Wheel bearing replacement questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, Jul 4, 2019.
  1. Jul 4, 2019 at 11:21 AM
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    After only 20k miles, I have a wheel bearing going bad.
    I paid someone to do the last set. But this time I’m going to tackle it myself.
    Question 1.
    The noise gets substantially QUITER when turning left.
    If I remember correctly, this it typically an indicator of a failing LEFT front bearing?
    Question 2.
    What are you using to torque the 4 hub bolts?
    I’m not seeing a way to get a Torque Wrench on those bolt.
    Not sure using crows foot is a wood idea at risk of rounding the head of the bolt off?
    Do you just get it good and tight and “roll with it”? Lol
    Question 3.
    What type and Where is a good place to get the new bearings?
    Any other tips are much appreciated.
    Thanks in advance for the help guys:)
  2. Jul 4, 2019 at 12:30 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Q1. Negative. Generally, it's the opposite bearing because the bad bearing is sustaining the weight transfer, which quiets it. Thus, in your case, the passenger side bearing is likely the bad bearing.
    Q2. Crow's foot will work. It worked for me. I don't remember the torque setting; maybe 50 or so.
    Q3. I have DuraGo. But, there are many other vendors. Avoid Dorman bearings, but many use their hubs with no issues.
  3. Jul 4, 2019 at 12:53 PM
    HillJackJDS
    HillJackJDS Well-Known Member
    Dale
    2008 Tacoma 4WD
    I hope I never have to do mine again, but I did but the 6 point impact 35mm axle nut socket. Hindsight being 20/20, if I were you and had the time before undertaking this job, I would put some penetrating oil on the bolts that hold the calipers on. Mine were unreasonably tight/rusted in place.
  4. Jul 4, 2019 at 3:20 PM
    TnShooter
    Deogee
    STOCK
    Are you sure on the sound diagnosis?
    All I have read and and seen, say that:
    “If turning left and the noise is louder. It is the right front bearing”
    As a left turn places a load on the right front bearing and causes it to get louder.
    Maybe @Jimmyh can help us out?
    As for the bearings. Yes, I’ll do hubs and all.
    Thanks for the heads up on a Dorman.
  5. Jul 4, 2019 at 3:23 PM
    TnShooter
    Deogee
    STOCK
    I have all the stuff to do it.
    I planned on doing it myself last time.
    But the plan went south..... No time, No Place, and obtaining some parts difficulty.
    Hopefully nothing on mine will be stuck.
    Seeing as it’s been less than 20k and 16 moths since the last set where pit on.
    Thanks for the info.
  6. Jul 4, 2019 at 3:28 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    REDdawn6, Kolunatic and TnShooter[OP] like this.
  7. Jul 5, 2019 at 3:00 AM
    Chuy
    Lakeside, CA
    Silver Taco
    Depends on type of bearing failure. If it's humming due to increased tolerances, the tolerances tighten up when turning into it. If bearing has broken race/bearings, a grinding noise may get louder when lifting pressure from it.
    It may be easiest to remove the tires and brake calipers, but leave the rotor on and use a couple lugs to tighten them. Spin the rotor by hand to feel for grinding, and pull the rotor side to side to feel for looseness. Only 20K on both? Might something have cause the failure? A bad CV joint can also make sounds and disappear when turning. Also sticking caliper piston, or debris caught in the brakes. BTW, 59 ft/lbs is the torque for the 4 bolts.
  8. Jul 5, 2019 at 4:37 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    You should be able to jack up the front end and try to wiggle the tire with hands at the 12/6 o'clock position along with spinning the tire to hear abnormal noises to check for failures of the WB. Regardless of which side you think it may be, always replace in pairs.
    RobZ9132 and DrFunker like this.
  9. Jul 5, 2019 at 6:52 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    lots of good advice here along with other threads. the job is much easier than you realize and likely wont take up more than short afternoon. i replaced only my front driver side and my passenger side has still been going strong a 100k miles later, but the advice to change both sides at once has some decent logic behind it.
    honda50r likes this.
  10. Jul 5, 2019 at 7:26 AM
    memphis guy
    memphis guy Well-Known Member
    Nashville
    PreRunner TRD Off-Road
    Michelin LTX M/S II 265/75-16 Tires (+1 sidewall height)
    215,000 miles on my 2007 (PreRunner V6, highway miles, no off-road use, very little towing or hauling).
    I think I can hear my front wheel bearings a little bit.
  11. Jul 5, 2019 at 7:27 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I have these torque adapters. They don't get used that often but are several years old and holding up great.
    https://www.amazon.com/Tools-93222-Metric-Torque-Adaptor/dp/B00NABVES8
    It's probably the passenger wheel bearing. If it's far enough along you'll be able to rotate the wheel and hear it. If you're having trouble diagnosing it with the pads dragging, you can remove them easily, just pull the two pins and the pads come out without removing the calipers. If you buy the hub and bearing assembly it's an easy job. The caliper bolts will be tight- the torque is 90+ lb-ft.
