Wheel fitment help
Discussion in 'Wheels & Tires' started by JTaco386, May 14, 2012.
  1. May 14, 2012 at 6:11 PM
    JTaco386
    JTaco386 [OP] Well-Known Member
    JT
    Fort Rucker, AL/ Home: Port Orange, FL
    13 DCSB TRD Sport 4x4
    I found a set of 17x8.5, 6x139.7, 0mm offset, hub 108mm. Will these fit my 2012 TRD Sport 4x4 V6? Thanks in advance!
  2. May 14, 2012 at 6:36 PM
    JTaco386
    JT
    Also the wheel is a method standard
  3. May 14, 2012 at 7:15 PM
    JTaco386
    JT
    Anyone?
  4. Nov 13, 2012 at 7:46 PM
    BigD91
    BigD91 Well-Known Member
    Andrew
    Bay Area
    08 Double Cab 4x4 TRD Sport
    how'd these wheels work out for you?
  5. Nov 13, 2012 at 7:48 PM
    JTaco386
    JT
    They worked out great, I just bought some hub spacers...not sure if that's what they're called to make the wheel sit flush on the hub.
  6. Feb 3, 2013 at 9:30 AM
    Shinshi
    Shinshi Member
    Calgary, Alberta
    2012 Toyota Tacoma DC SB
    I'm looking at purchasing the exact same wheel, 17x8.5, 0mm offset.
    What tire size are your running with those Duratracs?
    I'm considering the same wheel with 285/70R17 tires, possibly Duratracs, and trying to determine if they rub the UCA with 4.75 backspace. They are about 6mm closer than a 17x9 wheel with -12 offset, 4.50 backspace, which are the defacto best fit for a 17x9. I am hoping the 17x8.5 clear the UCA without using wheel spacers.
