Wheel bearing tolerence and replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by netman86, Apr 30, 2015.
  1. Apr 30, 2015 at 10:57 AM
    netman86
    netman86 [OP] Well-Known Member
    Maine
    99 flatbed, 2013 quad cab
    So I just failed the ever stupid Maine state inspection sticker tests.
    One of the things I failed for was both front wheel bearings.
    I jacked her up and had a go- there's no in/out play, no left/right play, and just a hair of play from top to bottom. I've driven far worse for many years.
    I picked up bearings from napa- they gave me two small boxes per wheel. I've not looked inside yet.
    Does anyone know offhand if the bearings are pressed or not? I've got a press, but knowing ahead of time means planning accordingly!
    I pulled the inspection guide and it reads:
    "Reject vehicle if the bearing's end play exceeds the manufacturer's specifications."
    Helpful, right?
    I've got a feeling that shop was just playing me to get extra labor and replace the bearings themselves. The inspection system is a scam- but theoretically that hair of play could be outside of "manufacturers specifications". Does anyone know off hand?
    Happy to replace the bearings if that needs to happen, but I'm getting real tired of these shops screwing me.
  2. May 1, 2015 at 2:48 PM
    BamaToy1997
    Bill
    Navarre, FL
    Yes, the bearings are pressed in. They need to be done by someone with some experience on Toyota, as not to screw them up. I have had to replace bearings many times because someone didn't know the right process, or didn't have the proper tools. It can be done if you have your own press though.
    As for their inspection, I have NEVER seen a state inspection that ever referenced wheel bearings in my LIFE. I would call BS on that one and ask them to give you not only the rule that shows they can fail you for bad bearings, but the actual reading that they had that shows your bearings were bad.
  3. May 1, 2015 at 2:53 PM
    BamaToy1997
    Bill
    Navarre, FL
  4. May 1, 2015 at 3:10 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    subbed for outcome. I think they are screwing with you
  5. May 5, 2015 at 5:07 AM
    netman86
    Maine
    Yep- they were screwing with me.
    Went to another shop and they brought me in to show me why I was failing- lower ball joints had significant vertical play.
    Replaced the balljoints and got a sticker.
    Sigh. Maine inspection is BS- but I'm glad they caught the ball joints before they broke.
  6. May 5, 2015 at 5:15 AM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    Glad it worked out that way. LBJs are not too bad a job to swap. Wheel bearings are one of the worst jobs on these trucks.
  7. May 5, 2015 at 6:23 AM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    "I. Wheel Bearings (1) Reject vehicle if the bearing’s end play exceeds the manufacturer’s specifications. (2) Reject vehicle if roughness or noise is evident during wheel rotation. (3) Reject vehicle if binding or roughness is detected while rotating bearing. (4) Reject vehicle if the bearing adjustment locking device is missing, not engaged, or not functioning."
    Its in that PDF.
    Glad you got your truck to pass though. Maine has an effed up inspection.
    SR-71A likes this.
  8. May 5, 2015 at 6:32 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I'm just gonna go with BamaToy's already done hub/bearings and be done since mine is starting to make odd rumble up front, sounds like from passenger side. New order for 2 coming to someone's online store very soon.............
