Wheel help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by picturethis, Feb 21, 2025.
  1. Feb 21, 2025 at 2:42 PM
    picturethis
    picturethis [OP] Well-Known Member
    Billy
    Issaquah, Wa
    2001 and 2016 Silver Tacoma DCLB TRD Sport
    BAMF Grille CBI Sliders Victory4x4 roof rack Cali Raised fog lights FNFX wheels Falken Wildpeaks tires
    Did research, just not sure!
    My current setup: 285/70/17 FNFX wheels 17x8 0mm offset 6x139.7 and I have 1.25" wheel spacers. They were put in to get it off the UCA's.
    JBA UCA's
    Lift is Bilstein 6112/5160
    Over the last year and a 1/2 I have replaced all 4 wheel bearings, I have heard the spacers play a roll in that.
    With that said I want to remove the wheel spacers and try to get a similar look, poked out a bit and no rubbing. I have a CMC and did some trimming to fit what I have now.
    I was looking into the SCS BR6, comes in a -38 offset and a -10, the 10 would move in around an inch, which I don't want to do, the 38 will rub I'm sure!
    Any similar wheels or advice will be greatly appreciated, scratching my head here on what to do!
    thanks
  2. Feb 21, 2025 at 3:29 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    High negetive wheel offset in general is harder on wheel bearings but I have been on -25 and -38 wheels for 2 years now on wheel bearing that already had 150k ish on them and iv only had to do one after railing a monster hole in a field.
    If your wheeling alot and hammering on the truck I would bet that is the root cause ontop of the offset putting additional strain on them
    Also I'm pretty sure a 0 offset plus a 1.25 spacer is basically a -38
    picturethis[OP] likes this.
