Wheel Bearing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jaymac10, Aug 28, 2024.
  1. Aug 28, 2024 at 11:23 PM
    jaymac10
    jaymac10 [OP] Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I'm starting to get a humming sound that I can sometimes feel. I'm guessing it's probably a wheel bearing going based on some previous threads.
    How does one verify/check if bearings need replacing? My truck only has 106k miles.
    Thanks!
    Marc70 likes this.
  2. Aug 28, 2024 at 11:47 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    One way is to lift the truck up so the tire is in the air, grab the tire at 6 and 12 o clock, and see if there is play.
    Another way is to load up the bearing and see if the noise goes away. What’s that mean? Let’s say it’s the front right tire. When making a sweeping left turn, like a freeway ramp, the truck will lean to the right, putting pressure on that bearing. It takes up the slop and the noise/vibrations goes away.
    Those have been my two go-to, but they’re not all inclusive. If those are original bearings, you’re likely on the right track. I wouldn’t be surprised if it’s the culprit.
  3. Aug 29, 2024 at 8:27 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I wasn't able to detect any play in mine when the wheel was off the ground, nor did it have a noticeable change in hum when swerving. Both are methods I've used successfully on my other vehicles. I decided to change them anyway and it did solve the hum, point being you might not always find a smoking gun when looking for a problem with the wheel bearings, at least not at first.
    jaymac10[OP] and wi_taco like this.
  4. Aug 29, 2024 at 2:18 PM
    racer1x
    racer1x Well-Known Member
    campbell ca
    05 Taco
    Too many
    I've rarely gotten any substantial play out of any of my wheel bearing before noticing that they were bad. I typically check them by taking off the rotor and spinning the hub with nothing attached to it. The bearings will feel gritty or dry like there is a lack of grease in the bearing. If your are getting play in the bearing they are way far gone; you should be able to detect a bad bearing a lot earlier than that.
    jaymac10[OP], wi_taco and Marc70 like this.
  5. Aug 29, 2024 at 4:12 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    For me it was noise and vibration. If it’s pretty consistent or at least linear relative to your speed, probably a wheel bearing. If you’re getting vibration mainly at medium speeds it might be your needle bearing.
    jaymac10[OP] and ridefreak like this.
  6. Aug 30, 2024 at 10:42 PM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Thanks guys, the hunm and vibes are most prevalant between 60-80km/h. I got up to 120km/h on the highway the other day and the humm seamed less obvious. I'm guessing becsuse other sounds got louder.
    I'll try to jack the truck up tomorrow and see if i can find any play and report back.
    Cheers,
    Jsy
  7. Aug 31, 2024 at 6:04 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Typically, like stated above, it's hard to notice play unless the bearing is severely wrecked. I find it much easier to spin the wheel by hand in the air and listen for noise, watch for excessive drag, or feel for vibration or grinding. It may help to compare it to the opposite side too.
    vtown and jaymac10[OP] like this.
  8. Aug 31, 2024 at 6:31 PM
    AZCFII
    AZCFII Well-Known Member
    2009 DCLB
    OME Susp.kit, ARB front bumper, Cooper AT3's, Alu-Cab canopy
    I just replaced both front wheel bearings about a week ago. Over the previous year and a half I noticed more noise and vibration from the left front it finally got to where it would consistently go away when turning right. You still couldn’t detect any abnormal movement at 6/12 or 3/9 with the wheel off the ground. After replacement all vibration was gone. I cut the old bearing and found significant brinelling (race looked like a washboard road). I know there is one more bad bearing at the differential on the drivers side. I’ll be replacing it with the ECGS bushing when my RCV axels arrive.
    Hook78 and jaymac10[OP] like this.
  9. Sep 5, 2024 at 7:36 AM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Finally got the truck up and spun all the wheels. They all seemed ok... Therefore, i'm now pretty certain that its the needle bearing thats toast. Lots of sloppy play in the plastic cover.
    Will be replacing it with the ECG bushing.
    Will my axel need replacing as well if needle bearing went bad?
    Also, is there anywhere in Canada that sells/ships the ECG bushing?
    Thanks!
  10. Sep 5, 2024 at 8:06 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Your axle isn’t necessarily toast just because your bearing is. Most people including me, that have posted here, have just replaced the needle bearing.
    Does ECGS not ship to Canada? Give them a call and see what they can do. If not you’re welcome to have it shipped to me (I’m two hours away from ECGS) and I will reship to you.
  11. Sep 5, 2024 at 7:34 PM
    ShimStack
    Ben
    NC
    You can confirm this diagnosis by verifying it goes away in 4wd.
    Axle will be fine.
