knobby tires. Absolutely no play in either of the front wheels.
    Replaced both front bearing assemblies with "QJZ" brand hubs and it's super quiet now. 2wd. Maybe 20 mins per side, easy!
    Amazingly, I'm fairly sure these were the original bearings with 280k miles.
  20. May 10, 2021 at 4:15 PM
    #80
    ViPER395
    ViPER395 New Member
    Eric
    2009 TRD Sport
    Super old thread, but looking for a definitive answer to Kingstons question.
    Thanks!
