Wheel Bearings Covered Under 60k Warranty?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kws129, Oct 9, 2012.
  1. Oct 9, 2012 at 4:45 PM
    kws129
    kws129 [OP] Well-Known Member
    PA
    TRD Off Road Double Cab
    Anyone know if a bed wheel bearing would be convered under the 60k drivetrain warranty?
  2. Oct 9, 2012 at 4:46 PM
    kws129
    PA
    of course by "bed" wheel bearing, I mean BAD Wheel Bearing
  3. Oct 9, 2012 at 4:47 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i would try it... do u have over sized tires? lift?
  4. Oct 9, 2012 at 4:48 PM
    kws129
    PA
    265/75R16 w/ Billies @ 0.85
  5. Oct 9, 2012 at 5:22 PM
    Toyotacerttech
    Toyotacerttech Well-Known Member
    Michael
    Texas
    2011 double cab 4x4 TRD
    Yes it's should be power train warranty 5years 60k
  6. Oct 9, 2012 at 5:25 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Should be covered but with your lift and tires, you'd better have a good story ready because, unless your dealerhsip is really really good, they'll try to blame the failure on the aftermarket parts.
  7. Oct 9, 2012 at 5:42 PM
    kws129
    PA
    I would have to strongly argue with the dealership if they turned it down, after I put the bilsteins on the front they aligned the truck and everything was on spec.
    At any rate I guess it doesn't cost anything to talk to them. The srevice manager at my dealership has been really good.
