Wheel Bearings/Hubs 4x4 & 4x2 PreRunner for sale *complete* save $$
Discussion in '2nd Gen Tacoma Marketplace (2005-2015)' started by nj636, Jul 25, 2013.
  1. Jul 26, 2013 at 6:45 PM
    #41
    g34rh34d
    g34rh34d Well-Known Member
    Colorado
    '08 4 DR TRD Off Road - 3" OME Lift, UCWMS
    UCWMS; OME 3" lift/OME 885 springs; OME 90000/60091 shocks; Diff drop Spacers; Light Racing UCAs
    A quick question, I have been suspecting I may have a front hub or two going bad. (2008 TRD DC 4x4 w/ ~58K miles) because last year as I drove down the road I had a shimmy that sorta felt like a wheel was out of balance. (This was amplified when I put my wheel spacers on which really brought it to my attention.)
    I took the wheel spacers off, and I had the tires rotated and balanced, but the shimmy never went away... So after an inspection, I noticed I needed front brake pads, so thinking that maybe I caused the shimmy by possibly overheating and warping a rotor, I ordered a new set of rotors for the front, and installed them with the new pads.
    At first, with new brakes and rotors the shimmy went away, but now that I have been driving it for a while (~3 mos), and as the front brakes have worn a bit, it seems that the shimmy is starting to re-emerge. Naturally now, I am suspecting the hubs even more.
    Can anyone tell me what is the process to inspect/verify the hubs are good (or bad)?? I tried the ol' grab the top of the wheel and shake to listen for clunks and rattles method, but nothing..
    Please advise, as I may be ordering two from you.
    thanks
    FH
  2. Jul 26, 2013 at 6:54 PM
    #42
    nj636
    nj636 [OP] Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    with the tires a good 3" off the ground stick a pry bar under the tire and pull upward, it may take more force than what your doing by hand. if there's any play you will notice it using this method.
  3. Jul 26, 2013 at 6:59 PM
    #43
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    haha, it really wasn't a bad job to press everything apart and together with that new 10 ton press. it's a lot cheaper, and if i ever have one gradually go bad again i'll rebuild it myself. I just ordered one from Keven to keep in my tool box in case I had a catastrophic failure on the trail, or needed a replacement but couldn't wait for parts. even if i were to somehow break some wheel studs wheeling or something, it's cake to pop one of these on on the trail, and then press out/in new studs when i get home.
    just too good of a value to pass up for some extra piece of mind on the trail and for day to day emergencies.
  4. Jul 26, 2013 at 7:23 PM
    #44
    no mods
    no mods Well-Known Member
    cincinnati
    Some stickers
    Good idea op.
  5. Jul 26, 2013 at 7:37 PM
    #45
    nj636
    Kev
    Jersey
    :cheers:
  6. Jul 26, 2013 at 7:46 PM
    #46
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    When you replaced the rotors & pads did you check the rotors for lateral run out ? If not go to raybestos garage.com and they have a good howtoo vid on it explaining why your warpt rotor sindrome returned after 3 mos.
    As for bearings, my 06 has 111k and I run 285's for 8 mos. a year and I still have original bearings with no problems.
  7. Jul 26, 2013 at 7:57 PM
    #47
    06taco
    06taco Well-Known Member
    Brendan
    South Jersey
    08 4x4 4-door TRD Sport
    *TRD Supercharger *3" OME lift kit *Dakar rear leaf springs *Total Chaos UCA *TJM T15 Plate Bumper *TJM Stealth 9000 winch
    Thanks to Kevin changing the wheel bearings were simple. Once he dropped them off at my house I had both sides installed and done with in an hour. I would highly recommend Kevin (nj636) if your looking to replace your wheel bearings. I can't thank Kevin enough as my truck no longer is making that horrible screeching/squealing sound.
    Much easier than having to take the bearings to a machine shop and have them pressed off am on and hope they don't f**k it up. For the price you can't go wrong.
  8. Jul 26, 2013 at 8:09 PM
    #48
    nj636
    Kev
    Jersey
    Thanks for the bump Brendan, I'm happy they came out how you expected. no more growling front end :grin:
  9. Jul 26, 2013 at 8:11 PM
    #49
    nj636
    Kev
    Jersey
    wait til you get in the 130k range :cool:
  10. Jul 26, 2013 at 8:24 PM
    #50
    Texoma
    Texoma Well-Known Member
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Poweraid TB spacer, a bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA 2035s headers and dey are perty, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, LR UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, 5 factory 16" steels wit Pep Boys special Dakota Definity MT's in 285/75/16, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more but it's alre
    Good job OP
  11. Jul 26, 2013 at 9:44 PM
    #51
    nj636
    Kev
    Jersey
    have the pre runner guys verified that the 4x4 assembly will not work on your trucks? They mount exactly the same.