  12. Sep 5, 2024 at 11:24 PM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Thanks a lot for the offer man, much appreciated! I was able to pick up everything I needed on my drive from Kelowna to the lower mainland today at https://overlandoutfitters.ca/. Also picked up some JD Fab UCAs so will get it all done at once.
    Hook78[QUOTED] likes this.
  13. Sep 5, 2024 at 11:29 PM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I'll have to confirm again, but I feel like I've tested it already and the sound didn't change when switching from 2wd to 4wd. Which is why I originally thought it was my wheel bearings. But given my truck is lifted 2.5', the needle bearing is an obvious issue that should be addressed no matter what. As soon as I get it installed, I'll report back if it solved the issue. My 2013 only has about 106k miles with light hunting FSR roads at times, so wheel bearings "should" be ok for now...
  14. Sep 6, 2024 at 5:10 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    When I checked my wheel bearings, I was looking for play in the bearing as opposed to noise when spinning. I grabed the wheel at 12 and 6 o'clock ....and then at 3 and 9 o'clock, while lifted off the ground, and tried to wiggle the wheel. In mine there was play indicating the bearings were bad.
    My bearings were replaced at 140K km, a little less than you current mileage. I replaced both sides, but the driver side was in terrible shape.
    jaymac10[QUOTED][OP] likes this.
  15. Sep 6, 2024 at 9:35 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    My experiences/observances regarding wheel bearing replacement. Note that as a DIY guy, my experience is limited to my own/my family's vehicles that have been a mix of coupes, sedans, and pickup trucks.
    1. I have never PERSONALLY come across a situation where a wheel bearing was bad enough to actually have discernible play in any direction from any clock position.
    a. The one time I discerned any play, it actually ended up being in the ball joint.
    2. The adage about "if the noise increases when you do a sweeping turn at speed, it's the wheel bearing on the opposite side, because you increase the load to that side" (ie. if the noise increases when doing a sweeping RIGHT on the highway, it's the LEFT bearing because what is happening is the the weight is being transferred to the left of the vehicle and the right is being unloaded), has only worked once out of about 8 or so wheel bearing swaps.
    a. My PERSONAL theory is that the adage is from days when bearings were caged conical bearings, whereas "modern" wheel bearing have dual captured bearings (each sealed bearing has captured bearings on both sides within a small distance of each other, so weight transfer isn't as relevant as it used to be as far as any increase in noise) - at least that's MY theory.
    3. One method that has worked once (both times front bearings) was to lightly hold the strut spring midway while spinning the wheel. The rough bearing/race was amplified by the spring, and I could readily feel more vibration on the "bad" side.
    4. There is no way to consistently/accurately determine which bearing is bad by having someone sit in various seats to see if they can tell which point the noise is coming from. This is because of how noise, especially ones caused by vibrations, etc., can travel through the body and/or chassis and sound like it's coming from somewhere it's NOT.
    SO, I got a ChassisEar off Fleabay a few years ago, and it has accurately diagnosed the correct wheel bearing (including a couple of times where it showed it WASN'T a wheel bearing).
  16. Sep 6, 2024 at 10:23 AM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Thanks so much for your information! I've now flip flopped from needle bearing (which should be replaced no matter what with my lift) back to wheel bearings... uuuhhh
    On my driving home today the hum and vibes seem to be the loudest at around 70km/h. I decided to do a bunch of tight slalom turns back and forth along a strait stretch of road. When turning left, the hum is loud, when turning right, the hum goes away.
    Question, what was the issue when it wasn't your wheel bearing?
  17. Sep 6, 2024 at 10:26 AM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    My front passenger side wheel bearing is bad. Indicated by a humming, sometimes growling sound of low intensity. I generally find that when the bearing is UNLOADED (so when I turn to the right) that the sound goes away.
    In any case, jacked up, it has play when grabbing the tire at 12 and 6. New one ready to go in hopefully this weekend.
  18. Sep 6, 2024 at 1:19 PM
    tak1313
    2013 Base 2WD
    The one time I discerned play while grabbing the wheel and it WASN'T the wheel bearing, it was play in the lower ball joint.
    Edit - that was the one time I could detect PLAY, and the PLAY was because of the BJ. There WAS a bad wheel bearing as well, that was the OTHER SIDE.
  19. Sep 11, 2024 at 9:51 AM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Just bumping this back up for further advice. Being in Canada, what wheel bearings are good to source/buy from? I'm not sure where my local shop gets their products from so just want to be informed. I think Napa is ok?
    Thanks!
  20. Sep 11, 2024 at 12:34 PM
    TacoTuesday1
    SD CA
    you just verified it.
    the guy on here who sells them using high quality parts.
