Wheel Bearing Woes
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nick_kellog9, Mar 21, 2024.
  1. Mar 21, 2024 at 11:02 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Ohhh I have watched tht vid + 5 more
    Just can’t look forward to the job
    (Everything good ………this month….u know)
    Kinda mentally preparing
    20yrs? I like your style and how many times you’ve been around the Sun.
    (Same Here)
    I do know this
    The absolute best seller of any vehicle…..is an aeronautic mechanic
    Period. End of Story.
    Buyer better buy, buyer will never find a better maintained vehicle.
    thanks man….when that rear bearing starts humming…..going to reach out
    Nick_kellog9[OP] and leid like this.
  2. Mar 22, 2024 at 9:45 AM
    Nick_kellog9
    Nick_kellog9 [OP] Well-Known Member
    Nicholas
    Eastern Shore MD / Daytona FL
    2002 Supercharged 5MT Lunar Mist
    OME's Firestone Destination AT/2 265/70r17 Nomad 501SA Convoy Salt Baja Designs Squadron Sport/S1 Leer Camper JBL/Pioneer Stereo
    Thank you for the heads up!
    I'll pass that along to them when I get it done.
    leid[QUOTED] likes this.
  3. Mar 22, 2024 at 9:48 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Glad you arrived on this choice- as it's by far the most cost effective if you don't already have the press.
  4. Mar 22, 2024 at 5:26 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    I thought about this for rear wheel bearings. Fully loaded drop it in and you can spec new brakes or not. Even if you bought all OEM and charged $100 for labor I bet people would them.
  5. Mar 23, 2024 at 10:50 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah they changed the design of that seal.
    So it is real important to study those Timmy vids very carefully....
    He does that grease test to tell exactly where that edge lip of that seal rides right in the very center of that ring...
    He accomplished that work-a-round fix by flipping that retainer ring backwards...
    The 4 runner people are very aware of this problem.
    I did mine with his 'Mr Coffee mod' and two years out with no leaks.
    For all you running old diff fluid......that is eating that seal alive.....along with the drive shaft one....
  6. Mar 24, 2024 at 7:04 AM
    tacoman2001$
    Clogged diff vents are half the problem. They get all gunked up and when the fluid heats up it pushes past the seal and leaks.
    ControlCar likes this.
  7. Mar 26, 2024 at 8:50 AM
    Nick_kellog9
    Nicholas
    I've received my parts in the mail.
    Includes:
    Koyo Bearing
    Two seals
    Snap Ring
    Hub
    Nut
    Do I need to give any special instructions to the shop? Should I provide them a diagram of the assembly?
    The spindle is currently "assembled", meaning that the hub is attached, all seals are attached, the brake shield is in place, etc... Should I be able to bring this to the shop and provide them the new parts and have them press it/reassemble?
    Thanks in advance! Just want to get this thing on the road.
  8. Mar 26, 2024 at 10:16 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Call and ask if including an FSM page would be helpful for them or not :notsure: Just make sure to ask in a tone that's not insulting.
  9. Mar 26, 2024 at 10:43 AM
    Nick_kellog9
    Nicholas
    I'll definitely do that just to make sure. I just want to make sure it goes back together the right way the first time and seeing as how these aren't necessarily the most common jobs I figured it could help.
    Thanks!
    Nick
  10. Mar 28, 2024 at 5:32 PM
    Nick_kellog9
    Nicholas
    Update:
    Got the spindle back from the shop today.
    They said it went on no problem.
    Re-installed the spindle in the truck, the bearing felt a little tight not too bad. This is after re-installing the axle nut etc...
    I took it for a drive, everything seemed ok, except that the brake shield was bent and I had to re-bend it away from the hub or whatever it was rubbing on.
    Seemed fine, brought the truck home, felt the hubs. Left one (good one), was warm but basically cool to the touch.
    The one that was just pressed in was HOT. Like burn your fingers hot.
    Any ideas?
    No play in it or anything just really hot.
    Really need to get this thing sorted out.
    Thanks!
  11. Mar 30, 2024 at 8:09 AM
    Nick_kellog9
    Nicholas
    Update all,
    fixed up!
    replaced the inner oil seal, removed and lubricated caliper.
    no more extreme heat.
  12. Mar 30, 2024 at 9:11 AM
    Hotdog7
    Hotdog7 Well-Known Member
    Fred
    1gen Tacoma
    Toytec 2.5-3" lift 2010 rims wheel spacers tundra brake upgrade
    Great news guessing it was caliper?
