Wheel Bolt Pattern.
Discussion in 'Wheels & Tires' started by ChristianB, Aug 26, 2012.
  1. Aug 26, 2012 at 8:26 PM
    ChristianB
    ChristianB [OP] Member
    Christian
    Vancouver Island
    Hey guys. I want to order Pro Comp 7089 Wheels for my truck. I found everything to the right specs in non hub centric but it is a 6on5.5 bolt pattern which the truck requires. I also found the same wheel, hub centric but the bolt pattern is 6on135mm. Just curious would that bolt pattern difference matter or should i just stick with the 6on5.5 wheels. Any help would be great thanks.
  2. Aug 26, 2012 at 8:32 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Convert millimeters to inches, and you will find your answer. I believe the correct pattern in 6x139mm or 6x5.5
  3. Aug 26, 2012 at 8:34 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    correct
  4. Aug 26, 2012 at 8:34 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    he is right ^ But they are both the same just different measurements, don't be worried about it means nothing. It is good to know both though.
  5. Aug 26, 2012 at 8:34 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    6x135 won't fit.
    6x5.5 / 6x139.7 is correct
  6. Aug 26, 2012 at 8:35 PM
    ChristianB
    Christian
    Vancouver Island
    Yeah, i was aware that it was a bit bigger. I was just curious if that little bit would be enough to effect it?
  7. Aug 26, 2012 at 8:38 PM
    ChristianB
    Christian
    Vancouver Island
    I will stick with the ones i know will fit then. Thanks for the information.
  8. Aug 26, 2012 at 8:39 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    5mm is not exactly a "little bit". It's nearly 1/4" off.
    Sometimes you can find "multi-fit" wheels that have a range, but I haven't seen those in years. Generally, multi-fit are now drilled with an extra set of holes... more common on 4 and 5-lug wheels than 6.
  9. Aug 27, 2012 at 10:39 PM
    JdMeF9SiR2
    JdMeF9SiR2 FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    Rich is exactly right.
