Wheel Bearings/Hubs 4x4 & 4x2 PreRunner for sale *complete* save $$
Discussion in '2nd Gen Tacoma Marketplace' started by nj636, Jul 25, 2013.
  1. Jan 21, 2014 at 6:18 PM
    #621
    nj636
    nj636 [OP] Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Likewise & whenever your ready, I'll be here :thumbsup:
  2. Jan 23, 2014 at 8:46 AM
    #622
    weiser5150
    weiser5150 Stickers and new floormats arent Mods
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    Bilsteins all around,Front set at 2.5",Toytec AAL,LR UCAs,18x9 ATX Thugs,275/70R18 Toyo MT's,Relentless Fab Sliders,Satoshi Grill with TRD emblem and Hella Black Magic's converted to HID behind it.
    I have a vibration that I feel in the pedal.....it doesnt start til around 60mph and feels like.........whoooom whoooom whoooom......if that makes sense.
    Is this the cure?
  3. Jan 23, 2014 at 8:50 AM
    #623
    nj636
    Kev
    Jersey
    that is typically the symptom. you can jack the front end up and spin the tires to feel for resistance and a grinding noise.
  4. Jan 23, 2014 at 8:58 AM
    #624
    weiser5150
    JK
    Jacksonville,Fla.
    2008 DC LB 4x4
    I will do that.....Thanks
  5. Jan 23, 2014 at 11:23 AM
    #625
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    Should've just bought them from ya..
    Shop totally bunged up one of my bearings when they pressed them in; and I just realized that they used the wrong seal between the bearings.. For whatever reason they used the outer seal in place of the inner seal. Which is pretty hard to understand given that the bearing is clearly chamfered for the taller seal. Now I'm stuck with the taller seal that won't fit in the spindle due to the ABS sensor.
    Godddammnnit!!
  6. Jan 23, 2014 at 11:33 AM
    #626
    nj636
    Kev
    Jersey
    There are definitely hacks out there & unfortunately you dealt with one.
    So many important steps that can be skipped or done incorrectly, how they managed to install the wrong seal is beyond me. supporting the bearing race when pressing the flange in is crucial.
    Are you bringing it back to them? that bearing will be dead with the wrong seal on it.
  7. Jan 23, 2014 at 11:40 AM
    #627
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    I guess. Man this pisses me off.
    I figured I'd save a few dollhairs and support a local shop, they're literally next door. Yet another reason why I don't like farming out work to other people.
    The face on one of the bearings got totally scarred up; leading me to believe that the force applied was uneven.. Plus, the integrated seal on the ceramic cartridge was pushed out as well..
    I'm kind of at a loss as to what I do, since this is my daily driver.
    I dunno dude, don't want to clutter up your thread with my personal BS.
    Do I get another set of outer seals from NAPA and throw them in as is? Run them until they're shot? Trying to press them out and install the proper seals is going to destroy those brand new bearings.. I don't know what the life expectancy will be with the incorrect seal in there. They're completely different with regards to sealing surfaces/seal lips.
    Go over there and bitch at them?
    Shoot me a PM, don't want to clutter your thread.
  8. Jan 23, 2014 at 11:55 AM
    #628
    nj636
    Kev
    Jersey
    If that seal is pushed out from the cartridge then chances are they didn't support the bearing race when the flange was pressed in.
    if done correctly, the flange can be pressed out and a new seal installed successfully. what I wouldn't do is have that shop touch them again. I would take them over and show them what they did wrong, if you were charged I would ask for a refund since you'll be doing it all over again. maybe ask for a new set of seals as well.
  9. Jan 24, 2014 at 5:58 AM
    #629
    nj636
    Kev
    Jersey
    all current orders will ship tomorrow morning. check your inbox later this evening for tracking information :cheers:
  10. Jan 26, 2014 at 2:35 PM
    #630
    nj636
    Kev
    Jersey
    after fulfilling all current orders I actually have five 4x4 assemblies built and ready to ship.
    Let me know if anyone needs anything :thumbsup:
  11. Jan 26, 2014 at 3:32 PM
    #631
    nj636
    Kev
    Jersey
    So I replaced the bushings on my LCA's a few weeks ago and while I was there I replaced the LCA ball joints, outer tie rod ends & I came across the passenger side wheel bearing making some noise. I decided to replace both hubs.
