Wheel fitment across different years
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaPrime, Oct 31, 2019.
  1. Oct 31, 2019 at 8:22 AM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    I have some oem trd off road rims left from my 2005 trd off road. I want to use them as winter wheels on my 2014 trd sport. Will they work without any clearance issues. Figured I'd put 265/70/16 tires on them.
    Thanks.
  2. Oct 31, 2019 at 8:29 AM
    Muddinfun
    Muddinfun Well-Known Member
    Yes, they will fit perfectly.
    You just need to decide what you want to do for TPMS sensors.
  3. Oct 31, 2019 at 9:31 AM
    TacomaPrime
    Gregory
    Illinois
    Oh yeah. Forgot about that. Can I just buy new ones?
  4. Oct 31, 2019 at 9:51 AM
    Muddinfun
    There are multiple ways you can do it.
    Buy new TPMS sensors.
    1) Buy pirated Techstream for ~$50 and reprogram truck every fall and spring.
    2) Pay the tire shop to reprogram your truck every spring and fall.
    3) There is a magic box on ebay that supposedly stores your sensor ids and you just plug it in and click your heels together 3 times and it programs the truck for you.
    Here's another option that should work.
    The tire shop has sensors that they can clone to be the same as your exisiting sensors. I've never heard of anyone doing it, but in theory, if the truck doesn't know the difference, it should work. You may need to store your 2nd set a long ways away from your truck. Think of it as having a clone of yourself. But if your girlfriend ever saw both of you at the same time, that could be a problem.
  5. Oct 31, 2019 at 9:54 AM
    TacomaPrime
    Gregory
    Illinois
    So the truck can only ever have 1 set of tpms sensors programmed to it at once? So in theory I could leave my set I have on now, then buy a 2nd set for the other rims, and like you said have the shop program them every time I switch the wheels/tires out in fall/spring?
  6. Oct 31, 2019 at 9:59 AM
    Muddinfun
    Everything you wrote there is correct.
    You may want to find out how much the tire shop is going to charge you to reprogram each time. If it's more than, free to $15, you may want to consider the other options.
