Wheel flare rubber pads
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rctmontana, Sep 24, 2021.
  1. Sep 24, 2021 at 12:16 PM
    Rctmontana
    Rctmontana [OP] Well-Known Member
    Bozeman, Montana
    2003 5 speed M/T 2.7 sr5 4x4
    So,
    I am just finishing up painting my wheel flares and was about to install the rubber flare pad. I decided to do a dry run to fit it before I actually put it on. When doing this on the rear flares the pad is about 4-5” short! I bought genuine Toyota flare pads that were advertised as being for the rear wheel flares. Is this just a parts mixup? Is it possible the rubber has shrunk a little?
    I appreciate any input, thank you!
  2. Sep 24, 2021 at 12:21 PM
    JonathanH
    JonathanH Well-Known Member
    Jonathan
    Southern Maryland
    11' DCLB
    These should be the part numbers you got 61783-35071 which is for the pass side and 61783-35091 which is the drivers side.
    Andy01DblCabTacoma likes this.
  3. Sep 24, 2021 at 12:26 PM
    Rctmontana
    Bozeman, Montana
    I ordered from camelback Toyota in Phoenix, the part numbers I got were, 75696-35020 for the rear pads (didn’t have different part numbers for driver or passenger side), and 53851-35061 for the front pads (again no differentiation between driver or passenger).
  4. Sep 24, 2021 at 12:29 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I just replaced my rear passenger side one a few weeks ago.
    Part number: 61783-35071 Pad, Rear Wheel Opening Extension No. 1
    Exact fit.
  5. Sep 24, 2021 at 12:30 PM
    Rctmontana
    Bozeman, Montana
    Well, looks like the ones I ordered, even though advertised to fit, weren’t the right ones. Thank you for the correct part numbers.
  6. Sep 24, 2021 at 12:32 PM
    Rctmontana
    Bozeman, Montana
    Do you happen to have the front flare pad part numbers? I’m wondering now, if I don’t have the correct ones for the front either.
  7. Sep 24, 2021 at 12:32 PM
    JonathanH
    Jonathan
    Southern Maryland
    11' DCLB
    53851-35061 are correct for your Taco. They are the same left or right . The 75696 pads are for flares for a 99-00 Taco.
  8. Sep 24, 2021 at 12:34 PM
    Rctmontana
    Bozeman, Montana
    Gotcha. Thank you for the help, I appreciate it.
  9. Sep 24, 2021 at 12:35 PM
    JonathanH
    Jonathan
    Southern Maryland
    11' DCLB
    You're welcome.