  12. Jul 5, 2019 at 7:35 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Passenger bearing is culprit if it quiets turning left. I suggest doing both bearings as the other side will be shortly behind it. Use Timken bearings and seals. You have an outer seal between hub and bearing, an inner seal between spindle and CV if you're 4wd, and an Oring between bearing and spindle that you can get anywhere if you know the size, or from dealer for pretty cheap. If 4wd, torque CV nut to 173ft#'s or you wont get proper bearing preload. If 2wd, you'll need the adapter to fit on the hub nut, and I forgot the torque spec there, but it's easily found, and replace that hud nut if 2wd. Then stake it once it's torqued. I personally get the 4 bearing bolts just good n snug with a very small drop of loctite on the threads. Brake caliper bolts are 91ft#'s, lug nuts are 83ft#'s.
    Austinguy and Blockhead like this.
  13. Jul 5, 2019 at 8:22 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I usually go with the logic then again they may not have been properly lubricated prior to installation or they could have been improperly assembled which is an even bigger reason to do both. I'm also not a big fan of non-oem, but last I remember there are several member vendors that sell quality pre-assembled hubs.
    Oh and if I were going with a crows foot I would use one of the ones above with the boxed end 6 point. Just make sure you calculate for the offset properly.
    http://www.cncexpo.com/TorqueAdapter.aspx
    https://www.engineersedge.com/manufacturing_spec/torque_wrench_1.htm
    PzTank and TnShooter[OP] like this.
  14. Jul 5, 2019 at 11:56 AM
    TnShooter
    Deogee
    STOCK
    Thanks for the advice everyone.
    The ones I have in now are supposed to have Koyo bearings.
    I believe I paid around $350 for the set + extra for new dust seals.
    I attempted to get OEM, but they were really expensive at the dealership.
    Going to have to see if I can source OEM. My OEM ones lasted 100k
    These new ones......lol... not long at all.
    Thanks again everyone.
  15. Jul 5, 2019 at 3:30 PM
    Muddinfun
    Muddinfun Well-Known Member
    I'm gonna guess that whoever replaced the bearings didn't bother replacing the inner seals. There are 2 inner seals per side. 1 goes on the CV joint and the other goes in the knuckle. 1st line of defense keeping water out and 2nd line of defense. If the original bearing failed bad enough that the hub was flopping around, it definitely damaged the seals.
    TRDZILA likes this.
  16. Jul 5, 2019 at 8:50 PM
    TnShooter
    Deogee
    STOCK
    Both seals were replaced.
    The O-ring and Rear.
    The rear one required the spindle to be removed from the axle.
    The old ones were not completely worn out.
    Road noise was heard but very little tire/wheel movement.
    Muddinfun[QUOTED] likes this.
  17. Jul 5, 2019 at 9:14 PM
    Levalexi
    Levalexi Well-Known Member
    Southern Maine
    07 Tacoma access cab 4x4 2.7l
    As far as rusted rotors go, there's 2 bolt holes for this very reason. I put a 12mm bolt I got from the air filter box and it popped right off. Had I realized that, it would have saved 30 mins of trying different things to get it off....
    TnShooter[OP] likes this.
  18. Jul 6, 2019 at 10:58 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I know it's a different vehicle but on my Corolla, I thought it was one side and it was the other. I couldn't tell by wiggling the wheel and tire assembly.
    I jacked the car up and took both rear wheels off. Just turning the hub by hand, I could feel that one was not as smooth as the other. That's the one I changed and the vibration/noise went away.
    Blockhead, Crom and TnShooter[OP] like this.
  19. Jul 6, 2019 at 11:32 AM
    Chuy
    Lakeside, CA
    Silver Taco
    If bearings are extremely worn, yes. Otherwise, any slight movement can be attributed to normal suspension tolerances - tie rods mainly. And a noise when spinning the tire will likely be the brake pads dragging on the rotor. It's best to remove everything to where you are spinning the axle on the bearings with as little non-bearing component interference as possible.
    When using crowfoot wrenches, or any torque wrench extension, you don't need to adjust torque settings if the crowfoot/extender is installed on the torque wrench at a 90 degree angle.
  20. Jul 9, 2019 at 7:29 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    DCSB 12 slightly lifted Tacoma
    Ripped off all four mudflaps. Scratches all down both sides 6112’s up front on 3rd notch 5100’s in back with Toytech 1” block Skids & sliders from SOS Concepts I got rid of the 1” block and put on Wheelers 1 1/2” progressive AAL. SPC UCA. Be sure your standing on the drivers side when reading the instructions! I swapped sides so many times that I can swap UCA’s in 15 minutes. I put in the 3/4” spacer to eliminate the Taco Lean, and just got my 4th alignment. Traded the OEM rims for 17” Sport rims and a bora bora 1” spacer. I got my Firestone 285/70/17 MT2’s. Pelfreybilt gas tank skid and hi-lift jack should be here Friday. Looking at bumpers, but I think they will wait for next year. So far I’m happy with my build. I’ve done it all myself, leading to a lot of cussing and frustration, but it’s all mine.
    Why avoid Dorman?
    Looking for torque specs to put my stuff together with a Dorman hub assembly,,, and now I see the warning.
