wheel corroded to hub, need help!
Discussion in 'Wheels & Tires' started by Tacoma_teenagers, Sep 6, 2009.
  1. Sep 6, 2009 at 3:44 PM
    Tacoma_teenagers
    Tacoma_teenagers [OP] Member
    Justin
    Southeast
    '00 Tacoma SR5 Prerunner
    on my tacoma, the aluminum wheels have corroded to the hub. i have tried liquid-wrench, and even driving then trying again, but all 4 of the things are STUCK. has anyone had this problem? i was attempting to rotate the tires b/c the previous owner "didnt believe in rotating tires". i need help,does anyone know how to get them off?
  2. Sep 6, 2009 at 3:47 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Large BFH. (Big Fucking Hammer)
  3. Sep 6, 2009 at 3:49 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    kick the tire really hard
  4. Sep 6, 2009 at 4:01 PM
    Tacoma_teenagers
    Justin
    Southeast
    Ive tried kicking it and beating it with a hammer. it is REALLY STUCK. Ill try a bigger hammer.
  5. Sep 6, 2009 at 4:03 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You have to hit the hub.
  6. Sep 6, 2009 at 4:04 PM
    JKD
    JKD Well-Known Member
    Have you loosened all of the lug nuts, driven a few feet forward, nailed the brakes, driven a few feet backward, nailed the brakes again, then tried removing them?
    The nuts should be loose enough to not be in contact with the wheel, but they shouldn't be removed completely.
  7. Sep 6, 2009 at 4:04 PM
    Tacoma_teenagers
    Justin
    Southeast
    ok ill try that.
  8. Sep 6, 2009 at 4:45 PM
    Tacoma_teenagers
    Justin
    Southeast
    so far i think its worked for 3 of them, i hear a loud pop, then one side of lugs is loose and the other side is tight, i guess that means it worked.
    just got the rear passenger wheel left to go, then im gonna try to remove them, thanks for the help, ill post how it goes.
  9. Sep 6, 2009 at 5:02 PM
    BAP_29
    BAP_29 Well-Known Member
    Ben
    North Carolina
    05 Prerunner DC TRD Sport
    Bilstein 5100s at 2.5" and Toytec 1.5" AAL Eagle Alloy 063 Wheels on 285/60/18 Cooper Zeon LTZ tires Alpine iDA-X305 Head Unit MB Quart DKD 116 Discus-Line 6.5" Front Speakers (Baffles by Marv) Alpine 6-Disk CD Changer Toyota All-Weather Floor Mats Kobalt Low-Profile Toolbox 13" Wicked Flow Muffler w/ Chrome Tip
    PB Blaster. apply it and let it sit for awhile. then come back and begin kicking the tire and hammering it. this happened to mine and the pb blaster was the only thing that worked
  10. Sep 6, 2009 at 5:08 PM
    df4iguy
    df4iguy Well-Known Member
    Dan
    Chicago
    hitting the tire from the inside out works best for me
  11. Sep 7, 2009 at 4:34 AM
    Tacoma_teenagers
    Justin
    Southeast
    loosening lugs and going down driveway did the trick.
    Thanks
