Wheel Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTL Tacoma, Feb 17, 2011.
  1. Feb 17, 2011 at 4:58 AM
    MTL Tacoma
    MTL Tacoma [OP] Well-Known Member
    Montreal, Canada
    2016 DC LB TRD Sport
    Hey Guys, have any of you replaced a wheel bearing on your trucks?
    I have a 2008 TRD w/ 70000+miles and had to change one last week.
    Is it common for our trucks or am i just unlucky?
  2. Feb 17, 2011 at 5:36 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    that sounds pretty normal...I think the whole sealed wheel bearing design has become a problem accross the board.
    Howard
  3. Feb 17, 2011 at 5:41 AM
    SuthrnTaco07
    SuthrnTaco07 Well-Known Member
    Kyle
    Huntsville, AL
    2003 T4R SR5 V8 4wd
    None
    What if you haven't changed one and you have just over 74,000... oops?!
  4. Feb 17, 2011 at 7:05 AM
    hetkind
    Howard
    Johnson City
    Jack up the truck and wiggle the wheel, 12 and 6, and 3 and 9. ANY play needs to be investigated. If the the play is the same 12 and 6, and 3 and 9 it is likely a wheel bearing. Spin the wheel and listen for noise or harshness.
    Howard
  5. Feb 17, 2011 at 7:07 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    how much are these to replace?
  6. Feb 17, 2011 at 8:47 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    it depends. One axle has bearings you can pull or push into the bearing plate the other I seem to remember doesnt.
    THey're like a bill or 2 a wheel unfortunately if you get the full on bearing assembly from toyota. Like 20 if you can press or pull out the old bearing.