    Regardless, I am putting together a list for pre runner specific hub assemblys :cheers:
  12. Jul 26, 2013 at 10:25 PM
    #52
    nj636
    Kev
    Jersey
    PRE RUNNERS
    your trucks use more parts for the hub assembly than the 4x4 trucks. I'd like to know if a 4x4 assembly will work on the pre runner?
    anyway, for a complete assembly ready to bolt on will be $325. I've seen a complete assembly on ebay and their website for $400.
    *edit* I got a call with same parts at a cheaper cost. The kicker is that flange, dorman does not make a pre runner flange so a genuine Toyota one has to be used in this kit, which isn't a bad thing just at a higher cost.
    Pre Runner complete hub assembly, flange to lock nut is $299. I'll update OP :cool:
  13. Jul 26, 2013 at 10:28 PM
    #53
    Anteupp
    Anteupp Mega Member
    Andrew
    San Diego
    Total Chaos Long Travel 4x4, Fox Coilovers, DMZ spring under, 16" king tripple bypasses, Garage built bedcage/bumper, full cage coming soon...
  14. Jul 26, 2013 at 10:44 PM
    #54
    Chickenmunga
    Chickenmunga Nuggety
    Olympia, WA
    08 TRD Offroad DC 4x4 (read the build)
    Going to have to do this. I had a shop tell me that my passenger side was totally shot even though I never felt a thing.
    I had it replaced - of course, you can't tell much once it's already out - but ever since I've been nervously inspecting any sounds or weird steering. Never felt a thing with the ol' grabbing tire and pushing about.
  15. Jul 26, 2013 at 11:41 PM
    #55
    3ps14
    3ps14 Well-Known Member
    Orange, CA
    05 trd sport dc
    OME 885s, Black FJ Alloys, TSB AAL, BHLM, Satoshi, Hellas, Black Valence, 6k HIDs
    I've only done the front bearings, and all that's required "extra" is a hub nut I bought at a dealership for $25
  16. Jul 27, 2013 at 4:19 AM
    #56
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors
    The prerunner is similar but different.
    The prerunner uses a large special nut to secure the hub to the bearings. This nut lives in the location the u joint is on the 4wd.
    The nut is supposed to be replaced on account of it being staked.
    The disassembly and reassembly requires a special socket and needs to be torqued to 200 ftlbs.
    The 4wd is assembled and secured by the axle spline,threaded portion and nut on the outboard end of the hub assembly.
    The prerunners sees no contamination from the inboard side of the suspension upright since these is a large plug that caps the ujoint area.
    PK
  17. Jul 27, 2013 at 4:36 AM
    #57
    BeeRadd
    BeeRadd ANTI-DARK Vendor
    Brad
    Fountain Valley, CA
    2008 DCLB 4x4 TRD Sport
    Mag light mod, ABS Kill switch, On board air, tail-gate theft mod, Redline hood struts, Shovel mount, Rubberized undercoated frame, CB radio w/lil wil magnet antenna, LED interior light, Shocker 228 Train horns, black valence, fog lights anytime, black hood scoop, eyelids, anti-seatbelt chime hack, weathertechs,
    I would've killed to have this thread around when my bearings went out. For the newbs: if you're a 4x4, when your wheel bearing goes bad you have to have a shop remove it from the hub (the thing with the 6 lugs). It's a tedious process and very frustrating. If you have a preassembled unit like this, all you'd have to do is swip-swap! Oh so nice. Props and SUBD!
  18. Jul 27, 2013 at 4:54 AM
    #58
    no mods
    cincinnati
    Some stickers
    Add a 75$ dollar overnight option and u Will rake it in. So many people don't realize they are out until they are 300 mikes away from home on the side of a mountain w no breaks cause the wobble is spreading the caliper.
  19. Jul 27, 2013 at 5:42 AM
    #59
    TacomaSportLB
    TacomaSportLB Well-Known Member
    Dad
    Chambersburg, PA
    2012 Toyota Tacoma TRD Sport DCLB MGM 4x4
    YWM, Front 5100's @ 2.5", Rear 5100's, 1.25" Spidertrax Wheel Spacers, Safety Rack, Fog Light Anytime, DRL Switch, Differential Breather Mod, UWS TBSD63ALPB ToolBox, AMP Research BedStep, Bedrug Tailgate Mat, aFe Air Filter, Dee Zee Heavyweight Bed Mat, Pop & Lock Power Tailgate Lock, Auto Ventshade In-Channel Ventvisors, Stant Locking Fuel Cap, Plasti Dipped Badges
    Just curious, would one need to bother with the ecgs bushing if using this assembly?
  20. Jul 27, 2013 at 6:30 AM
    #60
    nj636
    Kev
    Jersey
    one has nothing to do with the other
