wheel bearing or needle bearing?
Discussion in '1st Gen. Tacomas (1995-2004)' started by seehodgey, Jan 20, 2019.
  1. Jan 20, 2019 at 1:11 PM
    seehodgey
    seehodgey [OP] Member
    chris
    Southern California
    02 tacoma 3.4
    First post, long time reader.
    02 base tacoma/ 180k on the clock/ ifs 7.5 clam/ 4.10 / 3inch lift/ 285's/ new cv's
    -I believe I am experiencing the clamshell bushing/ (needle bearing?) failure but am questioning the wheel bearing as the culprit.
    -Constant cyclical whirling front end driveline noise and vibration that increases with speed.
    +Occurs at speed with engine off.
    +Does not go away when 4wheel drive is engaged
    +Does not seem to change sound/vibration when turning left to right
    +Significant (in comparison to passeng) up and down play at cv diff union
    +(With wheel lifted) binds at one position during hand rotation 10 degree out of 360.
    + requires significant hand force to pass binding area (Concerned about cv angle during test)
    + no audible grinding or typical wheel bearing noise
    + no noticeable 12 to 6 play when shaking wheel
    I have reviewed lots of the second gen posts on the needle bearing issue and replacement and believe this to be my issue. I found one post regarding the 1st gen bearing/sleeve issue. I know i can pull the drivers side cv to check and see if the hub spins freely with no cv/ diff connection; eliminating the wheel bearing as a suspect. I am looking for advice before doing so in the hopes to reduce daily driver down time and wrench hours. I am ready to purchase the ecgs sleeve and removal tool or wheel bearing but given that they come out to about the same price (tight budget), wanted some feedback if possible. My biggest question is: can a wheel bearing failure create an almost seized point of rotation with no other symptoms, then return to free motion for the remaining 350 degrees?
    I appreciate your time and truly value the information and communal support within this forum, one of the many reasons why I chose this truck.
    Thank you, Chris
  2. Jan 20, 2019 at 1:15 PM
    Bishop84
    Bishop84 Well-Known Member
    Sounds like a wheel bearing, hard to diag at home with spinning tires up to speed.
    Often on tacomas I can tell a worn bearing simply by hitting it and checking the wheel for free play with the tire on and off the ground.
    A good solid hand hit on the tire will create a clunking noise on a worn wheel bearing. Also some bearings when worn and noisy will have movement with the hub compared to the brake.
    Next, CV axle play in the drivers output is normal, it moves like crazy, this is why it makes so much noise on lifted models.
    Lastly, when bearings are worn, it puts more stress on the brake caliper, make sure its not seized, push the pistons back, this could be causing the drag.
    Ngneer likes this.
  3. Jan 20, 2019 at 10:59 PM
    seehodgey
    chris
    Southern California
    02 tacoma 3.4
    Thank you Bishop84
    -Hit, shook kicked tire both on and off ground- no noticeable sound or motion, most likely due to a lack of ear.
    -Pulled caliper and pads- no difference in binding. Rotor, pads, caliper all look good.
    When I get the chance, i'll pull the cv axle out of the knuckle and rotate hub to search for free movement or resistance, hopefully isolating the problem to bearing or diff/cv. Ill check rear of wheel bearing/ hub for shavings, wobble and irregularities if thats visible or possible.
    The cv to diff connection is still concerning to me since it appears to move in an oval (not smooth) motion when rotating.
    Will let y'all know what I come up with.
    Thank you again, Chris
  4. Feb 16, 2019 at 12:06 PM
    seehodgey
    chris
    Southern California
    02 tacoma 3.4
    SOLVED: Passenger rear wheel bearing.
    Replaced front drivers wheel bearing after removing cv axle when I still felt resistance in the hub. The old wheel bearing showed signs of water mixing in the grease. The whirling problem vibration/noise persisted. Changed front passenger side wheel bearing. Problem persisted. Out of frustration, put all four corners on jack stands and, as safely as I possibly could, engaged drivetrain to speed in the air. Walked around vehicle noticing faint rear passenger noise close to hub. Replaced passenger rear wheel bearing, which was extremely worn. I didn't notice any symptoms there when originally checking all four. Not sure why the sound seemed to come so much more from the front of the vehicle. Thank you Bishop84 for your help.
    original noise from cab:
    rear wheel bearing:
  5. Feb 26, 2019 at 1:47 PM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
  6. Jan 24, 2021 at 1:52 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    That was a classic bearing sound for sure.
