Wheel bearing question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by awoit, Dec 14, 2010.
  1. Dec 14, 2010 at 4:03 PM
    awoit
    awoit [OP] Well-Known Member
    San Jose, CA
    08 TRD, SR5, Debadged
    URD CAI, Flowmaster super 40, Debadged, 15% Tint all around, 12" sub, amp, and upgraded kenwood headunit,
    When is it time to re-pack the wheel bearings if that needs to be done? and is there a how to on here or anywhere on this?
  2. Dec 14, 2010 at 5:42 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    The bearings are sealed. You cannot grease them.
    If your bearings are making noise or vibration you may need to replace.
    You should put the truck up on jack stands and spin the wheels, listen for noise, and feel for resistance. Grab the wheel with a hand on each side and try to move it side to side. See if there is any play.
  3. Dec 14, 2010 at 5:49 PM
    awoit
    San Jose, CA
    I see
    The reason I'm asking is because i took my truck into toyota complaining about this problem. Even though to me the buzzing noise I am hearing sounds like its near the front wheel thwy diagnosed that the real differential was bad somewhere .. being under warranty they fixed it and put some new pinion and gasket in it, called me to pick it up. On the way home the buzzing started again and now I'm pissed.. called em and told me to bring it back on thursday as thats when the mechanic that originally diagnosed the problem will be working.. I have a feeling it might be a bearing
  4. Dec 14, 2010 at 6:07 PM
    Sampson90
    Sampson90 Well-Known Member
    Maryland
    2005 DC LB
    Sounds like the bearing noise I was having. How many miles are on the truck? Mine started at 45k or so and steadily got worse.
  5. Dec 14, 2010 at 6:43 PM
    awoit
    San Jose, CA
    I'll agree it is happening more frequent then it use to.. I can't tell u when t originally started but its been atleast 5 or 10k miles and I'm at 57k right now
  6. Dec 14, 2010 at 7:19 PM
    romafern
    romafern Well-Known Member
    Rob
    Olympia, WA
    stock and very pissed about the issues
    Machine gun mount. Would love to blow the shit out of it since it has nothing but issues. QA at Toyota USA is shit. Start making them in Japan for Christ's Sake!
    open it up and show us some pics
