Wheel fitting
Discussion in 'Wheels & Tires' started by StrongYota22, May 5, 2010.
  1. May 5, 2010 at 5:06 PM
    StrongYota22
    StrongYota22 [OP] Active Member
    Alex
    Tennessee
    01 Double Cab Prerunner
    Black Low Pro Toolbox.. More to come soon!
    Quick question. I'm almost positive these will fit on my stock tires 265/70/16.
    Will they fit when i get my OME 3" lift?
    I'm getting size: 16x8 Bolt Pattern 6x4.5 with -13 offset.
  2. May 5, 2010 at 5:31 PM
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    no because you need, 6x5.5! other than that I think they will
  3. May 5, 2010 at 5:36 PM
    StrongYota22
    Alex
    Tennessee
    haha thanks for the quick answer. That helps a lot. It doesn't say what the backspacing is on the site (I may be retarted and just can't find it) I know i need 4.5 right?
    so my new size is 16x8, 6x5.5 and 0mm offset
  4. May 5, 2010 at 6:26 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    8" wide rim with -13 offset (your original post) is 4" BS.
    8" rim with 0 offset is 4.5" BS
    Here is a chart that converts from offset to BS and visa versa. Halfway down the page
    https://www.rsracing.com/tech-wheel.html
  5. May 5, 2010 at 6:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Be sure the wheels you order are the lug centric type. The hub centric type will not fit properly on a 1st gen.
  6. May 5, 2010 at 6:31 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I personally think that a 4.5" to 5" Backspacing is perfect. That way you have the option to run a bigger tire down the road if you choose
  7. May 5, 2010 at 7:18 PM
    StrongYota22
    Alex
    Tennessee
    Thanks guys. Yall truly are the best. And hopefully i'll be able to run 285/75/16 in a month or so whenever i get the cash for them. I'm going to order the ones with 4.5 in backspacing.
    If it doesn't have the hub centric option and it just says "not hub centric" does that mean they are lug centric?
  8. May 5, 2010 at 7:21 PM
    KPT
    09 Prerunner
    Yep if they aren't hub centric, then they are lug-centric by default.
