wheel bearings and abs ring(or whatever you call it)
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaman06, Jul 7, 2010.
  1. Jul 7, 2010 at 2:38 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    when i had my one spindle of a while back...was gonna replace the bearings, but my buddies shop didnt have a big enough press.......but i noticed on the inner side of the spindle...up against the bearing...there is a part of the abs system....looks like a gear or something....and me or my buddy couldnt figure out how the hell to get it out. any ideas on this??
  2. Jul 7, 2010 at 4:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The ABS speed sensor rotor. IIRC, It presses into the assembly.....I cant remember for certain.
  3. Jul 7, 2010 at 5:54 PM
    biggdog747
    biggdog747 Well-Known Member
    MI
    taco
    to get it off you will destroy it. you have to replace it at the same time you replace the bearing. and before you take any of it apart measure the distance be the tone ring and the metal backing plate. there is not a stop or anything for it to rest against. after you press the bearing and stuff back on you have to press the tone ring back on. if you are off at all the abs sensor will not read it and you will have to buy a new tone ring and do it all over again.
  4. Jul 7, 2010 at 6:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    damn.....thats looks like its gonna be a royal pain in the ass there.
    wonder if i can ditch the abs system altogether???:D but seriously.......
  5. Jul 7, 2010 at 6:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    how about this............one of those sharp needle deals that you can get for the end of a grease gun............couldnt you re-grease the wheel bearings that way instead of having to press out/in with new ones?? wouldnt that make them last longer?? mine are starting to kinda chirp when i come to a stop(im guessing its them anyway....kinda a screeching noise). i gotta replace my damn calipers soon...but i dont think its them.
  6. Jul 7, 2010 at 6:33 PM
    biggdog747
    MI
    taco
    bearings going bad has to do with one or more of the roller bearings getting hot and having a bad spot on it and then damages the race. grease will not fix that.
  7. Jul 7, 2010 at 6:34 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah........kinda figure, but it was an idea. dont think it'll prolong its life anyway?