    What I found interesting was the passenger side cv seal was damaged, which in turn allowed the outside elements into the bearing which lead to its demise.
    The driver side, which is original just like the passenger side, the seal was intact and the bearing was working great.
    I disassembled the passenger bearing assembly and it was pretty crusty in there. The grease was burnt, the bearing race was scoured badly it was a sad site.
    Now I disassembled the driver side. Here you can see the grease as I started to push the flange out of the bearing. The grease is still a nice clean white!
    looks new to me
    The cv seal was in perfect condition on the drivers side and as you can see the adequetly greased OEM 81,000 mile wheel bearing is in perfect condition.
    For those that believe the OEM bearings are inadequately greased from the manufacturer may want to think again. I honestly believe (and was told by a Timken Rep) that the white grease is adequate & under no circumstances should the bearing be altered with any other grease.
    As long as the seals are intact, the bearing will have a very long life.
  12. Jan 26, 2014 at 3:38 PM
    #632
    nj636
    Kev
    Jersey
    I also took a few pics of the hub flange surface to show why you should not re-use this flange when replacing wheel bearings. As you can see the flange is scoured all the way around at the seal surface which allows the outside elements to get by the seal and into the bearing, prematurely wearing the bearing.
    This is the flange as it was pressed out of the passenger side bearing. The bearing surface is rusted and the seal surface is rusted and scoured.
    Here is the passenger side flange cleaned up to show the gouges in the sealing surface
    Definitely do not want to reuse this flange! :eek:
  13. Jan 26, 2014 at 3:39 PM
    #633
    DoorDing
    DoorDing Thank you, Nancy Roman
    2012 DCSB Off-Road 4WD
    It sure seems like that seal is the weak point. Without a redesign, do you see any way to improve or protect it?
    I used to run pillow/plummer block bearings on a stump grinder, which was a very harsh environment. I could count on having to replace them not too many hours after I could see that a seal had failed.
  14. Jan 26, 2014 at 3:42 PM
    #634
    DoorDing
    No doubt.
    How did the driver's side hub look? It seems that if someone wants to reuse the actual hub, they'd be better off approaching bearing replacement as preventative maintenance. By the time the assembly starts showing signs of a problem, hub damage may have already occurred.
  15. Jan 26, 2014 at 4:14 PM
    #635
    nj636
    Kev
    Jersey
    I did not document the driver side hub flange, but it was in great shape so I re-used it. The passenger side obviously got a new hub flange.
    I'm pushing on Dorman and two other companies to manufacture the 4x2 hub flange. I'm hoping they come through!
  16. Jan 27, 2014 at 4:39 AM
    #636
    nj636
    Kev
    Jersey
    The seals would have to be protected but I believe checking them during routine maintenance would be a great idea.
  17. Jan 27, 2014 at 4:38 PM
    #637
    nj636
    Kev
    Jersey
    remaining orders shipped today :cheers:
  18. Jan 28, 2014 at 1:52 PM
    #638
    TuFerLife
    TuFerLife 2 4 LIFE!!!
    Taylor
    Chattanooga, TN
    '06 Boosted Lifted 4X4 DCSB
    URD MKII Stage 2 supercharger, APR X-1 ECU, DTLT L1 series, Pro Comp 6" lift (stage 1), 20" KMC XD Monsters wrapped in 35x12.50 Pro Comp Extreme AT's, Icon DR coilovers, Icon DR Billet UCA's, Custom Dual exhaust - Magnaflow X muffler to 2 Bassani mufflers with tuned pipes to eliminate drone at 2-3000 RPM, Redline hood struts, Spider Trax front wheel spacers 1.25", Line-X'd 2" nFab nerf bars and Avid Light Bar, Illumination Supply 30" double row spot/flood combo LED light bar, Bushwhacker pocket style flares, 13tw5 in Mr. Marv box and memphis door speakers, URD Short Shifter, TRD Shift Knob Carbon Fiber hood Skewp, AsianAnts FXR projectors
    Sub'd. Looks like this is what I'm going to be buying myself for my birthday
  19. Jan 28, 2014 at 3:50 PM
    #639
    nj636
    Kev
    Jersey
    I'll be here :cool:
    I currently have two sets in stock & will be building more the end of this week
  20. Jan 28, 2014 at 8:32 PM
    #640
    TuFerLife
    Taylor
    Chattanooga, TN
    Thank ya sir... I'll be reaching out to you shortly!
