wheel bearings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kauaitaco69, Jan 29, 2011.
  1. Jan 29, 2011 at 8:35 PM
    kauaitaco69
    kauaitaco69 [OP] Active Member
    hawaii
    06 lifted white tacoma
    k&n intake, 40 delta flow exhaust, 6 in. lift, 20" centerline eclipse wheels with 33x13.5 iroks, pioneer deck, alpine type s components, one 12" alpine type R and 1000 watt alpine v-power amp.
    hey guys I got a 2006 toyota tacoma with a 6in lift and 33in tires. my front wheel bearings just went out. does anyone know of any aftermarket or stronger wheel bearings?
  2. Jan 30, 2011 at 6:30 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    03 regular cab 4x4
    Nope. It's too bad somebody doesn't come up with a setup like you can now get for a super duty. Apparently on those you can now get a setup that replaces the integrated flange/bearing/pressed in hub with a regular setup with greaseable tapered tapered roller bearings and manual hubs. But I've used SKF bearings on both the tacomas I've replaced them on. The last set I changed had about 30k on them when I sold the truck and it was still whisper quiet. I would suggest staying away from GMB brand. I work in the Euro parts business and I've seen lots of them fail prematurely. I can't imagine they have different standards for Japanese vehicles than they do European ones.
  3. Jan 30, 2011 at 8:00 PM
    kauaitaco69
    hawaii
    ok thanks for the info
