Wheel bearing replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by STLTaco09, Jan 23, 2012.
  1. Jan 23, 2012 at 10:29 AM
    STLTaco09
    STLTaco09 [OP] Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
  2. Jan 24, 2012 at 5:51 AM
    STLTaco09
    Bump, curious if anyone has any info on this part?
  3. Jan 24, 2012 at 7:01 AM
    jgray
    jgray Well-Known Member
    josh
    boyds,md
    05 Ext.cab "murder was the case"
    Aero turbine sidepipe 3" pipe Murdered out 3"revtek leveling kit 33's
    The bearing and hub assembly are both sold separate either way new bearing has to be pressed into the new hub. Just went through this hassle the other day my passenger side wheel eating raring went bad
  4. Jan 24, 2012 at 7:02 AM
    jgray
    josh
    boyds,md
    Fuckin iPhone autocorrect wheel bearing**
  5. Jan 24, 2012 at 10:50 AM
    STLTaco09
    Doesn't that part look like it has the bearing already pressed in?
  6. Jan 24, 2012 at 10:51 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Nope. That needs to have the hub pressed into it.
  7. Jan 24, 2012 at 10:52 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.03CUPID
    1.03. Kbro2s. ICONS.
    I'm looking more into this for you, they usually don't come pressed in.
  8. Jan 24, 2012 at 10:57 AM
    dYL0n
    Dyl0n
    New Orleans, LA
    If you buy OEM from Toyota, you'll get the whole assembly:
  9. Jan 24, 2012 at 11:00 AM
    dYL0n
    Dyl0n
    New Orleans, LA
  10. Jan 24, 2012 at 11:07 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    and raped
  11. Jan 24, 2012 at 11:39 AM
    dYL0n
    Dyl0n
    New Orleans, LA
    yep
  12. Jan 24, 2012 at 2:02 PM
    STLTaco09
    I obviously don't know 100% what I'm looking at. There has to be a decent aftermarket solution that has the bearing pressed in already.
  13. Jan 24, 2012 at 2:46 PM
    mjp2
    NJ
    That's the aftermarket solution is to purchase a shop press with the money you save buying just the bearings from a vendor rather than the entire unit from Toyota. Do the work yourself and now you have a tool you can always use in the future.
  14. Jan 24, 2012 at 3:11 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    x2. Or, do what I did on my friends element, buy the bearing and bring it somewhere to get pressed. They charged her $8.76 exact. Just bring in the spindle and bearing and tell them what you need. Not sure if autozone still rents out the press.
  15. Jan 24, 2012 at 3:14 PM
    XXXX
    sKiP
    05 Prius
    Leave the spindle at home all you need is the old hub (bearing inside) and the new bearing. Press out old - press in new. I paid $20 from my local NAPA and they had it done before lunch.
  16. Jan 24, 2012 at 3:18 PM
    MQQSE
    MQQSE Random Member
    Rob
    Palmer, AK
    FWIW ... local machine shop pressed both of mine (driver and passenger side fronts) for $40 total. Money well spent IMHO.
  17. Jan 24, 2012 at 4:40 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    yep hub, my bad
  18. Jan 24, 2012 at 4:57 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Or you can make your own press with a jack and some spare junk lying around your garage. :p
  19. Feb 12, 2012 at 9:11 AM
    dYL0n
    Dyl0n
    New Orleans, LA
