Wheel fitment question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JTaco386, May 27, 2012.
  1. May 27, 2012 at 12:52 PM
    JTaco386
    JTaco386 [OP] Well-Known Member
    JT
    Fort Rucker, AL/ Home: Port Orange, FL
    13 DCSB TRD Sport 4x4
    I recently purchased the Method standard wheels. The size is 17"x8.5"
    Offset: 0mm
    Bolt pattern: 6x139.7 (6x5.5)
    Hub: 108mm
    I've read that our hub bore is 106mm. In order for these wheels to balance correctly will I need to buy rings to make them fit properly with the 106mm hub? What lug nuts would you recommend? Thanks!
  2. May 27, 2012 at 1:50 PM
    JTaco386
    JT
    Anyone have any input? I found a great thread which Talks about hubcentric rings, but I don't want to buy the wrong thing.
  3. May 28, 2012 at 11:26 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    to minimize any vibration issue, consider adding the rings if you haven't already. you'll need acorn style lugs. your oem shank lugs will not work.
  4. May 29, 2012 at 3:06 AM
    JTaco386
    JT
    Thanks for the help! :)
