Wheel bearings or front Diff? or.....?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JasonJump, May 17, 2010.
  1. May 17, 2010 at 10:58 PM
    JasonJump
    JasonJump [OP] Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    I have posted a thread about a strange vibration/grinding noise coming from the front of my truck. Lately its been more evident when i turn left, I can also hear it around 40mph... more of the steady vibration. To eliminate anything thing easy, I have changed my front are rear diff oil, greased the zerks. First thought after ready some stories on here I thought front bearings have been a porblem for some people. Sooooo I went and bought some seals and bearings and took my bearing/hub assembly off today and took it to Les Shwab, or however you spell it and the guy there turned the bearing on the hub and said "dude these bearings aren't bad" I asked since its not happening all the time, maybe they are starting to get bad...? He said no no no, they would def be making a noise or trying to catch. He got me thinking well maybe I shouldn't even change them and it might be coming from my fornt diff... so I go back and put the bearings and wheels back on and drove it around and also put it in 4x4 and it seemed more steady of a noise grind in 4x4 but even when I took it out, was more steady than before I had the bearings off. Not to keep ranting, but could some please shed some light on what you think it might be? Its def a little worse than before taking them off.... which would lead me to believe bearings, but he was sooooo sure it def was not. :mad:
  2. May 18, 2010 at 12:10 AM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    Les schuab is a place where you buy tires and not where you get work done to your car. Point being that while his intentions may have been well place his experience may be seriously lacking or he is just plain wrong.
    Just to make my point about experience -- have taken my motorcycles to dealers on several occasions and have had them create more problems than they solve. These are trained techs -- bottom line is don't put too much weight on what one guy says. If the problem is worse after you messed with the bearing then that is a good indication that it is the culprit. You might just want to replace them. How much are they?
  3. May 18, 2010 at 12:14 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Bay Area, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, 255/754R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Jack up the front tires, with your hands at the 12 and 6 position wiggle the tire. If you have quite a bit of play there's a good chance it's your bearings. In my previous life as an auto mechanic I could never give the service writer my sure answer of something until I had taken it apart and made sure that was definitely the answer. Not sure what you mean by "turned the bearing on the hub" but for me it always involved pulling the bearings or at least checking whether the grease was burnt or had metal shavings in it.
    It could also be your brakes slightly grabbing if the pads are fully retracting/your rotors are warped. That wouldn't really explain why it's doing it when you turn left or vibrating at 40MPH but it's a possibility since it sounds like a rotational noise.
    Best of luck.
  4. May 18, 2010 at 7:37 AM
    JasonJump
    Yukon Oklahoma
    The bearing and hub come off as one, its pressed. If I take that bearing off the hub, the bearing is no good anymore. U have to press the bearings off and it leaves the race of a sealed bearing... which isn't good after that is what he told me. The bearings were $170 all together with seals, then to press it would be another $50. Also I did jack it up and see if there was play side to side and up and down, and no play at all. Although I have heard too that there might not be play if its an early enough issue... so I'm up in arms. I do agree since there is a more evident noise and vibration its leaning me towards the bearings
  5. May 18, 2010 at 10:50 AM
    JasonJump
    Yukon Oklahoma
  6. May 18, 2010 at 11:06 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    How many miles are on the truck? how many with the lift? What kind of lift?
  7. May 18, 2010 at 12:22 PM
    JasonJump
    Yukon Oklahoma
    110k bearings were replaced 25k ago, and it has a 2" block up front.. nothing crazy. and original tire size, there is no reason bearings should be going out
  8. May 18, 2010 at 1:10 PM
    Peru
    Jonathan
    Redmond WA
    none
    if the bearings were installed improperly it can cause premature damage or perhaps something else was damaged during the installation process.
    Yo said they are sealed so the lubrication should not be an issue. Did the dealer do the work? If so there should be some sort of warranty on their workand if you fall with in that they should foot the bill. The thing to keep in mind is that if you take it somewhere else and it is the bearing good luck getting the dealer to pay and if you take it to the dealer more than likely they will blame it on something else.
