Wheel bearings
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yote488, Sep 12, 2016.
  1. Sep 14, 2016 at 10:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    :facepalm:
    All kinds of fail on my part.
    Fixed that post. The video is kind of worthless.
    So the two spacers go towards the differential.
    Yote488[QUOTED][OP] likes this.
  2. Sep 14, 2016 at 10:26 AM
    98tacoma27
    Ben
    Not Beech Creek
    Are you replacing the oil seals? Only thing I can think of is maybe you're getting water in the bearing.
    wilcam47 likes this.
  3. Sep 14, 2016 at 1:09 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    huh ?
    I will only replace my bearings using the factory Toyota bearings.
    As many aft. mrkt. chinese made bearings are subpar in quality
    even if they are claimed to meet OEM spec.
    Who's pressing in the bearings ?
    Are they possibly becoming damaged when pressed in ?
    ie: pressed in does not mean beaten in.
  4. Sep 14, 2016 at 1:24 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Proper Pressing Procedure Prevents Premature Problems
  5. Sep 14, 2016 at 1:39 PM
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Thanks for the axle and diy confirm
    After 4-5 bearings going in and out of the same hub,,you might be cocking the bearing in the hub. Any smeared metal inside where the bearing presses in and seats flat in there?. Just a few hard crumbs could do this.
    Did you over press the hub in any certain spot?,,warpage is what I am going for.
    Looking at a very good 30 ton 2 speed press for the shop. Have needed one so many times lately.
    Heat the hub in the oven (200-250°) and press a new one in. Stress relieve the hub and make the interferences a bit easier as you press in.
  6. Sep 14, 2016 at 2:43 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    'dats a bunch of "P's" :eek:
    and tho' I am in accord with 'dat
    I would likely re-word that slightly...
    Professional Pressing Procedure Prevents Premature Problems ;)
    still the 6 P's :p
  7. Sep 14, 2016 at 4:53 PM
    Yote488
    Yote488 [OP] Member
    2002 Tacoma
    6in fab tech suspension lift 3 in body 488 gears
    I cleaned the in side of the hub the last 2 times I did them, idk what I was seeing in that picture.
  8. Sep 14, 2016 at 4:53 PM
    Yote488
    Yote488 [OP] Member
    2002 Tacoma
    I'm doing them
  9. Sep 14, 2016 at 6:18 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Are you first pressing the bearing into the spindle via the outer race and then the hub into the bearing by supporting the inner race so the pressing force does not go thru the actual bearings themselves?
    Yote488[QUOTED][OP] and 40950 like this.
  10. Sep 14, 2016 at 6:18 PM
    40950
    CR, WA
    stock
    Snap some pics as you go. Yes, evidence,,no worries. Evidence to post globally of shitty import bearings,,if that's where it lies.
    Yote488[OP] likes this.
  11. Sep 15, 2016 at 4:13 AM
    98tacoma27
    Ben
    Not Beech Creek
    I change the original picture because I had a 2nd gen assembly on there.....:oops:
  12. Sep 15, 2016 at 8:36 AM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    I don't own nor have I ever worked on the later Tacoma truck spindles/hub bearing
    But besides a bearing snap (retaining) ring...
    looks to me as if the bearing is still pressed in.
    At least the FSM I have says so.
    So I'm not sure what you're seeing on the other diagram
    or mean by bolt on ?
    Regardless... your bearing is press in
  13. Sep 15, 2016 at 8:41 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    newer ones are a hub assembly, you take 4 bolts off and put the new assembly on. older ones the bearing is the replaceable pressed in part.
  14. Sep 15, 2016 at 8:45 AM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    the bearing is either pressed into the hub or the spindle
    tho' I'm not going to look again to determine which
    'cause I really don't care.
  15. Sep 15, 2016 at 8:48 AM
    #35
    98tacoma27
    Ben
    Not Beech Creek
    Gents, I had the wrong pic loaded. It was a second gen diagram. That's where the confusion came from. OP knows what he has. All is good.
    Moving on...
  16. Sep 15, 2016 at 6:44 PM
    #36
    Yote488
    Yote488 [OP] Member
    2002 Tacoma
    Yes
  17. Sep 15, 2016 at 6:45 PM
    #37
    Yote488
    Yote488 [OP] Member
    2002 Tacoma
    Yes
  18. Oct 10, 2016 at 12:11 PM
    #38
    Cam1992
    Cam1992 New Member
    Camryn
    Eatonville, WA
    1999 Toyota Tacoma SR5
    3" Toytec Ultimate Lift
    Hey Yote, you say you have two spacers. I'm guessing one is the outer bearing spacer, and the other is to replace the ABS speed sensor. Is one a thin 1/4" spacer, while the other is about 1" thick? The 1" thick one is tapered on one side, so could you be putting it in backwards? Also, are the dust seals on your axles getting chewed up at all?
