Wheel bearings
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yote488, Sep 12, 2016.
  1. Sep 12, 2016 at 7:51 PM
    Yote488
    Yote488 [OP] Member
    2002 Tacoma
    6in fab tech suspension lift 3 in body 488 gears
    Does anyone have the solution to wheel bearings or can tell me what I'm doing wrong. I cannot keep them in my drivers side front for more than 200 miles but I have well over 15,000 on my passenger side front with no problems. I have used several brands.
    98tacoma27 likes this.
  2. Sep 12, 2016 at 9:10 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    something is bent or bad. are you replacing the bearings yourself? or replacing the whole spindle?
    Dalandser likes this.
  3. Sep 13, 2016 at 1:12 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    What kind of failures are you experiencing ??
    Just how many have failed ??
  4. Sep 13, 2016 at 4:18 AM
    Yote488
    Yote488 [OP] Member
    2002 Tacoma
    The bearing it self, and they just don't last long at all if I jack the truck up the tire moved back and fourth again
  5. Sep 13, 2016 at 4:18 AM
    Yote488
    Yote488 [OP] Member
    2002 Tacoma
    I'm on my 4th in the last 6 months
  6. Sep 13, 2016 at 11:05 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Did you have the bearings done at a shop or DIY?
  7. Sep 13, 2016 at 11:13 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Are you not tightening the CV joint? Front bearings on 1st gen Tacoma are very robust. They should be going 300,000 miles.
    Something is wrong.
  8. Sep 13, 2016 at 12:00 PM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Bad/worn out CV shaft maybe,,rattling them out?. Should feel that as well at speed if it is. It's the direct connection to the bearing and all the other parts leverage on that(brake rotors, wheels and tires). Examine every detail as you replace again.
    Are you pressing them(hub and bearing) together,,or is someone else doing that work?. Just curious.
  9. Sep 13, 2016 at 2:55 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The bearings are collapsing
    You see heat score marks!!
    If these bearings have failed like this and every thing you think was correct
    Someone has a major quality control problem The bearing distributor would love to know before they have a major failure and people get killed
    Or is the nut not being torqued correct .175 foot pounds
    Unless your using a Chinese bearing they are working on quality control another 25 years they might get the idea
  10. Sep 14, 2016 at 5:22 AM
    Yote488
    Yote488 [OP] Member
    2002 Tacoma
    I am doing them myself. Brand new cv axel also
  11. Sep 14, 2016 at 8:59 AM
    wilcam47
    Will
    Bourbon state
    are you possibly damaging them when you are putting them in?
  12. Sep 14, 2016 at 9:15 AM
    Yote488
    Yote488 [OP] Member
    2002 Tacoma
    Another question is do the first gens fit 15in wheels? I do not believe I am, there is 2 spacers in the that come out and they go in the back of the bearing closest to the differential correct?
  13. Sep 14, 2016 at 9:19 AM
    wilcam47
    Will
    Bourbon state
    Im not sure on your 2002 I just had my bearing replaced and it was one piece just an inner and outer seal. Definitely shouldnt be going bad that quick...I would think they would last even with non-toyota parts.
  14. Sep 14, 2016 at 9:20 AM
    Yote488
    Yote488 [OP] Member
    2002 Tacoma
    Mine has a inner and outer seal 2 spacers and the wheel bearing and a snap right
  15. Sep 14, 2016 at 9:22 AM
    98tacoma27
    Ben
    Not Beech Creek
  16. Sep 14, 2016 at 9:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    Two spacers? Got any pics?
    wilcam47 likes this.
  17. Sep 14, 2016 at 9:38 AM
    Yote488
    Yote488 [OP] Member
    2002 Tacoma
    No I do not, that's a pre runner mines a base?
  18. Sep 14, 2016 at 9:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's both. You have to ignore the pre components...or do you mean the video? (didn't watch it)
  19. Sep 14, 2016 at 9:48 AM
    Yote488
    Yote488 [OP] Member
    2002 Tacoma
    Videos not wheel bearing
  20. Sep 14, 2016 at 9:56 AM
    Yote488
    Yote488 [OP] Member
    2002 Tacoma
    That picture is saying the wheel bearing is bolt in mine is pressed in