    I still think it's the bearings
  9. May 18, 2010 at 1:14 PM
    Peru
    Jonathan
    Redmond WA
    none
    One other thing to keep in mind that the run of the mill bearings (probably doesn't apply to your case) can be bad right out of the box. I wouldn't put it past a shop to try to source a cheaper -- that should read cheapest -- alternative (if its available) to the OEM.
  10. May 18, 2010 at 1:36 PM
    Racer78
    Racer78 Well-Known Member
    05 Tacoma 4X4 Sport
    Billstiens 5100 @1.75, 5125, 1.5 AAL,Leaf Spring TSB,TRD Intake, Roof Rack, Satoshi Grill, BHLM,T-Rex Eyelids, Undercover Cover, Powdercoated Sport Rims, KC Slimline 8" Lights, MTX ReQ5 w/ipod imput, 12" Shallow Pioneer Sub, RF 800.4 amp, JBL Comp, Bed Ext, USB Port, Shorty Antena, Spider Trax Spacers,TRD Skid Plate, Napier Sportz Tent II, Scangauge II, AirBedz
    As far as the left turn thing, I had the same problem with my 05. The only differance was that my grinding, intermittent crunching sound was from the rear of my truck. It was my rear diff, incorrect back spacing..
  11. May 18, 2010 at 1:46 PM
    JasonJump
    Yukon Oklahoma
    Racer that sounds exactly like what mine is doing, grinding on left turns... also here it around 40mph going straight.... so what exactly was wrong with yours? what was the fix? and $?
  12. May 18, 2010 at 1:47 PM
    JasonJump
    Yukon Oklahoma
    But I swear I feel it in the front under my feet...
  13. May 18, 2010 at 3:07 PM
    Peru
    Jonathan
    Redmond WA
    none
    You may have said this but have you changed the front diff oil receintly -- like anytime afte the sound started
  14. May 18, 2010 at 3:17 PM
    JasonJump
    Yukon Oklahoma
    Peru, actually yes I did change my Front/rear/transfer case fluid.... with mobil 1. You think that could be the problem? If so what oil would you suggest? Hope I haven't done too much damage
  15. May 18, 2010 at 3:18 PM
    JasonJump
    Yukon Oklahoma
    And it def seemed to do it ever since I changed it.....
  16. May 18, 2010 at 3:27 PM
    Racer78
    05 Tacoma 4X4 Sport
    Well, I was lucky as my extened plan covered it. They replaced the whole diff. I felt mine and it was the rear. Maybe take it to a transmission shop and have them take it for a drive? They might know the sounds and symptoms?
  17. May 18, 2010 at 4:35 PM
    Peru
    Jonathan
    Redmond WA
    none
    M1 is a high quality product -- I asked to see if you seen any metal either stuck to the magnet or if it came out in the oil.
    As far as M1 Or any synth in the rear is concerned, it appears that the consensus here, based on lots of real world expierence, is not the lube to use. Everywhere else it's a great product.
    One other question -- how many miles before the first oil change in the front diff?
    On a side note -- mobil makes some of the finest heavy duty industrial synthetic gear lubes around. I hate going up against them.
  18. May 19, 2010 at 10:56 AM
    JasonJump
    Yukon Oklahoma
    Sooo I changed the rear diff last night to regular 80-90 valvoline gear oil with LSD additive. and removing the mobil 1 syn that I had in it. THe slow turning grind is now gone.... buuuuut around 35 mpgs it seems to still be gettings vibes/grinding going straight..... think I have done some damage to the diff? ..... now I'm wondering if I should have put those bearings in the front.... :(
  19. May 19, 2010 at 12:54 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Don't forget to add the extra LSD Additive. Not clear on how you phrased it whether you still added the extra tube of additive or whether you just used the oil that says it has the additive in it. You still need the separate additive (at least I did).
    Also, now that you're down to a vibration/grinding on the straightaways at that speed, have you engaged 4wd to see if it goes away? If it does, then you've narrowed it down to the front diff. If it doesn't go away, then you've likely eliminated the front diff output bearing as being the problem.
  20. May 19, 2010 at 12:56 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    my 05 had to have the wheel bearings replaced, that could be your problem
