Wheel Bearings Changed (Pictures)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco93, Apr 25, 2011.
  1. Sep 26, 2011 at 10:24 AM
    #61
    KColoTaco
    KColoTaco Well-Known Member
    Kevin
    N. Colorado
    08 TRD O/R DC
    3 inch OME complete lift, Light racing UCA's, Bed comp. locks.
    Hey OP just a curious question at what speed were your wheel beaings most notiicibly bad?
  2. Sep 26, 2011 at 12:28 PM
    #62
    Taco93
    Taco93 [OP] Well-Known Member
    Milton, Ontario
    2011 TRD Sport
    Extang Trifecta Tonneau, Weathertech Floor Liners
    It wasn't very fast at all, maybe 25 - 30 mph when I started to hear the whirl!! I thought it was my tires at first, had those changed only to continue to hear the same noise!
  3. Oct 5, 2011 at 11:38 AM
    #63
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    Dumb question, but I'm just making sure. My truck being a prerunner do I need an inner seal? As I have no front 1/2 shaft I would assume no.
    I have already found the hub/bearing assembly at rockauto, just making sure I get all the parts I need before I start the swap.
    Thanks.
  4. Oct 5, 2011 at 1:59 PM
    #64
    Sneeker
    Sneeker Member
    I come from the land of the Ice and Snow
    05 Toyota Tacoma TRD OFF Road
    Hey great thread guys. I just want to make sure I have everything right.
    Going to need to order the Hub/bearing assembly (DA515040) there is one bearing per side.
    Should I deffinatly pick up some seal's and some o-rings and what part numbers would these be?
    After reading some more i realise I need some Oil seals how many do I need and what would the parts numbers be?
    Am I missing anything for this project?
    I know these are very elementary questions, but this is my comprehention for this project thus far.
    Thanks for your help.
  5. Oct 5, 2011 at 2:23 PM
    #65
    Muy Grande
    Muy Grande Well-Known Member
    Dallas, TX; RGV, TX
    06 DC TRD
    Suspension: DHoes up front, Dakar and OME out back. Audio: Alpine w205 w/ pair of Alpine Amps, Image Dynamic 6.5 Component Speakers up front and Image Dynamic Subs in the Back. Armor: ARB Bull Bar, Rocktek rear bumper and custom rock sliders. Other: Rigid Industries LED Light Bar, Platinum DieHard Battery, BlueSea Fuse Block, rear lights, bed lights, leds inside.
    Thanks for this write-up, my passenger side wheel bearing is done and needs to be replaced. The dealership want's $800 to replace the wheel bearing for only one side. That is some serious cabbage, I said fcuk that......I have ordered all the parts to do both wheel bearings and while I'm at it will be doing the BJ's total for all parts shipped - $223! :D
  6. Oct 17, 2011 at 8:53 PM
    #66
    Sneeker
    Sneeker Member
    How close are the FJ and the Tacoma parts wise around the wheel bearing hub assembly? Are the seals and o-rings the same part numberS?
  7. Oct 18, 2011 at 12:58 AM
    #67
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    The numbers in my post are the correct #s but I believe them to be the same for FJs
  8. Oct 18, 2011 at 6:07 AM
    #68
    WVTacoma08
    WVTacoma08 Well-Known Member
    West Virginia
    '20 TRD PRO Super White
    Taco93,
    Super job. Great pix :broccoli:
  9. Oct 18, 2011 at 7:09 AM
    #69
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    No sticky yet? or DYI
  10. Oct 19, 2011 at 7:33 PM
    #70
    Sneeker
    Sneeker Member
    Im just doing the driver side bearing and while I was pressing the bearing out the bearing basically fell apart it was in such rough shape. I had to heat the bearing up to pry it off after it basically fell apart in my hands...... Glad I changed it now befor my 8 hour drive south to edmonton. I have to replace my inner seal and probably my outer one too since there is cracking. I hope my passenger side isnt in such rough shape.
    Thanks for the thread again!
  11. Oct 26, 2011 at 7:59 AM
    #71
    stabngrab
    stabngrab Active Member
    Louisiana
    '17 TRD Off Road 4x4
    Thanks for the write up, it helped tremendously. Did driver side over the weekend for my pre-runner for $120 total, parts included (got hub for $70 at auto zone and went door to door to find a shop to press it for decent price). A shop quoted me 3x this for labor. Took me under an hour to take it off and about the same to re-install but this was done with wrenches and jack-stands in my garage. Word of warning, I thought I could get by without having to press it...not true. Do not try this without a press it will leave you severely pissed.
  12. Nov 21, 2011 at 4:10 PM
    #72
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    do you have to pack the bearings with grease or not since they are pressed in?
  13. Nov 21, 2011 at 7:30 PM
    #73
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    Nice write-up. Subscribed for future reference.
  14. Nov 22, 2011 at 10:23 PM
    #74
    Taco93
    Milton, Ontario
    2011 TRD Sport
    Nope, I just put a little grease around the inside of the oil seals. Not sure if it was needed though. The bearings are sealed units.
  15. Dec 20, 2011 at 12:31 AM
    #75
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    OP,
    Thanks for the excellent write up and pics; and to St3ve for the video in his sig. You guys made it possible for me to do this DIY.
    Interesting that even my Chiltons Manual didn't provide instructions or pictures for changing out the bearings. It basically said to go to a professional because of the special tools required. Don't know why they couldn't have provided instructions for removing the hub and bearing and then advised to go to a machine shop to have the bearings pressed off/on?
    For those reading here:
    I first noticed the hum/scrape sound when I used 4WD on the highway about six weeks ago after a snow storm. At first I only heard it in 4WD ... I was initially worried something was going bad in my front diff. In 2WD I didn't hear the sound. Then in the last week I started hearing it in 2WD. I had been planning to change out the front wheel bearing in the Spring regardless because of the known failures I'd read about on TW. So, with a prayer, I decided to change out the front wheel bearings now, hoping that would fix the noise I was hearing.
    Good News! All is quiet again. :D I suspect the driver's side was actually the culprit, but it only made sense to change them both.
  16. Dec 20, 2011 at 4:49 AM
    #76
    Namyo
    Namyo -
    114k or sumchit on mines....might should try this :anonymous:
  17. Dec 20, 2011 at 8:17 AM
    #77
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    114K ... you must have got the good set outta the batch. :cool:
  18. Dec 20, 2011 at 8:22 AM
    #78
    Namyo
    Namyo -
    :notsure: That's why I bought another taco...took the first one to 200somchit....just drove the piss out of it. Never really worried bout this kinda stuff till TW :eek:
  19. Dec 20, 2011 at 8:22 AM
    #79
    Jez
    Jez Hittn' easy steet on mud tires
    Ohio
    06 Black DC TRD SR5
    K&N air intake, Fox 2.5 coilovers, Total Chaos UCA's, AllPro Expo rear leaf pack, Fox 2.0 rear shocks, Diff Drop, U-Bolt Flip kit, Drive Shaft shim kit, Weathertech's, Borla cat back, Ultra Gauge,Clarion Radio, 18% tinted windows all the way around, smoked tail lights and rear break light, painted front chrome grill black, stained yellow fog lights, black head light mod, Interior LED kit, LED reverse lights, black leather arm rest mod
    Subd for future reference
  20. Dec 20, 2011 at 8:26 AM
    #80
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    If you want them to last over 3k then clean out all the worthless grease they come packed with and re-pack them with a premium bearing grease.
