Wheel Bearing problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by yota97, Jul 25, 2011.
  1. Jul 25, 2011 at 4:06 PM
    yota97
    yota97 [OP] Active Member
    97 Tacoma 4cyl 5 speed
    6 inch Fabtech suspension lift 2 inch body lift K&N cool air intake custom headers Mossy Oak upolstry Wheels and Tires
    so does anyone know how much of a pain it is to change a rear wheel bearing on a 97 tacoma?
  2. Jul 25, 2011 at 4:13 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  3. Jul 25, 2011 at 9:54 PM
    96Taco
    96Taco Well-Known Member
    Alberta
    2014 DBL CAB Tacoma
    I changed my rear wheel bearing. Yes its a pain. You also need access to a press. Just take the whole rear axle shaft out and take it to the shop with ur replacemente bearing. Don't forget you have to cut the collar off the back of the bearing for it to release from backing plate. It took us a while to figure this out. I did my drum breaks and shoes at the same time since everything was pulled apart.
