Wheel bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by climber-420, Jun 29, 2009.
  1. Jun 29, 2009 at 4:33 PM
    climber-420
    climber-420 [OP] I love tight cracks
    CO
    2004 Gold Ext Cab TRD 3.4L V6 Manual
    255/85/16 BFG KM2's, 3" OME lift, Dakar's, Nitrochargers, Grey Wire Mod, ARB Bumper, ARB CKMA12 air compressor, WIts End Pacifier, Warn M8000, Uniden 520 XL CB, rear diff breather mod, full time power to aux 12V outlets, Rago Fab ditch brackets, Titan Rod Vault, Extreme LED's front and rear,
    Went to have my oil changed today at Meinike(spelling), and the mechanic told me about the wheel bearing, something had to do with the tire being able to move up and down. Showed me on one side, but not the other, b/c all the tires were off except the passenger side up front. Anyone had problems with this, or think it was just a gimmick.
  2. Jun 29, 2009 at 4:34 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    what exactly do you mean "tire being able to move up and down"?
  3. Jun 30, 2009 at 8:47 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    Install a new bearings and youll see that the tires wont move/wiggle like that anymore. I just did my fronts, Easy job and under 100 for all 4 on my 5 lug. The rears are more expensive, I actually need to repack mine soon.
  4. Jul 1, 2009 at 6:01 PM
    saltbranch
    saltbranch Well-Known Member
    Tx
    1996 2.4,2wd,5spd, stock, 250k
    Does an 03(from profile) have sealed bearings? My 96 does not, have not owned a newer Yota yet. I just repacked my bearings today-PM maintenance. My taco is a 2wd daily driver with 237k on it.
    Things that come to mind to allow the wheel to move up/down
    -wheel bearings
    -ball joints
    -lug nuts loosened up just abit to allow rim to move
    I dont trust mieneke type shops myself, but thats me.
    I try to repack my bearings every 50k give or take a few thousand miles, factory bearings still in my truck.
  5. Jul 1, 2009 at 7:46 PM
    Robbsolid
    Robbsolid Zombie Killer
    ABQ, N.M.
    02 PreRunner SuperWhite DBL Cab
    Plastic X'd Flares, deck plate mod, Thrush welded muffler, graphite painted wheels, relocated turn signals, fogs in bumper
    could bad bearing cause highway shakes? ball joints? Im still plagued witth the horrible highway shakes :(
  6. Jul 1, 2009 at 7:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    its very possible. both could cause vibrations. have you had the tires road forced any?
  7. Jul 1, 2009 at 8:12 PM
    Robbsolid
    ABQ, N.M.
    not even sure what that is.. so no lol. ]Ive had my tires balanced and the vibration is still there
  8. Jul 2, 2009 at 4:51 AM
    saltbranch
    Tx
    What do you mean by hwy shakes? Like a tire out of balance?
    I recently had a set of tires go bad, They started to seperate from the inside. They would not balance out. I replaced 2 and then about 2 months later had same trouble w/other 2.Replaced them, no more shakes.
  9. Jul 2, 2009 at 6:16 AM
    Robbsolid
    ABQ, N.M.
    yes, it feels like the tires are slightly out of balance, they are pretty new tires too. sometimes it feels like the steering wheel has a up and down shake instead of the side to side shake when the tires are unbalanced
  10. Jul 2, 2009 at 12:52 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    try getting the tires road force balanced......it may take care of that problem.
  11. Jul 3, 2009 at 11:16 AM
    aacomi
    aacomi Member
    Red Bay, Alabama
    2005 SR5 tacoma 4x4
    Can the wheel bearings cause a roaring noise in the front end? 69,000 miles on DC 4x4 05'. The rims are enkei rims that were on it when bought new.
  12. Jul 3, 2009 at 9:11 PM
    saltbranch
    Tx
    Yes they can/will cause a roaring noise, faster you go the louder it will get. Should be able to jack up each side and turn wheel by hand to determine which side. I had an 04 Dodge 3500 diesel with sealed front bearings go out at 30k miles on passenger side. Driver side lasted to over 200k, go figure.
  13. Jul 4, 2009 at 6:24 PM
    aacomi
    aacomi Member
    Red Bay, Alabama
    2005 SR5 tacoma 4x4
    thanks......it just seems wierd....toyota dealership tried to apply it to the fact that there were enkie rims that they had on it new when I purchased it......68,000 miles and the bearing goes out.....right after the power train warranty is bonked something happens......Thanks again
