wheel help
Discussion in 'Wheels & Tires' started by bigblack87, May 29, 2011.
  1. May 29, 2011 at 2:10 PM
    bigblack87
    bigblack87 [OP] Member
    Tyler
    Cedar Rapids, IA
    10 TRD offroad
    6in procomp,18in xd monster rims, 305/65/r18 bfg all terrain tires, nfab step bars
    hey guys so here is the deal i have a 2010 trd sport with a revtek leveling kit in it. i am going to buy some 18in xd monsters. im gonna run 285/65/18 but i dont know what offset and backspacing i need. i want it so they stick out a little ways but not to much any help?
  2. May 29, 2011 at 2:12 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You'll need 4.5" backspacing, and then you'll need to trim some plastic in the fender well and possibly chop you cab mounts.
  3. May 29, 2011 at 2:29 PM
    bigblack87
    Tyler
    Cedar Rapids, IA
    10 TRD offroad
    what size would i go if i didnt wanna trim any. toyota has a 2011 with the same lift and same size tires and xd rims i dont think they trimmed anything
  4. May 29, 2011 at 2:30 PM
    TexasTacoma37
    265/65/18/ if you don't want to trim anything. I would bet the 2011 they have on the lot rubs like hell at full lock or any time the suspension flexes.
  5. May 29, 2011 at 2:33 PM
    bigblack87
    Tyler
    Cedar Rapids, IA
    10 TRD offroad
    alrighty thanks man
  6. May 29, 2011 at 8:14 PM
    Mytidawg
    Mytidawg Active Member
    Vince
    Bay Area, CA
    07 Tacoma 4x4 Sport
    ARB front bumper, King Coil over suspension
    bigblack87...how did the wheels turn out...what did you go with
    is the 265 like a size 31"...?
    im thinkin about getting these rims...see ebay auction below......i have a 2007 tacoma...going with a king coil over....aal in the rear
    what size wheels/rims do i need to be thinking of.....i dont wish to go too huge with the rim size....im thinking stay stock...17inch......any thought?...and down the road i wish to do the gears.....what do i need to change the gears to.....4.15?
    here's the auction
    http://cgi.ebay.com/ebaymotors/ws/e...0568949354&viewitem=&sspagename=STRK:MEWAX:IT
  7. May 30, 2011 at 12:55 AM
    bigblack87
    Tyler
    Cedar Rapids, IA
    10 TRD offroad
    haven't ordered them yet! but i do have 20in mambas that came on the truck i wanna get rid of because i wanna black it out
  8. Jun 2, 2011 at 8:18 AM
    bigblack87
    Tyler
    Cedar Rapids, IA
    10 TRD offroad
    alright guys so i went to toyota on tuesday and talked to the guy that lifts them there he said if i went wit +18 offset i could fit the 285/65/18 will little trimming! they should be on tom! ill post pics asap
  9. Jun 2, 2011 at 12:50 PM
    TexasTacoma37
    I hope it works out for you, but +18 offset is way too much. The wheel will sit too far into the wheel well.
    If it's an 8" wide wheel, you need around 0 offset. If it's a 9" wide wheel, you need -12mm. Those are 4.5" backspacing.
    The +18 offset may actually make the wheel sit even further in than stock (depending on the wheel width).
  10. Jun 3, 2011 at 5:29 PM
    lopezoscar03
    lopezoscar03 Well-Known Member
    lopezoscar03@gmail.com
    what do you mean chop your cab mount?
    so if one were to get 18s for the truck, 265/65/18 is the size without trimming? how would 18s fit without lifting the truck?
  11. Jun 3, 2011 at 5:54 PM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    You can fit 4.75 backspacing as well with that set up. Although you'll rub less with a 4.5 or more on your cab mounts. Just remember the farther away the wheel is from the hub the more wear your placing on your bearings. I'd stick with a 4.5 if I were you and go no more or less. If you don't want to trim put a 265/70/R18 on it and you'll be fine but If you want to look cool just cut the plastic and put the 32's on it like you want. The cutting can be completed with a pocket knife and now no one will know you did it. Unless their a TW member
  12. Jun 4, 2011 at 12:15 PM
    TexasTacoma37
    I was running 265/65/18 before I got my lift with no trimming. Pics are in my build if you click my sig.
