Wheel Help/Recommendation...Thx!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GIOI24, Apr 20, 2020.
  1. Apr 20, 2020 at 5:01 PM
    GIOI24
    GIOI24 [OP] Stay Humble
    Stephen
    Liberty Hill, TX
    2019 Midnight Black Tacoma TRD Sport
    TRD Skid Plate K&N Cold Air Intake Cali Raised 32" Lower Bumper Hidden LED Light Bar Cali Raised Low Profile Ditch Lights SOS Factory recovery replacement MESO Customs Ultimate Turn Signals The Gasshole TRD Pro Shift Knob TRD Pro Grill Raptor Lights MESO Chrome Delete Alpine Designs CAB MOUNT RELOCATION MBRP 3-Inch Black Series Single Exhaust System
    Need some help if anyone can provide it or point me in the right direction. Such a noob when it comes to wheels and spacings/offsets.
    The wheels I was going with were the fifteen52 Traverse HD's. 17x8.5; Zero Offset, with 4.75-Inch Backspacing.
    Well, those are significantly back-ordered so I really want to go with some Black Rhino Cinco Wheels but they are only available in 17x9.5; -18 Offset, with 4.54-Inch Backspacing.
    I will be installing a Cab mount relocate with an Elka Lift Level 3 Kit Complete 2.5 with Reservoir Suspension and ICON RXT Leafs. Also, a SPC Upper CA. I am going with KO2's - 285/70/17's.
    What is going to be the big difference on my truck with a 17x9.5 tire (-18 Offset) versus the 17x8.5 (0 Off-set)? Thanks in advance!
  2. Apr 20, 2020 at 5:33 PM
    Bizz
    Bizz Well-Known Member
    Craig
    Dallas, GA
    2020 TRD Sport DCSB Cement Grey
    Too many to list. I’m lazy
    The wheel width is going to be a bigger factor than the offset. The offset number is in mm and basically a negative offset will stick out and positive will push in. I’ve seen people running 285’s in stock suspension with a 0 offset with minimal trimming. I personally run a 3” lift with a 20x10 -18 with a cab mount chop and still rub a bit in a few places but that’s with a 10” wide wheel. I think with what you have planned the -18 should be ok but if you want to play it safe look for something with around a 8.5 to 9 in wide and stay less than -12. Method 305’s and 312’s are pretty sick and they’re 15% off tight now.
