wheel edges rubbing on tie rods
Discussion in 'Wheels & Tires' started by NDG55, Dec 11, 2012.
  1. Dec 11, 2012 at 10:08 AM
    NDG55
    NDG55 [OP] New Member
    Noble
    Anchorage
    02 Tacoma TRD Double cab
    I recently bought a 2002 Tacoma TRD. When I bought it the owner said he was running a larger set of tires on it and I might hear some rubbing on sharp turns, but it's just the fender and isn't a problem.
    After I bought the truck I did a closer inspection and I noticed that the edge of the wheel/rim is actually rubbing on the tie rod and is grinding a little bit of metal away along with the weights. It only rubs on sharp turns.
    My truck has 265 70 R16 tires on 16in cobra wheels. Is there any way I can help fix this? I was looking into wheel spacers but not sure if that's the best way to go.
    Thanks
  2. Dec 11, 2012 at 11:10 AM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Yep, either wheel spacers, or different wheels.
  3. Dec 11, 2012 at 1:30 PM
    NDG55
    Noble
    Anchorage
    What is the OE wheel size for the 02 Tacoma TRD?
  4. Dec 11, 2012 at 3:23 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    16x7 with 4.5" BS.
