Wheel compatibility T100 to Tacoma?
Discussion in 'Wheels & Tires' started by wholesaler57, Jan 6, 2011.
  1. Jan 6, 2011 at 6:48 AM
    wholesaler57
    wholesaler57 [OP] Member
    Florida
    prerunner SR5
    I am looking at a set of stock aluminum 16x7 wheels off of a 1998 T100 4x4 and I want to put them on my 2002 Tacoma 4 door SR5 Prerunner 2wd. I have the stock 16x7 steel wheels on my Tacoma now. Does anyone know any reason why they wouldn't fit. The wheels will come with the factory shouldered lugnuts so I won't have to worrry about finding those. Both wheels are the six hole design. Any info would be appreciated.
  2. Jan 6, 2011 at 7:10 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I don't see why they wouldn't work.
  3. Jan 6, 2011 at 7:26 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    You have any pics of the rims curious how they look
  4. Jan 6, 2011 at 8:00 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    There may be a difference in the wheel offset but besides that they should be the same bolt pattern. Toyota alloy wheels have the offset number cast into the wheel so I would check to make sure.
    The stock 16x7 alloys from your '02 will be +15mm offset. A higher offset number, say 30mm as in the 2nd gen stock alloys, will put the inside of the wheel closer to the suspension components.
    15mm equates to approximately 9/16ths of an inch.
  5. Jan 6, 2011 at 9:18 AM
    BAMFTACO
    Juan
    Kings bruh
    He could always get wheel spacers
  6. Jan 6, 2011 at 12:14 PM
    wholesaler57
    Florida
    prerunner SR5
    The T100 rims say 16x7 JJ and then they have a 15 stamped beside that so I guess the offset matches up. I don't have a picture but they are the 5 spoke aluminum wheels. The man at the tire shop says they will work. I guess I'll go ahead and get them. Thanks for the help.
