Wheel bearing question!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sack17, Jul 14, 2012.
  1. Jul 14, 2012 at 7:49 PM
    Sack17
    Sack17 [OP] Well-Known Member
    Andrew
    Sanibel, FL
    05 Tacoma DBL Cab TRD Sport 4x4
    Bed lights Blacked out sport wheels blacked out emblems BHLM Spidertraxx 1.5" wheel spacers factory roof rack custom yakima wind fairing w/ PIAA off road lights up top snowboard/ski rack surf board pads fog light mod custom interior cup holder l.e.d. lights Bestop topper custom L.E.D. rear facing lights Maglite mod (2 front seats) 3.25" in the front 2.5" in the rear 6 Hella 500ff's (w/ Silverstar's) Silverstar Ultra's in headlights Silverstar Ultra in fogs (retro-fitted 65w 9005's) Hi-Lift (mounted on side of bestop) Shovel (mounted on side of bestop) custom 1.5" body lift
    :eek:
    Okay guys so I've replaced my wheel bearing about 2 weeks ago and now I am still getting a vibration like its my wheel bearing going out again. I popped it back off and when I rotate the bearing in the hub it moves free with no issues. Before I popped it off there was a little play in it but it was def on tight and all the bolts were secure. Has anyone experienced this??
    Thanks guys!
    -Sack
  2. Jul 14, 2012 at 7:51 PM
    Sack17
    Andrew
    Sanibel, FL
    ...and yes I repacked the new bearing with plenty of grease before anyone asks lol
  3. Jul 14, 2012 at 8:26 PM
    Sack17
    Andrew
    Sanibel, FL
    ...after spinning the bearing on the hub assembly off the truck, it feels like there is some play in it. Could the shop that pressed the bearing in not have pressed it in all the way?? I mean I wouldn't think so but then again there is no way it is going out again after 2 weeks I hope to GOD.
  4. Jul 14, 2012 at 8:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    When installed properly it should not.
  5. Jul 14, 2012 at 8:36 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Well its possible to crush plastic cage during pressing. So its possible bearign got damaged but I would not be writting it off, just yet. Did you tightened CV nut t o 173ft-lb? If its not tighten then bearing will feel loose. Try to re-tightening again to 173 and see what happens if its still getting loose then most likely cage is crushed so you will need new bearing.
    BTW sure way to prevent cage crush is to rotate bearing as it is getting pressed.
  6. Jul 14, 2012 at 8:43 PM
    Sack17
    Andrew
    Sanibel, FL
    If the cage was crushed wouldn't it have started making a noise right after I started to drive on it? Because it just started doing it a few days ago...
  7. Jul 14, 2012 at 8:53 PM
    BlueT
    NorthEast
    Not necessary. It had plenty of grease t o chew through and cage may have been crushed but not to the point where rollers where just riding next to each other. Try retightening to 173 and if that does not stop bearing from being loose than you need new one.
    Pressing that thing together is like space shuttle lunch. It needs to sit even, rollers have to spread the pressure so they dont bunch up and crush the cage and it has to be at right depth. Plus peopel forget that new bearings need break in period and they get sited in first few hundred miles. I would say retighten CV nut and see what happens.
    I am almost with 10 000 on mine after they got replaced and they are as tight as new truck has them.
  8. Jul 14, 2012 at 8:57 PM
    Sack17
    Andrew
    Sanibel, FL
    Alright I'll try that and see what happens...so if not can I just take it to a shop and have them press it in a little more?...or has it already sh^t the bed? lol
  9. Jul 14, 2012 at 8:59 PM
    Sack17
    Andrew
    Sanibel, FL
    ...because I have the hub assembly off the truck and I can feel some slight play in the bearing and the hub with out it being on the truck...
  10. Jul 14, 2012 at 9:05 PM
    BlueT
    NorthEast
    Honestly it should be tight, so if its loose most likely has a problem. However, it could be that they had pressed bearing not far enough over the hub hence play. So you can ask them to press in, but easiest test is to have CV nut at 173lbft holding bearing together if its loose like that then is busted. Because that nut is what holds bearing with correct preload. Pressing only gets bearing into the right depth. nut is there to hold it together with out any play.
  11. Jul 14, 2012 at 9:20 PM
    Sack17
    Andrew
    Sanibel, FL
    Gotcha...thank you so much BlueT, I really do appreciate it. When I set the assembly on the garage floor I can see the outter part (on the outside of the black seal) wiggle just slightly and that is where I am getting the play. I'll have to see if I can dig out my torque wrench. Honestly I didn't know that nut had to be torqued to a certain spec I just cranked it as tight as I could with my hand.
  12. Jul 14, 2012 at 9:30 PM
    BlueT
    NorthEast
    :D NP
    Nut has to be at 173 anything less and bearing will be loose and with driving it will destroy itself. but after removing from the wheel it should still be tight, if its loose i hate to say it you may have have to replace this thing again. Dont worry takes few bearing replacements to learn ;)
  13. Jul 14, 2012 at 9:41 PM
    Sack17
    Andrew
    Sanibel, FL
    Yea this is the 2nd time I've done this haha I'll tell you what I just did...prolly not the best thing to do but it is not wiggling anymore...I set the assembly on the ground and smacked it with a mallet hammer, with a piece of wood flat across the surface and wacked the hell out of it...and its not wiggling anymore haha
  14. Jul 14, 2012 at 9:48 PM
    BlueT
    NorthEast
    :D Desperate times call for desperate measures.
    Hopefully it just needs preload.
  15. Jul 14, 2012 at 9:54 PM
    Sack17
    Andrew
    Sanibel, FL
    True that I'm suppose to be driving back home to KY tmrw from Florida (about 13 hours) haha I may have to order from rockauto again on the way home if not lol
  16. Jul 14, 2012 at 9:59 PM
    BlueT
    NorthEast
    You can probably get cheap one from autozone. Your problem is gogin t o be getting seal that goes between hub and wheel bearing.
  17. Jul 15, 2012 at 2:49 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I wouldn't drive on it. Have you ever seen a bearing weld itself to an axle or hub. It's ugly...
  18. Jul 16, 2012 at 4:38 PM
    sfoxwoody
    sfoxwoody Well-Known Member
    Calhoun, Ga
    05 TRD Sport, 4x4, BSP, LB
    none yet
    I just replaced my passenger side bearing, and the vibes were worse after I put the new one on. I talked to the parts store and they ordered me a new one, said sometimes they are bad, they even pressed them for me at no charge! Only problem is its still vibrating, now what?
    I also just installed Billies set at 1.75", but I drove it a few days before I replaced the bearing and no vibes untill the bearing was replaced
